Back Panel
2 Answers 0 Score |
How can the internal storage be upgraded? |
1 Answer 1 Score |
No NVMe Detected After RAM/SSD Upgrade on 2026 Steam Machine - lspci C |
2 Answers 0 Score |
Where can I find a replacement power cord? |
1 Answer 1 Score |
Replacement Lan / usb ribbon cable |
Documents
Background Information
Announced on November 12, 2025, alongside the Second Generation Steam Controller and the Steam Frame, Valve's second go at the Steam Machine is a compact 6x6-inch Linux-based PC designed to offer an accessible, console-like gaming experience built on SteamOS. The new Steam Machine features a semi-custom AMD Zen 4 CPU and RDNA-3 GPU, which offer more than 6 times the performance power of the Steam Deck. With living-room gaming in mind, the Steam Machine supports 4K at 60 FPS with FSR upscaling.
The Steam Machine (2nd Generation, 2026) is offered in either 512 GB or 2 TB SSD configurations; however, both have expandable storage via a high-speed MicroSD card slot. Additionally, users can customize the LED status strip or disable it entirely, and can swap out the front plate.
Valve started shipping 2nd-gen Steam Machines globally in June 2026, with the base 512 GB model priced at $1,049 and the 2TB model priced at $1,349. Steam Controllers can be bundled at a discounted +$79 with either model.
Technical Specifications
General Information
- CPU: Semi-Custom AMD Zen 4 6C / 12T
- Up to 4.8 GHz, 30W TDP
- GPU: Semi-Custom AMD RDNA3 28CUs
- 2.45 GHz max sustained clock, 110W TDP
- RAM: 16 GB DDR5 + 8GB GDDR6 VRAM
- Power: Internal Power Supply, AC Power 110 - 240V
- Storage:
- 512 GB NVMe SSD
- 2 TB NVMe SSD
- Expandable Storage: High-speed MicroSD Card Slot
Connectivity
- Wi-Fi: 2x2 Wi-Fi 6E
- Bluetooth: Bluetooth 5.3 Dedicated Antenna
- Steam Controller: Integrated 2.4 GHz Steam Controller Wireless Adapter
I/O
- Display:
- DisplayPort 1.4:
- Up to 4K@240 Hz or 8K@60 Hz
- Supports HDR, FreeSync, and Daisy-Chaining
- HDMI 2.0:
- Up to 4K@120 Hz
- Supports HDR, FreeSync, and CEC
- DisplayPort 1.4:
- USB:
- Two USB-A 3.2 Gen 1 Ports in the front
- Two USB-A 2.0 High Speed Ports in the back
- Once USB-C 3.2 Gen 2 Port in the back
- Networking: Gigabit Ethernet
- LED Strip: 17 Individually Addressable RGB LEDs for system status and customization
Size & Weight
- Size:
- Height: 152 mm (148 mm without feet) / 5.98 in (5.83 in without feet)
- Depth: 162.4 mm / 6.39 in
- Width: 156 mm / 6.14 in
- Weight: 2.6 kg / 5.73 lb
Software
- Operating System: SteamOS 3 (Arch-Based)
- Desktop Environment: KDE Plasma
