Shop the Holiday Gift Guide
Steam Machine (2026) Back Panel Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
36
Past 30 Days:
134
All Time:
454
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
OEM Guide
iFixit collaborated with the manufacturer to make this guide.
Introduction
Go to step 1 ↓
Follow this guide to remove or replace the back panel on your Valve Steam Machine (2026).
Tools
    1. Steam Machine (2026) Back Panel Replacement, Before you begin: step 1, image 1 of 2 Steam Machine (2026) Back Panel Replacement, Before you begin: step 1, image 2 of 2
      • Before you begin this repair:
      • Power off your Steam Machine and disconnect the power cable.
      • Unplug any remaining cables or accessories from all ports.
      Ask FixBot
    1. Steam Machine (2026) Back Panel Replacement, Reposition the Steam Machine: step 2, image 1 of 1
      • Reposition the Steam Machine so the back panel is facing up.
      Ask FixBot
    2. Steam Machine (2026) Back Panel Replacement, Loosen the back panel screws: step 3, image 1 of 2 Steam Machine (2026) Back Panel Replacement, Loosen the back panel screws: step 3, image 2 of 2
      • Use a T8 Torx screwdriver to fully loosen the two captive screws securing the back panel.
      Ask FixBot
    3. Steam Machine (2026) Back Panel Replacement, Remove the back panel: step 4, image 1 of 3 Steam Machine (2026) Back Panel Replacement, Remove the back panel: step 4, image 2 of 3 Steam Machine (2026) Back Panel Replacement, Remove the back panel: step 4, image 3 of 3
      • The back panel is secured by two metal tabs along the bottom edge and two locking clips on the sides.
      • Lift the top edge of the panel (near the screws) until the two locking clips release.
      • If you're having trouble getting an initial grip on the panel, use a spudger to lift it enough to grab with your fingers.
      • Slide the panel towards the top edge and lift to remove it.
      Ask FixBot
Spencer Day
208,732 Reputation
1,266 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 36
Past 30 Days: 134
All Time: 454
