Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
OEM Guide
iFixit collaborated with the manufacturer to make this guide.
Introduction
Go to step 1 ↓Follow this guide to replace or upgrade the SSD (aka storage) in your Valve Steam Machine (2026).
The Steam Machine has a single M.2 NVMe slot that's compatible with 2230 or 2280 form factors.
These steps only describe how to physically remove and replace your SSD. You'll need additional software tools and procedures to install an OS and get the replacement SSD to function as intended.
Follow Valve's SteamOS installation instructions to install, re-image, or repair SteamOS on your Steam Machine. Follow Valve's Steam Deck recovery instructions to reset or recover SteamOS on your device. For installing Windows, official resources can be found here.
Tools
Power down your Steam Machine and disconnect the power cable.
Unplug any remaining cables or accessories from all ports.
Reposition the Steam Machine so the back panel is facing up.
Use a T8 Torx screwdriver to fully loosen the two captive screws securing the back panel.
Lift the top edge of the panel (near the screws) until the two locking clips release.
Slide the panel towards the top edge and lift to remove it.
Use a T8 Torx screwdriver to remove the two 7.3 mm‑long screws securing the inner assembly.
Grip the inner assembly under the fan and lift it straight up and out of the shell.
Set the inner assembly down so the SSD is on top.
Use a T8 Torx screwdriver to remove the 5.1 mm‑long screw securing the SSD.
Pull the SSD out of its socket at the angle it popped up at to remove it.
Use a 5.0 mm nut driver to remove the standoff screw and install it in the desired position:
2280
2230
2 other people completed this guide.
