Robot Vacuum Cleaner Troubleshooting: Fix Common Problems
The first step towards a working Robot Vacuum Cleaner is identifying the problem. Select one of our preferred guides below to diagnose and solve Robot Vacuum Cleaner common issues.
Robot Vacuum Won’t Connect to the App or Wi-Fi
The smart home connection is convenient, but when it doesn’t work, it can get frustrating fast. Luckily, this can almost always be fixed easily.
Robot Vacuum Won’t Mop or Leaks Water
If your robot with mopping function no longer dispenses water or leaks too much, the cause is usually the water tank or seal. The good news: You can almost always fix this yourself.
Robot Vacuum Won’t Turn On
If your robot vacuum no longer responds at all, that’s frustrating. But don’t worry: in most cases, the cause is easy to find and fix. Regular maintenance and cleaning are essential for a long lifespan. Follow the cleaning guide regularly and replace filters and brushes on time.
Robot Vacuum Shows an Error Message or Flashing LEDs
Flashing lights or error messages may seem complicated, but they are usually quite clear. They help you understand what your robot needs.
Robot Vacuum Won’t Charge
You place the robot on the dock, but nothing happens? Don’t worry. The cause is often a simple contact issue or a power supply problem. Regular maintenance and cleaning help prevent issues like this.
Robot Vacuum Can’t Find the Charging Dock
If the robot stops somewhere after cleaning with an empty battery, the issue is usually the dock’s position or dirty sensors.
Robot Vacuum Has No Suction or Weak Suction
If your robot is moving but barely picking up any dirt, the cause is almost always a blockage or a dirty filter.
Robot Vacuum Makes Loud or Unusual Noises
A robot vacuum should sound quiet and steady. If it suddenly rattles, squeaks, or hums, it usually means there is dirt in the mechanism. It is rarely a real defect.
Robot Vacuum Gets Stuck or Stops Mid-Clean
If your robot keeps getting stuck or stops before it finishes cleaning, there can be several causes. Often, the problem is hair, cables, or dirty sensors.
Robot Vacuum Only Cleans Partially or Skips Areas
If the robot only cleans part of your home, the cause is usually navigation, mapping, or blocked areas, not the device itself.
Robot Vacuum Doesn’t Navigate Properly or Bumps Into Walls
If your robot drives around your home without orientation, bumps into walls, or constantly gets lost, dirty sensors or navigation errors are almost always the cause.
Didn't see your problem? The iFixit Community has answers.
Browse the most common questions asked by our members to see more solutions. Still no luck? You can always ask for help!
Roomba keeps giving error 2 even when brushes are clean
iRobot Roomba 500 Series
How to stop my i7 from spinning in circles in one place?
iRobot Roomba i7
Battery won't charge.
Samsung Jet Bot VR30T80313W
Vacuum will not go straight
iRobot Roomba 4230
Clean Water Tank Empty ... but it's NOT
Narwal Freo Z10
How do I factory reset the device.
Ecovacs DEEBOT DN622.11
Why will my Roomba not charge?
iRobot Roomba 655 Pet Series
