Causes
- “Wheel blocked” / “Wheel Error”
- Cause: Hair or dirt around the wheels or caster wheel
- Solution: Clean all wheels thoroughly.
- “Brush blocked” / “Brush Error”
- Cause: Main brush or side brushes are blocked
- Solution: Remove the brushes, clean them, and reinstall them.
- “Sensor error” / “Sensor Error”
- Cause: Sensors are dirty
- Solution: Wipe all sensors with a lint-free cloth.
- “Dustbin missing” / “Dustbin Error”
- Cause: Dustbin is not installed correctly or sensor is dirty
- Solution: Clean the contacts and insert the dustbin firmly.
- “Stuck” / “Stuck”
- Cause: Robot is caught in cables or carpet fringe
- Solution: Free the robot and clear obstacles out of the way.
- “Low battery” / “Low Battery”
- Cause: Battery is too weak to return to the dock
- Solution: Carry the robot manually to the charging dock and fully charge it.
- “Charging error” / “Charging Error”
- Cause: Problem with the charging contacts or dock
- Solution: Clean the contacts thoroughly.
- “Navigation error” / “Navigation Error”
- Cause: Laser or camera is dirty
- Solution: Clean the navigation components and restart the robot.
You're seeing solutions for Robot Vacuum Cleaner. Select your model to find parts for your device.
Describe your problem in your own words
View statistics:
Past 24 Hours:3
Past 7 Days:15
Past 30 Days:121
All Time:238
