MacBook Air 13" (Mid 2012 through Early 2015) Battery
$119.95
$119.95
We'll send a message when the product is back in stock.
Product Details
Features
Features
Give new life to your MacBook!
Replacement 7150 mAh battery compatible with all 1.3 or 1.7 GHz (Mid 2013), 1.4 or 1.7 GHz (Early 2014), and 1.6 GHz or 2.2 GHz (Early 2015) 13" MacBook Airs, and backward compatible with 1.8 or 2.0 GHz (Mid 2012) 13" MacBook Airs.
Please note: This battery may experience issues under OS X El Capitan (10.11.x) or higher. We're not sure if all computers running El Capitan or higher have this issue yet. If the battery you buy from us does not work, please contact us.
Note: Lithium ion battery shipping regulations limit the shipping methods for orders containing batteries. Domestic orders may only be shipped via Standard shipping. iFixit is not able to ship batteries internationally or outside the contiguous US at this time. iFixit Customer Support will contact you if your order needs to be modified after it is placed.
Compatibility
MacBook Air 13" Early 2014
1.4 GHz (Early 2014)
MacBook Air 13" Early 2015
1.6 GHz (Early 2015)
MacBook Air 13" Mid 2012
1.8 GHz (Mid 2012)
2.0 GHz (Mid 2012)
MacBook Air 13" Mid 2013
1.3 GHz (Mid 2013)
1.7 GHz (Mid 2013)
Show 1 more devices
Repair Stories
User avatar
My Problem
Battery failing in mid 2012 MacBook Air
My Fix
Very easy repair. Lots of screws but the repair guide is easy to follow. I decided to use this 2013 battery in my mid-2012 MacBook Air so I'd get a bit more time out of the battery. Seems to work just fine and fits like the original. Was a real Apple part so yo . . .
User avatar
My Problem
An entire cup of coffee got spilled on my MacBook Air.
My Fix
I actually took apart the entire interior except the keyboard & trackpad, but in the end, only the battery needed replacing. I rinsed all the logic board & SSD card in isopropyl alcohol and spot cleaned the rest of the coffee spots. After 48 hrs . . .
User avatar
My Problem
As a musician doing outdoor gigs in Florida, my macbook air gets exposed to a lot of use above the recommended ambient temperature. Battery went stone cold dead.
My Fix
Repair was a piece of cake! iFixIt has excellent visual instructions. Very easy to follow.
My Advice
Get 4 small containers to put the screws in... Th . . .
User avatar
My Problem
Battery icon indicated a problem.
My Fix
Repair was super easy.
My Advice
The screws on bottom of case have very shallow heads. I bought/used the recommended tools. I had to apply light to medium downward pressure to keep screw driver head seated properly.
Very happy I was able to use a 2013 battery with better spec . . .
User avatar
My Problem
So I bought my fiancée a MacBook Air for Christmas 2014. In February while playing with our puppy, she threw a toy and it knocked a glass of tea over onto her computer. It was open, but turned off. She was devastated.
My Fix
I immediately cleaned up all the tea I could, and opened it up and let it dry f . . .
User avatar
My Problem
Original battery froze subzero, didn't recover
My Fix
Great, once I got the right tools. Trivial to remove old battery and replace it. This item works perfectly in MacBookAir5,2
My Advice
I assumed torx throughout, but the case is a pentalobe T5 and the battery itself is a torx T4. Other than that it is a 2 minute j . . .
User avatar
My Problem
1/2 cup of water-spill over keyboard made my MacBook Air 13" inoperable.
My Fix
Apple wanted $750 for repair. After internet research and agonizing a lot over the situation I discovered ifixit.com. In short time I learned the way to open the back of the unit, clean the corrosion and identify the faulty part . . .
User avatar
My Problem
My original battery had problems with about 500 cycles and it was lasting only 20 minutes (sometimes less).
My Fix
Good. It's a very easy part to replace. The only problem I had was that, after changing the battery, my trackpad is a liiittle bit loose. When I click it, it makes a sound like it's a little lo . . .
User avatar
My Problem
the internal battery was done and needed to be replace - costes here were extremly high
My Fix
was very easy! took a while to find the correct screwdriver - BUY THE OFFERED SCHREWDRIVER!- opened the metal case, the old battery pulled out very easyliy as instructed in the video and shut it back closed - 2 d . . .
User avatar
My Problem
My battery with almost 700 cycles and approximately 80% health was starting to cause MBA shutdowns with greater than 50% charge remaining.
My Fix
Replacing the battery is a very easy MBA repair. You just need the right tools.
My Advice
I was concerned about previous reports of MBA battery replacement issues under El . . .
Show more
