Causes
- “Wheel blocked” / “Wheel Error”
- Cause: Hair or dirt around the wheels or caster wheel
- Solution: Clean all wheels thoroughly.
- “Brush blocked” / “Brush Error”
- Cause: Main brush or side brushes are blocked
- Solution: Remove the brushes, clean them, and reinstall them.
- “Sensor error” / “Sensor Error”
- Cause: Sensors are dirty
- Solution: Wipe all sensors with a lint-free cloth.
- “Dustbin missing” / “Dustbin Error”
- Cause: Dustbin is not installed correctly or sensor is dirty
- Solution: Clean the contacts and insert the dustbin firmly.
- “Stuck” / “Stuck”
- Cause: Robot is caught in cables or carpet fringe
- Solution: Free the robot and clear obstacles out of the way.
- “Low battery” / “Low Battery”
- Cause: Battery is too weak to return to the dock
- Solution: Carry the robot manually to the charging dock and fully charge it.
- “Charging error” / “Charging Error”
- Cause: Problem with the charging contacts or dock
- Solution: Clean the contacts thoroughly.
- “Navigation error” / “Navigation Error”
- Cause: Laser or camera is dirty
- Solution: Clean the navigation components and restart the robot.
You're seeing solutions for Robot Vacuum Cleaner. Select your model to find parts for your device.
Related Problems
11 problems · View all
Describe your problem in your own words
View statistics:
Past 24 Hours:6
Past 7 Days:59
Past 30 Days:226
All Time:817
