Shop the Holiday Gift Guide
Roborock Q5 Max Plus Troubleshooting: Fix Common Problems
The first step towards a working Roborock Q5 Max Plus is identifying the problem. Select one of our preferred guides below to diagnose and solve Roborock Q5 Max Plus common issues.
Brush Not Moving
If your Roborock Q5 Max Plus is running but the main brush isn’t spinning as it should and as a result, the vacuum struggles to pick up dirt and debris, the following solutions may help.
Suction Is Weak
If your Roborock Q5 Max plus is running, but its suction power is significantly weaker than expected, the following solutions may help.
Does Not Dock Properly
If your Roborock Q5 Max+ fails to return to or connect properly with its dock, preventing recharging or self-emptying functions, the following solutions may correct the problem.
Roborock Q5 Plus Not Charging
If your Roborock Q5 Max Plus is unresponsive when you plug the charger in and doesn't charge, this page offers potential solutions.
Didn't see your problem? The iFixit Community has answers.
Browse the most common questions asked by our members to see more solutions. Still no luck? You can always ask for help!
How to inspect lidar
