Shop the Holiday Gift Guide
Guides
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
The Roborock Q5 Max Plus is an advanced robotic vacuum cleaner designed to provide an efficient and intelligent home cleaning experience. Released as part of Roborock's Q-series lineup, this model is built to navigate and clean homes with precision while minimizing user intervention. It is a smart vacuum that combines high suction power, LiDAR-based navigation, and app integration to deliver an optimized cleaning experience.
The Roborock Q5 Max Plus features a powerful 5500 Pa suction system, making it highly effective on carpets and hard floors. The vacuum is equipped with LiDAR navigation technology, allowing it to map multiple levels of a home, avoid obstacles, and create efficient cleaning routes. It supports app-based controls via the Roborock or Xiaomi Home app, enabling users to schedule cleanings, set virtual barriers, and customize cleaning preferences. The Q5 Max Plus is also compatible with voice assistants such as Amazon Alexa, Google Assistant, and Apple Siri Shortcuts.
This robotic vacuum comes with a self-emptying dock, allowing it to automatically empty its dustbin into a larger container, reducing the need for frequent maintenance. It includes a long-lasting battery, offering up to 250 minutes of runtime per charge, and a washable E11-rated filter, which helps capture fine dust particles, improving indoor air quality.
The Roborock Q5 Max Plus is a well-regarded model in the Roborock lineup, praised for its reliability, strong suction power, and smart navigation. While it is a durable device, common issues may include sensor misalignment, brush wear, battery degradation, or dustbin maintenance. Users may need to replace key components such as side brushes, main brushes, wheels, or filters over time to maintain optimal performance. Equipped with a large water tank for mopping. It has an auto-lifting mop function that lifts the mop when vacuuming carpets to keep them dry.
Identification
The Roborock Q5 Max Plus can be identified by the notch at the top with the Roborock logo. "Roborock" is printed on the device, and there are three silver-colored buttons on the top of the unit.
The Auto-Empty dock tower has an opaque top for the dustbin and a ramp for the robot vacuum. "Roborock" is printed on the front.
Technical Specifications
Performance:
  • Suction power: Adjustable up to 5500 Pa.
  • Cleaning Modes: Five levels, ranging from 'Quiet' to 'Max+'.
  • Navigation system: PreciSence LiDAR for accurate mapping and navigation.
  • Surface Detection: Automatically increases suction on carpeted floors.
Brush System:
  • Main Brush: DuoRoller system with dual rubber brushes to minimize hair tangles and enhance debris pickup.
  • Side Brush: Single fixed brush for edge cleaning.
Dustbin and Filtration:
  • Onboard Dustbin Capacity: Approximately 550 milliliters.
  • Auto-Empty Dock Capacity: Utilizes 2-liter dirtbags capable of holding up to seven weeks' worth of debris.
  • Filtration system: E11-rated Filter for capturing fine particles.
Battery and Charging:
  • Battery capacity: 5200 mAh lithium-ion.
  • Maximum runtime: Up to 250 minutes in 'Quiet' mode.
  • Recharge time: Approximately 2-3 hours.
Dimensions and Weight:
  • Robot Vacuum: Height 3.9 inches; Depth 13.9 inches.
  • Docking station: Height 16.7 inches; Width 11.9 inches.
  • Weight: 7 pounds.
Additional Information
The Roborock Q5 Max Plus is designed to be user-friendly and efficient. It offers an intuitive app interface that allows users to track cleaning progress, set cleaning schedules, and make adjustments on-the-go. The robot’s LiDAR-based mapping system ensures thorough coverage and avoids obstacles, even in complex home layouts.
In addition, the vacuum features customizable cleaning zones and virtual barriers, allowing users to focus cleaning efforts on specific rooms or areas while avoiding others. With its long-lasting battery, efficient navigation, and robust suction power, the Roborock Q5 Max Plus is suitable for both large homes and smaller apartments.
Roborock Support Center
Additional Trouble Shooting
Roborock Forum
Author
with
Hector Borjas
188 Reputation
1 Guide authored
Past 24 Hours: 1
Past 7 Days: 30
Past 30 Days: 100
All Time: 1,688
