Click Image To Zoom
Unibody Laptop Dual Drive
$39.95 Was $59.95
You save $20.00!
Product code: IF107-080
Product Overview
Replace a laptop optical drive with a 9.5 mm SATA drive
  • CDs are fast becoming obsolete, yet data space never goes out of style.
  • Adds a lot more space to your laptop.
  • Add an SSD for your OS and most commonly used Apps to drastically increase your speed, while still keeping your old HDD for capacity.
  • Kit includes a USB to SATA adapter cable that will let you keep using your optical drive after it's been removed.
  • Does not include hard drive.
Kit Contents:
  • SATA Optical Bay SATA Hard Drive Enclosure
  • Plastic Spudger
  • SATA USB Cable - continue using your optical drive after it's removed
  • iFixit Tool Pouch
  • 4 mm Precision Screwdriver Handle - includes the following bits:
    • Phillips #00
    • Torx T6
    • Torx T8
    • Pentalobe P6
    • Tri-wing Y1
    • Magnetic Pickup Bit
Compatibility
  • All Unibody MacBooks and Unibody MacBook Pros (excluding MacBook Pro Retina)
Product Details
$39.95 Enclosure Only
Condition:
New
Warranty:
6 month warranty
Notes:
This enclosure does not work with ATA drives or hard drives thicker than 9.5 mm.
$49.95 Upgrade Kit
Condition:
New
Warranty:
6 month warranty
Notes:
Everything you need to add a 9.5mm SATA hard drive to your laptop, while still being able to use your optical drive externally.
Add to Cart »
Install Videos
Replacement Guides
MacBook Pro 13" Unibody Early 2011
Difficulty: Moderate
MacBook Pro 13" Unibody Late 2011
MacBook Pro 13" Unibody Mid 2009
MacBook Pro 13" Unibody Mid 2010
MacBook Pro 13" Unibody Mid 2012
MacBook Pro 15" Unibody Early 2011
MacBook Pro 15" Unibody Late 2011
MacBook Pro 15" Unibody Mid 2009
MacBook Pro 15" Unibody Mid 2010
MacBook Pro 15" Unibody Mid 2012
MacBook Pro 17" Unibody
MacBook Unibody Model A1278
MacBook Unibody Model A1342
Compatibility
2.3 GHz (Early 2011)
2.7 GHz (Early 2011)
2.4 GHz (Late 2011)
2.8 GHz (Late 2011)
2.26 GHz (Mid 2009)
2.53 GHz (Mid 2009)
2.4 GHz (Mid 2010)
2.66 GHz (Mid 2010)
2.5 GHz (Mid 2012)
2.9 GHz (Mid 2012)
MacBook Pro 15" Unibody 2.53 GHz Mid 2009
2.53 GHz (Mid 2009)
2 GHz (Early 2011)
2.2 GHz (Early 2011)
MacBook Pro 15" Unibody Late 2008 and Early 2009
2.4 GHz (Late 2008)
2.53 GHz (Late 2008)
2.66 GHz (Early 2009)
2.8 GHz (Late 2008)
2.93 GHz (Early 2009)
2.2 GHz (Late 2011)
2.4 GHz (Late 2011)
2.5 GHz (Late 2011)
2.66 GHz (Mid 2009)
2.8 GHz (Mid 2009)
3.06 GHz (Mid 2009)
2.4 GHz (Mid 2010)
2.53 GHz (Mid 2010)
2.66 GHz (Mid 2010)
2.8 GHz (Mid 2010)
2.3 GHz (Mid 2012)
2.6 GHz (Mid 2012)
2.7 GHz (Mid 2012)
2.53 GHz (Mid 2010)
2.66 GHz (Mid 2010)
2.8 GHz (Mid 2009)
2.8 GHz (Mid 2010)
3.06 GHz (Mid 2009)
MacBook Pro 17" Unibody Early 2011
MacBook Pro 17" Unibody Late 2011
2.4 GHz (Late 2011)
2.5 GHz (Late 2011)
2 GHz (A1278)
2.4 GHz (A1278)
2.26 GHz (A1342)
2.4 GHz (A1342)
Stories
My Problem
Purchased the MBP with a small SSD with intentions to implement this configuration
My Fix
Relatively smooth. I would recommend using a Phillips #0 rather than #00
My Advice
Be absolutely certain the SSD you wish to install has a compatible data transfer rate with your machine AND has the most up to date firmware (TRIM enabled)
My Problem
Installed SSD for use as fusiondrive with onboard HHD
My Fix
Went well although design of bluetooth antenna was different than repair plan showed. Succeded anyway
My Advice
Just look very carefully and then just do it!
My Problem
I installed the Dual Drive for the always-available Time Machine backup. Optical storage really is antiquated.
My Fix
The installation went perfectly, however certain bizarre issues resulted. My MacBook Pro seemed to no longer go to sleep, preferring instead to shut itself down, then complain to me upon boot that this had happened. Additionally, Bluetooth would inconsistently report itself unavailable. After some light reading, I reset the SMC, PRAM, reinstalled Mavericks 10.9.2 and recovered my setup via Time Machine, and reflected seriously on whether or not I needed Bluetooth or suspend mode for my laptop.
The solution (so far, anyway) seems to be to shutdown the computer, disconnect the SATA connector to the Dual Drive, reboot, suspend, reconnect the SATA, then restart. That solved the problem for me.
My Advice
I have no way of knowing what the cause of this issue was and I may never know. At first I thought it might be related to the amp draw via SATA possibly sharing a power bus with Bluetooth. Now I think it may have been Mavericks confused by how a SuperDrive miraculously became a hard disk. I believe the problem is resolved.
My Problem
Needed more storage for Linux! I fixed the problem with a 1TB Western Digital Blue drive for laptops.
My Fix
Smoothly! It was a lot of fun getting into the guts of my old MacBook Pro and customizing my old machine!
My Advice
That little piece of plastic holding the iSight camera in place is a doozy! Just handle it all gingerly and always use a spudger!
My Problem
Little hd space and slow performance.
My Fix
Smooth, not a single problem following the guide.
My Advice
I produced my own magnetic mat using a couple of magnetic sheets I purchased in a paper store and printed an A4 sheet with a grid on my computer - DONE.
