Shop the Holiday Gift Guide
Suction Is Weak
Ali Alabadi and 1 contributor
Last updated on
If your Roborock Q5 Max plus is running, but its suction power is significantly weaker than expected, the following solutions may help.
Causes
 Dust and debris accumulation in the dustbin and filter can restrict airflow, reducing suction power. To resolve this:
  • Remove the dustbin and empty it completely.
  • Check the filter and clean it by tapping it gently to remove loose dirt.
  • If the filter is washable, rinse it with water and let it dry completely before reinserting.
  • If the filter is heavily soiled or damaged, replace it with a new one.
2
Hair, fibers, and debris wrapped around the brushes can obstruct airflow. To clean them:
  • Turn the vacuum upside down and inspect both the main and side brushes.
  • Use a cleaning tool or scissors to carefully remove any entangled debris.
  • If the brushes appear worn or damaged, replace them with new ones.
3
The vacuum's suction power may be reduced due to incorrect settings. To adjust:
  • Open the Roborock app on your mobile device.
  • Navigate to the suction settings and set the vacuum to a higher mode, such as "Turbo" or "Max."
4
Improperly installed components can cause air leaks, reducing suction efficiency. To check:
  • Remove the dustbin and filter.
  • Reinsert them securely, ensuring they fit snugly in their respective compartments.
5
Dirty sensors can affect navigation and suction optimization. To clean them:
  • Use a dry microfiber cloth or a cotton swab with isopropyl alcohol.
  • Gently clean the sensors, especially those near the dustbin and suction intake.
6
If none of the above solutions resolve the issue, the vacuum's motor or internal components may be failing. To diagnose:
Describe your problem in your own words
View statistics:
Past 24 Hours:10
Past 7 Days:25
Past 30 Days:103
All Time:1,350
