Shop the Holiday Gift Guide
Samsung Ice Maker Not Making Ice
$35.95
5
1 reviews
Introduction
You had one job - make ice. Perhaps your machine isn't ejecting ice, hums, or just isn't creating ice quickly. These fixes will help reset your Samsung ice maker if your fridge still dispenses water. Let's jump into potential solutions.
If you need a replacement ice maker, iFixit offers Samsung ice maker assemblies.
First Steps
If your fridge doesn't dispense water, you'll have to first pull the machine out and check the water supply to the back of the fridge. Consider resetting your ice maker first.
Causes
If the ice maker isn't working, check the ice maker switch. This switch is usually located behind the ice bucket and frequently gets turned off by accident. If the switch is turned on but the ice maker still doesn't work, check the switch for continuity with a multimeter. Replace as needed.
As ice is made, it falls to a lower storage tray. In circumstances where the ice doesn't fully freeze, or melts and then refreezes, it can form a blockage for future ice. In this case, the ice maker will rattle and make noise while no ice is made.
- Check the chute where ice cubes are made and see how large the blockage might be.
- Perform a defrost procedure.
- Remove the stuck ice with a chisel, hairdryer, or warm water and rag while making sure not to break the plastic bits.
Ice may have built up in the ice molds. Remove and pour warm water through the molds so the old ice will melt and new ice can form.
Whenever your ice maker stops working, check the temperature of the freezer. If the freezer temperature is above 10 degrees F (-12 C) the ice maker will not work properly. It functions best when the freezer temperature is set between 0 and 5 degrees F (-18 to -15 C).
If the freezer temp is too high, make sure the condenser coil is clean and the condenser fan is working to cool the condenser and compressor. These can get covered in hair in grime and can be cleaned with a condenser coil brush.
Check the evaporator coil for frost—if too much frost builds up, the air can't circulate through the coil and you will need to check the defrost components for a failure.
Another reason why the temperature may be unstable is due to a faulty door seal. Without a good seal, temperatures become unstable with warm air seeping into the fresh food door. When the temperature sensor detects the warmer air, the controller keeps the compressor running constantly to maintain the correct 37-degree temperature for fresh food. This excessive cooling causes the freezer temperature to fall well below zero, which will freeze the tip of the water tube that provides the ice maker with water.
Keep in mind that for proper door suction and sealing, the doors need to be self-closing so their weight helps maintain the seal.
- The leveling rollers or legs need to be adjusted to tilt the fridge back slightly. When a proper seal is made, within 24 hours the defrost cycles will thaw the water tube and begin ice production.
If the refrigerator ice maker is not working, the door switch might be defective. When the freezer door is opened, the freezer door switch does two things: it turns on the light in the freezer, and turns off the ice maker and dispenser. If the door switch fails, the dispenser will not turn on. The switch can be checked for continuity with a multimeter. If it doesn’t have continuity, it should be replaced.
Your ice maker may halt ice production while the water filter is clogged and the replacement light is on. This is a safety and flavor precaution and prevents the machine from making poor quality ice.
- If it's been more than 6 months since you last replaced your fridge's water filter, replace it now.
If the temperature is correct but the ice maker won’t work, the water inlet valve might be defective. The water inlet valve is an electrically-controlled mechanical valve that opens to supply water to the dispenser and ice maker. If the water inlet valve is defective, or if it has insufficient pressure, it won’t allow water to flow through. As a result, the ice maker won’t make ice.
The valve requires at least 20 psi to function properly.
- Make sure that the water pressure to the valve is at least 20 psi. Close the water inlet valve, and then disconnect the water inlet hose. Hold the hose over a bucket, and open the valve.
If the water pressure is sufficient, use a multimeter to check for power (continuity) to the water inlet valve. If the water inlet valve has sufficient pressure and is getting power, but the ice maker won’t fill with water to make ice, replace the water inlet valve.
Flex-tray or twist-try ice makers eject cubes by twisting of the ice tray. As this plastic tray ages, it becomes brittle, stiff, and more likely to crack.
Interruption in the flow of water through the water line leading to the ice maker can account for no new ice production. This can mean a closed valve, a kink or clog in the line, or a disconnection of the line.
- Inspect every valve, line, and connector for leaks. Replace and tighten as you go.
If the ice maker is not working it could be that the ice maker assembly itself is defective. There are several components in the control module of the ice maker that can fail, and most are not sold separately. Some ice makers have a relatively short lifespan and may not always be worth fixing.
- If other, simpler parts like the water inlet valve or shut-off arm have been ruled out, and the only thing left is the ice maker itself, replace the ice maker assembly.
Find compatible replacement parts for your Samsung Refrigerator. All parts and fix kits are backed by the iFixit Quality Guarantee.
If the ice maker is not working the ice level control board might be defective. The refrigerator is equipped with an infrared light beam to detect the level of ice in the ice bucket. As the ice level reaches the top, the beam is interrupted and the ice maker shuts off. As ice is used up and ice drops below the beam, the ice maker starts up again. If the ice level control board fails, the ice maker will stop making ice.
If the ice maker is not working, the ice maker mold thermostat might be defective. Inside the control module of the ice maker is a thermostat that monitors the temperature of the ice mold (ice tray). Once the mold reaches the proper temperature, the ice maker starts a harvest cycle by ejecting the ice cubes and refilling the tray with water.
If the mold thermostat is defective, the ice maker doesn't advance. The thermostat can be checked for continuity. Replace it as needed. The freezer temp should be between 0-5 degrees for optimum performance.
Your machine may have stored error codes preventing further ice. If you cleared clogged ice, it may be worth switching your machine on and off. If it's possible to reset the ice maker settings on a control panel, perform the reset.
If your ice maker isn't responding to these attempts, confirm secure electrical connections to the ice maker, control panel, and outlet.
Included Models
This guide should cover the models listed below. Hit CTRL+F or CMD+F and search with your model number:
RB217ABPN, RF217ACPN, RF217ACRS, RF266ABPN, RF266AEPN, RF267ABRS, RF267AERS, RF268ABRS, RF4287HARS, RF4287HARSXAA, RFG297AARS, RFG298HDRS, RS2530BBP, RS2630SHXAA, RS2630WWXAA, RS265TDRS, RS267LABP, RS267LASH, RS269LARS, RS2777SL, RSG257AARS
You're seeing solutions for Samsung Refrigerator. Select your model to find parts for your device.
Related Problems
12 problems · View all
- Ice Maker Only Crushing Ice
- Ice Maker Not Dispensing Ice
- Ice Maker Won't Stop Making Ice
- Compressor Running but Not Cooling
- Fridge Not Cooling But Freezer Works
- Compressor Not Running
- Light Flickering
- Freezer Ice Building Up
- Making Knocking Noise
- Sounds and Possible Causes
- Freezer Not Freezing Ice Cream
- Won't Dispense Water
- Makes Humming Noise
- Has Freezer Leaking Water Into Fridge
- Ice Maker Making Hollow, Small, or Mushy Ice Cubes
- Ice Maker Making Cloudy Ice Cubes
Describe your problem in your own words
