iMac Intel 21.5" (2012-2015) Adhesive Strips
$19.95
$19.95
We'll send a message when the product is back in stock.
Product Details
Features
Features
Adhesive Strips for Every Repair
  • This complete set of replacement adhesive strips are specifically cut to fit 21.5" iMacs from Late 2012 through Late 2015.
  • The individual adhesive strips are labeled to indicate their correct location as shown in the replacement guides.
  • The kit includes one iMac Opening Tool.
  • Because of continuing improvements, actual product may differ slightly from photo.
The unique design of the 21.5" iMac requires the replacement of the adhesive strips whenever the display assembly is removed. Fortunately, these adhesive strips are actually a foam tape, easily cut with an iMac Opening Wheel. Unfortunately, the display has to be removed every time anything needs to be replaced or upgraded inside the machine.
Compatibility
iMac Intel 21.5" EMC 2544
2.7 GHz (Core i5, Late 2012)
2.9 GHz (Core i5, Late 2012)
3.1 GHz (Core i7, Late 2012)
iMac Intel 21.5" EMC 2638
2.7 GHz (Core i5, Late 2013)
2.9 GHz (Core i5, Late 2013)
3.1 GHz (Core i7, Late 2013)
iMac Intel 21.5" EMC 2805
1.4 GHz (Core i5, Mid 2014)
iMac Intel 21.5" EMC 2889
1.6 GHz (Core i5, Late 2015)
2.8 GHz (Core i5, Late 2015)
iMac Intel 21.5" Retina 4K Display
3.1 GHz (Core i5, Late 2015)
3.3 GHz (Core i7, Late 2015)
Show 2 more devices
Repair Stories
User avatar
My Problem
Hard drive went bad.
My Fix
Repair was easier than expected. Tool included with Adhesive strips made the job super easy!
My Advice
Be careful when placing the screen/monitor back in place. The adhesive strips aren't very forgiving. When I put the monitor back in place according to the instructions it still left a smal . . .
User avatar
My Problem
The entry level IMac 21,5 4K Late 2015 has an HORRENDOUSLY SLOW 1TB 5400 RPM hard drive, that made the whole experience of using the computer, an absolute pain. We got this computer as a replacement for a white polycarbonate Macbook, that turned out to be running a lot faster than the new computer . . .
User avatar
My Problem
I wanted to upgrade the sluggish 2.5" 5400 RPM platter drive with a new Samsung EVO 850 SSD, While I was in there, I figured I'd double the 8GB of RAM to 16GB.
My Fix
Success! This guide is spot-on! I was able to follow each step in detail and safely open my iMac without any issues. The repair kit from . . .
User avatar
My Problem
Needed to replace the RAM and Hard drive on a late 2013 iMac - a device rated as "get a professional" due to the sealed nature of the iMac.
My Fix
Wonderful. Thee tool to seep rate the iMac display from its back is nothing short of revolutionary. The "pizza cutter" is light years ahead of the "guitar pick . . .
User avatar
User avatar
My Problem
My Late 2012 21.5" iMac had been performing like a dog lately - the 5400rpm laptop hard drive in there is terribly slow. We didn't get the Fusion Drive model. I had upgraded Macbook Pro's to SSD's before, so I figured why not upgrade the iMac.
My Fix
The repair was actually easier than first expected. It . . .
User avatar
User avatar
User avatar
My Problem
I wanted to upgrade my RAM and internal storage and make the process easy to do again without Adhesive Strips!
My Fix
The repair went very, very well. Now my iMac is designed like Apple should have made them, not all glued together.
My Advice
Take your time and carefully think it over. Especially the placement of the . . .
User avatar
My Problem
Replaced the hard drive.
My Fix
Despite the lengthy instructions the job was actually much easier than the old iMac with the glass that was held in with magnets. The adhesive strip kit came with the cutting tool that makes the job very easy.
My Advice
Definitely use the tape to hold the screen in place once you line i . . .
Show more
