Introduction
iPhone batteries degrade with use—over time, they lose their ability to hold a full charge. Apple's batteries are rated to hold 80% of their capacity for up to 500 charge cycles, which lasts roughly 18-24 months for most users. When your battery's chemistry is degraded, it may also cause your iPhone to run more slowly. Use this guide to replace your battery and restore your iPhone to full performance.
If your battery is swollen, take appropriate precautions.
This guide instructs you to completely detach the display and remove the lower speaker and Taptic Engine for better access to the battery's adhesive strips.
For optimal performance, after completing this guide, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least two more hours. Then use your iPhone until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
Power off your iPhone before beginning disassembly.
Remove the two 6.7 mm-long pentalobe screws at the bottom edge of the iPhone.
Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
Tool used on this step:Clampy - Anti-Clamp$24.95
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Slide the arms over either the left or right edge of your iPhone.
Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
Squeeze the cups together to apply suction to the desired area.
Pull the blue handle forward to lock the arms.
Turn the handle clockwise 360 degrees or until the cups start to stretch.
Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
Heat an iOpener and thread it through the arms of the Anti-Clamp.
Fold the iOpener so it lays on the bottom edge of the iPhone.
Wait one minute to give the adhesive a chance to release and present an opening gap.
Insert an opening pick under the screen and the plastic bezel, not the screen itself.
Skip the next three steps.
Use a hairdryer or heat gun, or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute in order to soften up the adhesive underneath.
If you're using a single suction handle, apply it to the bottom edge of the phone, while avoiding the curved portion of the glass.
Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
Slide the opening pick around the lower left corner and up the left edge of the iPhone, slicing through the adhesive holding the display in place.
Re-insert your pick at the bottom edge of the iPhone, and slide it up the right side to continue separating the adhesive.
Slide the opening pick around the top corner of the display, while gently pulling or wiggling the display down in the direction of the Lightning port.
Slide the pick to the opposite corner and cut any remaining adhesive securing the display.
Open the iPhone by swinging the display up from the left side, like the back cover of a book.
Lean the display against something to keep it propped up while you're working on the phone.
Tool used on this step:Magnetic Project Mat$19.95
Remove three 1.2 mm Y000 screws securing the battery connector cover bracket.
Remove the bracket.
Use the point of a spudger to pry the battery connector straight up out of its socket.
Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
Remove the two 1.2 mm Y000 screws securing the display connector bracket.
Remove the bracket.
Use the tip of a spudger to pry up and disconnect the digitizer cable.
Remove the five screws securing the logic board connector bracket to the rear case:
One 1.3 mm Phillips #000 screw
One 1.5 mm Phillips #000 screw
Three 1.2 mm Y000 screws
Remove the bracket.
Use the tip of a spudger to pry the front sensor assembly connector up from its socket.
Remove the seven screws securing the bracket below the Taptic engine and speaker:
Three Phillips 1.4 mm screws
Two Phillips 1.7 mm screws
One Phillips 1.9 mm screw
One Phillips 1.6 mm screw
Lift the bracket from the edge nearest the battery. Don't try to fully remove it, as it's still connected via a small flex cable.
While holding the bracket out of the way, use the point of a spudger to pry up and disconnect the flex cable underneath.
Remove the piece of black tape and the small rubber rectangle covering the Taptic Engine connector cover.
Remove the small bracket on the top right corner of the speaker.
Remove the Taptic Engine connector cover.
Insert a spudger under the top edge of the speaker near the edge of the iPhone's case.
Gently pry up and lift the top edge of the speaker.
Hold the speaker by its side edges and rock it side-to-side, separating the adhesive securing it to the bottom edge of the iPhone.
Pull the speaker away from the bottom edge of the iPhone until the adhesive gasket separates.
Use a spudger to disconnect the Taptic Engine flex cable by prying it straight up from its socket.
Each piece of adhesive has a black pull-tab at the end, which is lightly adhered to the side edge of the battery.
Slowly pull one battery adhesive tab away from the battery, towards the bottom of the iPhone.
Pull steadily, maintaining constant tension on the strip until it slips out from between the battery and the rear case. For best results, pull the strip at as low an angle as possible, without snagging it on any of the iPhone's other components.
If the battery adhesive tabs break during the removal process, use your fingers or blunt tweezers to retrieve the remaining length of adhesive, and continue pulling.
Repeat the above steps to remove the remaining three adhesive strips.
If you removed all of the adhesive strips successfully, skip the next step.
If any of the adhesive strips broke off and the battery remains stuck to the rear case, prepare an iOpener or use a hair dryer to heat the rear case directly behind the battery. This will help soften the adhesive.
Flip the iPhone back over and thread a strong piece of string (such as dental floss or a length of thin guitar string) underneath the battery.
Pull the string from side to side in a sawing motion all along the length of the battery to separate the adhesive. This can take some time since the adhesive is slow to deform, but with patience it will come free. Do not deform or damage the battery.
