iPhone 12 mini Battery Replacement
  1. iPhone 12 mini Battery Replacement, Remove the pentalobe screws: step 1, image 1 of 2 iPhone 12 mini Battery Replacement, Remove the pentalobe screws: step 1, image 2 of 2
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.7 mm-long pentalobe screws at the bottom edge of the iPhone.
    Ask FixBot
  2. iPhone 12 mini Battery Replacement, Mark your opening picks: step 2, image 1 of 3 iPhone 12 mini Battery Replacement, Mark your opening picks: step 2, image 2 of 3 iPhone 12 mini Battery Replacement, Mark your opening picks: step 2, image 3 of 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Ask FixBot
  3. iPhone 12 mini Battery Replacement, Tape over any cracks: step 3, image 1 of 3 iPhone 12 mini Battery Replacement, Tape over any cracks: step 3, image 2 of 3 iPhone 12 mini Battery Replacement, Tape over any cracks: step 3, image 3 of 3
    • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
    • If all else fails, you can superglue the suction cup to the screen.
    Ask FixBot
  4. iPhone 12 mini Battery Replacement, Anti-Clamp instructions: step 4, image 1 of 3 iPhone 12 mini Battery Replacement, Anti-Clamp instructions: step 4, image 2 of 3 iPhone 12 mini Battery Replacement, Anti-Clamp instructions: step 4, image 3 of 3
    Tool used on this step:
    Clampy - Anti-Clamp
    $24.95
    Buy
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
    Ask FixBot
  5. iPhone 12 mini Battery Replacement: step 5, image 1 of 3 iPhone 12 mini Battery Replacement: step 5, image 2 of 3 iPhone 12 mini Battery Replacement: step 5, image 3 of 3
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    Ask FixBot
  6. iPhone 12 mini Battery Replacement: step 6, image 1 of 3 iPhone 12 mini Battery Replacement: step 6, image 2 of 3 iPhone 12 mini Battery Replacement: step 6, image 3 of 3
    • Support your iPhone on something sturdy such as a hardcover book so it rests hands-free and parallel to the ground; this makes it easier to work with in the following steps.
    • Use a hair dryer to heat along the bottom edge of the iPhone. The screen should feel slightly too hot to touch.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen's plastic bezel when the Anti-Clamp creates a large enough gap.
    • Make sure the opening pick is placed properly between the plastic bezel and the frame to avoid damaging your screen.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
    Ask FixBot
  7. iPhone 12 mini Battery Replacement, Heat the bottom half of the phone: step 7, image 1 of 1
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
    • Heating the bottom half of the iPhone helps soften the adhesive securing the display, making it easier to open.
    • Use a hair dryer or a heat gun to heat the bottom half of the iPhone until the screen is slightly too hot to touch.
    • For best practices on using a hair dryer to soften adhesive, check out this guide. For warnings on heat gun use, check out this guide.
    • To prevent screen damage, keep your heat source moving rather than focused on one spot.
    • If you have trouble during the opening procedure, the adhesive most likely cooled down. Apply more heat to further soften the adhesive.
    Ask FixBot
  8. iPhone 12 mini Battery Replacement, Apply a suction handle: step 8, image 1 of 2 iPhone 12 mini Battery Replacement, Apply a suction handle: step 8, image 2 of 2
    • If you're using a single suction handle, apply it to the bottom edge of the phone, as close to the edge as possible.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    Ask FixBot
  9. iPhone 12 mini Battery Replacement, Lift the screen slightly: step 9, image 1 of 3 iPhone 12 mini Battery Replacement, Lift the screen slightly: step 9, image 2 of 3 iPhone 12 mini Battery Replacement, Lift the screen slightly: step 9, image 3 of 3
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the metal frame.
    • A plastic bezel is secured to the underside of the display, and needs to lift up with the display. Inserting a pick between the bezel and the display will damage the panel.
    • Insert an opening pick into the gap under the screen and the plastic bezel, not the screen itself.
    • Make sure to insert the opening pick under the thick plastic bezel to avoid damaging your screen. You should see a visual gap, and the pick shouldn't catch on anything. If you can't see the gap, you'll need to pull the screen up more.
    • The watertight adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
    Ask FixBot
  10. iPhone 12 mini Battery Replacement, Separate the bottom edge adhesive: step 10, image 1 of 3 iPhone 12 mini Battery Replacement, Separate the bottom edge adhesive: step 10, image 2 of 3 iPhone 12 mini Battery Replacement, Separate the bottom edge adhesive: step 10, image 3 of 3
    • Don't insert your opening pick deeper than 3 mm along the bottom edge.
    • Slide your pick back and forth along the bottom edge to separate the adhesive.
    • Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
    Ask FixBot
  11. iPhone 12 mini Battery Replacement, Heat the right edge: step 11, image 1 of 2 iPhone 12 mini Battery Replacement, Heat the right edge: step 11, image 2 of 2
    • Use a hair dryer to heat the right edge of the iPhone (the edge with the power button) until the screen is slightly too hot to touch.
    Ask FixBot
  12. iPhone 12 mini Battery Replacement, Separate the screen adhesive: step 12, image 1 of 3 iPhone 12 mini Battery Replacement, Separate the screen adhesive: step 12, image 2 of 3 iPhone 12 mini Battery Replacement, Separate the screen adhesive: step 12, image 3 of 3
    • Slide the opening pick around the bottom right corner and along the right edge of the iPhone, slicing through the adhesive holding the display in place.
    • Don't insert your pick more than 3 mm, as you may damage internal components.
    Ask FixBot
  13. iPhone 12 mini Battery Replacement, Heat the top half: step 13, image 1 of 1
    • Use a hair dryer to heat the top half of the iPhone until the screen is slightly too hot to touch.
    Ask FixBot
  14. iPhone 12 mini Battery Replacement: step 14, image 1 of 3 iPhone 12 mini Battery Replacement: step 14, image 2 of 3 iPhone 12 mini Battery Replacement: step 14, image 3 of 3
    • The top edge of the display is secured with both glue and clips.
    • Insert your pick underneath the top-right corner of the display panel.
    • Slide the pick around the top right corner. Because of the clips you might encounter some resistance.
    • Don't insert your pick more than 3 mm, as you may damage the front panel sensor array.
    • Gently pulling the front panel assembly towards the bottom edge of the phone simplifies this step a little.
    • Slide the pick along the top edge and cut any remaining adhesive securing the display.
    Ask FixBot
  15. iPhone 12 mini Battery Replacement, Heat the left edge: step 15, image 1 of 2 iPhone 12 mini Battery Replacement, Heat the left edge: step 15, image 2 of 2
    • Use a hair dryer to heat the left edge of the iPhone until the screen is slightly too hot to touch.
    Ask FixBot
  16. iPhone 12 mini Battery Replacement, Separate the left edge adhesive: step 16, image 1 of 3 iPhone 12 mini Battery Replacement, Separate the left edge adhesive: step 16, image 2 of 3 iPhone 12 mini Battery Replacement, Separate the left edge adhesive: step 16, image 3 of 3
    • Don't insert your pick deeper than 2 mm along the left edge to avoid the two cables connecting the screen to the phone.
    • Rotate your pick around the top left corner of the screen.
    • Slide your pick down the left edge of the screen to separate the adhesive.
    • If you're having trouble separating the adhesive, reheat the left edge.
    Ask FixBot
  17. iPhone 12 mini Battery Replacement, Open the iPhone: step 17, image 1 of 3 iPhone 12 mini Battery Replacement, Open the iPhone: step 17, image 2 of 3 iPhone 12 mini Battery Replacement, Open the iPhone: step 17, image 3 of 3
    • Rotate your iPhone so the right edge faces you.
    • Open the iPhone by swinging the display up from the right side, like the front cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
    • During reassembly, lay the display in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the display down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the display and make sure they aren't bent.
    Ask FixBot
  18. iPhone 12 mini Battery Replacement, Unscrew the battery and display connector cover: step 18, image 1 of 2 iPhone 12 mini Battery Replacement, Unscrew the battery and display connector cover: step 18, image 2 of 2
    Magnetic Project Mat
    $19.95
    Buy
    • Remove the 1.25 mm-long Y000 screw securing the battery & display connector cover bracket.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
    Ask FixBot
  19. iPhone 12 mini Battery Replacement, Remove the battery and display connector cover: step 19, image 1 of 2 iPhone 12 mini Battery Replacement, Remove the battery and display connector cover: step 19, image 2 of 2
    Buy
    • Use a pair of tweezers to remove the battery & display connector bracket.
    • There are two little hinges on the right edge of the connector bracket. Make sure to align them with their counterparts during reassembly.
    Ask FixBot
  20. iPhone 12 mini Battery Replacement, Disconnect the battery: step 20, image 1 of 2 iPhone 12 mini Battery Replacement, Disconnect the battery: step 20, image 2 of 2
    • Use a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
    Ask FixBot
  21. iPhone 12 mini Battery Replacement, Disconnect the OLED display cable: step 21, image 1 of 2 iPhone 12 mini Battery Replacement, Disconnect the OLED display cable: step 21, image 2 of 2
    • Use a spudger or a clean fingernail to pry the OLED panel cable connector up from its socket on the logic board.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    Ask FixBot
  22. iPhone 12 mini Battery Replacement, Unscrew the front sensor assembly cover: step 22, image 1 of 2 iPhone 12 mini Battery Replacement, Unscrew the front sensor assembly cover: step 22, image 2 of 2
    • Remove the five 1 mm-long Y000 screws securing the front sensor assembly cover bracket.
    Ask FixBot
  23. iPhone 12 mini Battery Replacement: step 23, image 1 of 2 iPhone 12 mini Battery Replacement: step 23, image 2 of 2
    • Use a pair of tweezers to remove the front sensor assembly bracket.
    Ask FixBot
  24. iPhone 12 mini Battery Replacement, Disconnect the front sensors: step 24, image 1 of 2 iPhone 12 mini Battery Replacement, Disconnect the front sensors: step 24, image 2 of 2
    • Use a spudger or a clean fingernail to disconnect the front sensor assembly cable connector.
    Ask FixBot
  25. iPhone 12 mini Battery Replacement, Remove the display assembly: step 25, image 1 of 1
    Ask FixBot
  26. iPhone 12 mini Battery Replacement, Unscrew the speaker: step 26, image 1 of 2 iPhone 12 mini Battery Replacement, Unscrew the speaker: step 26, image 2 of 2
    • Remove the four 1.5 mm-long Phillips #000 screws securing the speaker.
    Ask FixBot
  27. iPhone 12 mini Battery Replacement, Remove the speaker: step 27, image 1 of 2 iPhone 12 mini Battery Replacement, Remove the speaker: step 27, image 2 of 2
    Buy
    • Use a pair of tweezers to remove the speaker.
    Ask FixBot
  28. iPhone 12 mini Battery Replacement, Remove the adhesive strips: step 28, image 1 of 2 iPhone 12 mini Battery Replacement, Remove the adhesive strips: step 28, image 2 of 2
    • Peel down the first battery adhesive pull-tab to un-stick it from the bottom edge of the battery.
    • Don't jab the battery with any sharp tools. A punctured battery may leak dangerous chemicals or catch fire.
    Ask FixBot
  29. iPhone 12 mini Battery Replacement: step 29, image 1 of 3 iPhone 12 mini Battery Replacement: step 29, image 2 of 3 iPhone 12 mini Battery Replacement: step 29, image 3 of 3
    Buy
    • Grab the pull tab with your fingers and slowly pull it away from the battery, toward the bottom of the iPhone.
    • Pull hard enough to maintain tension on the strip, but don't force it. Give it plenty of time to stretch and un-stick from under the battery.
    • Don't press down on the battery. Hold the iPhone firmly by its sides.
    • Keep the strip flat and unwrinkled. Try to pull evenly on the whole strip, rather than pulling mainly in the middle or on one side.
    • Pull at a low angle so the strip doesn't snag on the edge of the battery.
    • If the adhesive strip breaks off, try to retrieve it using your fingers or blunt tweezers, and continue pulling—but do not pry under the battery.
    • If any of the adhesive strips break off underneath the battery and can't be retrieved, try to remove the other strips, and then proceed as instructed below.
    Ask FixBot
  30. iPhone 12 mini Battery Replacement: step 30, image 1 of 2 iPhone 12 mini Battery Replacement: step 30, image 2 of 2
    • Grab the wide pull tab with your fingers and slowly pull it away from the battery, toward the bottom of the iPhone.
    Ask FixBot
  31. iPhone 12 mini Battery Replacement: step 31, image 1 of 3 iPhone 12 mini Battery Replacement: step 31, image 2 of 3 iPhone 12 mini Battery Replacement: step 31, image 3 of 3
    Ask FixBot
  32. iPhone 12 mini Battery Replacement: step 32, image 1 of 3 iPhone 12 mini Battery Replacement: step 32, image 2 of 3 iPhone 12 mini Battery Replacement: step 32, image 3 of 3
    • Peel up the two remaining battery adhesive pull-tabs to unstick them from the top edge of the battery.
    Ask FixBot
  33. iPhone 12 mini Battery Replacement: step 33, image 1 of 3 iPhone 12 mini Battery Replacement: step 33, image 2 of 3 iPhone 12 mini Battery Replacement: step 33, image 3 of 3
    • Using the same procedure as before, pull the remaining two tabs, one at a time, to stretch and remove the remaining adhesive strip holding the battery in place. Try not to snag the adhesive on anything.
    • Be careful not to fling the battery from the iPhone as the final adhesive strip comes out.
    • If you removed all the adhesive strips successfully, skip the next step.
    • Otherwise, continue to the next step.
    Ask FixBot
  34. iPhone 12 mini Battery Replacement, How to remove a stuck battery: step 34, image 1 of 2 iPhone 12 mini Battery Replacement, How to remove a stuck battery: step 34, image 2 of 2
    • If you're still having trouble removing the battery, apply a few drops of high concentration (over 90%) isopropyl alcohol under the edge of the battery in the area of the broken adhesive strip(s).
    • Wait about one minute for the alcohol solution to weaken the adhesive.
    • Use an opening pick or the flat end of a spudger to gently lift the battery.
    • Don't try to forcefully lever the battery out. If needed, apply a few more drops of alcohol to further weaken the adhesive. Never deform or puncture the battery with your pry tool.
    Ask FixBot
  35. iPhone 12 mini Battery Replacement, Remove the battery: step 35, image 1 of 2 iPhone 12 mini Battery Replacement, Remove the battery: step 35, image 2 of 2
    • Remove the battery.
    • If there's any alcohol solution remaining in the phone, carefully wipe it off or allow it to air dry before installing your new battery.
    • Use this guide to install new battery adhesive strips.
    • Perform a force restart after reassembly. This can prevent several issues and simplify troubleshooting.
    Ask FixBot
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
To reassemble your device, follow the above steps in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
After your repair, depending on the replacement part, you may be able to calibrate it using Apple's Repair Assistant, available as of iOS 18. Update your device, navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 12 mini Answers community for help.
112 other people completed this guide.
Dominik Schnabelrauch
259,949 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
122 Members
26,572 Guides authored
28 Guide Comments
If you replace the battery (even with a first party one) you will need to go to Apple, unfortunately, as is for the new iPhone 13 models.
Roman - Reply Share
Since iOS 17, I believe, they have a self-registering mechanism. OS will start a wizard to register replaced first-party battery without going to the store
rbhbokka - Reply Share
I don't think it's stated clearly enough that the display adhesive is VERY strong and you might think you've gotton a big enough gap when sticking in a pick will actually separate the layers of the screen and break it (defintely not speaking from experience). Make sure the phone is totally, thoroughly heated and be very, very careful.
Wesley Halliwell - Reply Share
+1
Tried it without the clamp for two hours and couldn‘t get it open. With clamp, it was opened within 30 minutes.
Overall battery replacement worked well, the instructions were clear enough to follow along. Would do this again… but with the clamp. ;)
schmurian - Reply Share
same pried in between layer and then realized after after i separated the bottom corners that needed to go deeper
Simon Milburn - Reply Share
Past 24 Hours: 348
Past 7 Days: 2,160
Past 30 Days: 7,831
All Time: 479,259
