Google Pixel 6 Pro Screen Replacement
  1. Google Pixel 6 Pro Screen Replacement, Safety precautions: step 1, image 1 of 2 Google Pixel 6 Pro Screen Replacement, Safety precautions: step 1, image 2 of 2
    • Allow your battery to drain below 25% before starting this repair. A charged battery may catch fire if damaged.
    • Fully power off your phone and unplug any cables.
    Ask FixBot
  2. Google Pixel 6 Pro Screen Replacement, Anti-Clamp instructions: step 2, image 1 of 3 Google Pixel 6 Pro Screen Replacement, Anti-Clamp instructions: step 2, image 2 of 3 Google Pixel 6 Pro Screen Replacement, Anti-Clamp instructions: step 2, image 3 of 3
    Tool used on this step:
    Clampy - Anti-Clamp
    $24.95
    Buy
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • If your screen is cracked, cover it with a layer of clear packing tape to help the suction cup adhere.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your phone.
    • Position the suction cups near the bottom edge of the phone—one on the front, and one on the back.
    • Squeeze the cups together to apply suction.
    • If you find that the surface of your phone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
    Ask FixBot
  3. Google Pixel 6 Pro Screen Replacement: step 3, image 1 of 3 Google Pixel 6 Pro Screen Replacement: step 3, image 2 of 3 Google Pixel 6 Pro Screen Replacement: step 3, image 3 of 3
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    Ask FixBot
  4. Google Pixel 6 Pro Screen Replacement: step 4, image 1 of 3 Google Pixel 6 Pro Screen Replacement: step 4, image 2 of 3 Google Pixel 6 Pro Screen Replacement: step 4, image 3 of 3
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer or heat gun—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the phone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen frame when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next two steps.
    Ask FixBot
  5. Google Pixel 6 Pro Screen Replacement, Loosen the display adhesive: step 5, image 1 of 1
    • Apply a heated iOpener to the screen to loosen the adhesive underneath. Apply the iOpener for at least 3 minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
    Ask FixBot
  6. Google Pixel 6 Pro Screen Replacement, Insert an opening pick: step 6, image 1 of 3 Google Pixel 6 Pro Screen Replacement, Insert an opening pick: step 6, image 2 of 3 Google Pixel 6 Pro Screen Replacement, Insert an opening pick: step 6, image 3 of 3
    • Once the screen is warm to the touch, apply a suction handle to the bottom edge of the screen.
    • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction handle to adhere. Alternatively, very strong tape may be used instead of the suction handle. If all else fails, you can superglue the suction handle to the screen.
    • Lift the screen including its safety frame with the suction handle to create a small gap between the screen and the phone assembly.
    • Insert an opening pick into the gap between the screen frame and the phone assembly.
    • Make sure to insert your opening pick in the right position to avoid separating the screen from its safety frame instead of the phone assembly.
    • Slide the opening pick to the bottom left corner of the screen to slice its adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
    Ask FixBot
  7. Google Pixel 6 Pro Screen Replacement, Slice the adhesive: step 7, image 1 of 2 Google Pixel 6 Pro Screen Replacement, Slice the adhesive: step 7, image 2 of 2
    • Insert a second opening pick at the bottom edge and slide it to the bottom right corner of the screen to slice the adhesive.
    Ask FixBot
  8. Google Pixel 6 Pro Screen Replacement: step 8, image 1 of 3 Google Pixel 6 Pro Screen Replacement: step 8, image 2 of 3 Google Pixel 6 Pro Screen Replacement: step 8, image 3 of 3
    • The screen of the Google Pixel 6 Pro is not only held in place by adhesive but also small plastic pins. In case your opening pick gets blocked during the screen removal procedure it means you inserted your pick too deep underneath the screen. Only insert the tip of the opening pick (~3-4 mm) when slicing the display adhesive.
    • Insert a third opening pick underneath the bottom left corner of the screen.
    • Slide the opening pick along the left edge of the screen to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
    Ask FixBot
  9. Google Pixel 6 Pro Screen Replacement: step 9, image 1 of 2 Google Pixel 6 Pro Screen Replacement: step 9, image 2 of 2
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener or heat gun for 1-2 minutes to reheat it.
    • When you slice near the front facing camera, insert only the tip of the opening pick (~2-3 mm) to avoid damaging or smearing the camera.
    • Insert a fourth opening pick at the top left corner of the screen.
    • Slide the opening pick along the top edge of the phone to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
    Ask FixBot
  10. Google Pixel 6 Pro Screen Replacement: step 10, image 1 of 2 Google Pixel 6 Pro Screen Replacement: step 10, image 2 of 2
    • Insert a fifth opening pick and slide it along the right edge of the phone to slice the remaining adhesive.
    • Do not try to remove the display all the way yet, the screen is still connected to the phone assembly.
    Ask FixBot
  11. Google Pixel 6 Pro Screen Replacement, Open up the phone assembly: step 11, image 1 of 3 Google Pixel 6 Pro Screen Replacement, Open up the phone assembly: step 11, image 2 of 3 Google Pixel 6 Pro Screen Replacement, Open up the phone assembly: step 11, image 3 of 3
    • Avoid straining the display cable during the following procedure.
    • Carefully fold the screen to the left side of the phone assembly like you would open the front cover of a book.
    Ask FixBot
  12. Google Pixel 6 Pro Screen Replacement, Unfasten the display bracket screw: step 12, image 1 of 1
    Magnetic Project Mat
    $19.95
    Buy
    • While the Pixel 6 Pro uses Torx Plus screws, standard Torx bits work. Make sure to apply constant, downward force to prevent stripping.
    • Use a Torx T3 screwdriver to remove the 2.0 mm-long 3IP Torx Plus screw securing the display cable metal bracket.
    Ask FixBot
  13. Google Pixel 6 Pro Screen Replacement, Remove the display cable bracket: step 13, image 1 of 2 Google Pixel 6 Pro Screen Replacement, Remove the display cable bracket: step 13, image 2 of 2
    Buy
    • Use a pair of tweezers to remove the metal bracket sitting on top of the display cable connector.
    • Make sure to keep this component to reinstall it during reassembly.
    Ask FixBot
  14. Google Pixel 6 Pro Screen Replacement, Disconnect the display cable: step 14, image 1 of 2 Google Pixel 6 Pro Screen Replacement, Disconnect the display cable: step 14, image 2 of 2
    • Use a spudger to disconnect the display flex cable by prying the connector straight up from its socket.
    Ask FixBot
  15. Google Pixel 6 Pro Screen Replacement, Screen information: step 15, image 1 of 1
    • The back of the Pixel's screen is very fragile. Even a small scratch or dent can damage the screen.
    • To prevent damaging your screen or replacement screen:
    • When handling your screen, grip it by its edges.
    • When placing the screen on your work area, make sure nothing is touching the bottom of the screen. Consider placing it on a soft, lint-free cloth.
    Ask FixBot
  16. Google Pixel 6 Pro Screen Replacement, Remove the screen: step 16, image 1 of 2 Google Pixel 6 Pro Screen Replacement, Remove the screen: step 16, image 2 of 2
    • Remove the screen.
    • During reassembly:
    • If you replaced the screen, check the screen's front-facing camera hole and sensor cutout for any protective liners. Remove these liners before you close the phone up.
    • Remember to reinstall the display cable bracket.
    • This is a good point to test your phone before sealing it up. Temporarily connect your screen, power on your phone, and make sure it works as expected. Before continuing with reassembly, power off your phone and disconnect the screen.
    • Follow this guide if you're using custom-cut adhesives for your device.
    • Follow this guide in case you're using a pre-cut adhesive card.
    • If you're installing a new screen, follow this guide to calibrate the fingerprint sensor.
    Ask FixBot
If possible, turn on your device and test your repair before installing new adhesive and resealing.
The best way to secure the new screen is to apply a sheet of custom-cut double-sided tape to the back of the screen.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
119 other people completed this guide.
Dominik Schnabelrauch
261,711 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
123 Members
31,535 Guides authored
66 Guide Comments
Est-ce possible de changer que e verre brisé
Leroy - Reply Share
Really wish this had instructions on how to put the screen back on. "reverse order" is not accurate.
Ed Word - Reply Share
The fingerprint scanner doesn't work. I get a message that I need to visit, but the website doesn't exist. Google has a fingerprint repair tool where you connect your phone and boot into rescue mode, but the program says I can't use it as my phone's firmware is newer than the tool's firmware.
Do a google search to see, there are many others with this issue and a few Google support threads where google acknowledged the issue for over two years but doesn't address the issue other than to say it should be fixed in the future firmware update.
So, now I'm stuck without a fingerprint scanner that I used for all security and banking apps.
kimsballs - Reply Share
Did you transfer your existing fingerprint scanner from your original screen to the new one ?
Alan Sears - Reply Share
See my note below; I found a solution for this.
Matt Montero - Reply Share
Past 24 Hours: 41
Past 7 Days: 329
Past 30 Days: 1,727
All Time: 224,381
