Roborock Q5 Max Plus Battery Replacement
    1. Roborock Q5 Max Plus Battery Replacement, Side Brush: step 1, image 1 of 2 Roborock Q5 Max Plus Battery Replacement, Side Brush: step 1, image 2 of 2
      • Carefully flip the Roborock upside down on a soft surface (e.g., towel) to avoid scratches.
      • Turn off the vacuum using the main switch underneath.
      Ask FixBot
    2. Roborock Q5 Max Plus Battery Replacement: step 2, image 1 of 3 Roborock Q5 Max Plus Battery Replacement: step 2, image 2 of 3 Roborock Q5 Max Plus Battery Replacement: step 2, image 3 of 3
      • Hold down the side brush with one hand to prevent it from moving.
      • Use a Phillips #1 screwdriver to remove the single screw securing the side brush.
      • Remove it from the base.
      Ask FixBot
    1. Roborock Q5 Max Plus Battery Replacement, Bottom Panel: step 3, image 1 of 2 Roborock Q5 Max Plus Battery Replacement, Bottom Panel: step 3, image 2 of 2
      • Use a Phillips #1 screwdriver to remove the eight 14 mm screws that secure the bottom shell.
      Ask FixBot
    2. Roborock Q5 Max Plus Battery Replacement: step 4, image 1 of 1
      • Gently lift the the bottom shell up and off.
      • If you encounter resistance, double-check for any hidden screws that may have been overlooked.
      Ask FixBot
    1. Roborock Q5 Max Plus Battery Replacement, Battery: step 5, image 1 of 3 Roborock Q5 Max Plus Battery Replacement, Battery: step 5, image 2 of 3 Roborock Q5 Max Plus Battery Replacement, Battery: step 5, image 3 of 3
      • Carefully pry out the battery and remove it from its housing.
      • Don't fully remove it as its still connected to the vacuum.
      Ask FixBot
    2. Roborock Q5 Max Plus Battery Replacement: step 6, image 1 of 3 Roborock Q5 Max Plus Battery Replacement: step 6, image 2 of 3 Roborock Q5 Max Plus Battery Replacement: step 6, image 3 of 3
      • Carefully press on the side tab of the connector to release the latch, then pull the connector straight up and out of its port.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 22
Past 30 Days: 82
All Time: 748
