Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
418 Questions View all
Replaced LCD screen, now no boot!
I hope someone can give me some suggestions. I cracked the LCD screen on my MacBook and decided to replace it myself. After following the step-by-step directions on a different website (http://www.PowerBookmedic.com/manual.php...), I got everything put back together and now the machine won't boot.
When I press the power button, the power light on the front near the IR sensor comes on, and the screen flashes (as my old one did), but there's no noise from the optical drive and nothing else happens.
I'm going to take it apart again tomorrow and follow the directions on this site. - I'm hoping it's simply a cord that isn't fully connecting. Since the machine was working fine this morning (just with a cracked screen) it doesn't make sense to me for it to be anything serious like the logic board. Any ideas?
Score -1
1 Comment
You say <<When I press the power button, the power light on the front near the IR sensor comes on, and the screen flashes (as my old one did)>> then you say << Since the machine was working fine this morning (just with a cracked screen) >>. So what was the machine stattus before you replaced the screen ? Also, was the machine dropped ? Any damage to the hinges ? When you replaced the LCD did you take off the display from the machine or simply removed the LCD with the display still attached to the machine ?
by
Add a comment
Chosen Solution
Plug it into an external monitor to isolate the problem to the display quadrant. You also may not be getting a full restart. Press the caps lock key to see if the machine is still on. If it is then press and hold the power button for 10 seconds.
Score 2
1 Comment:
good start +
by
Add a comment
Double check all connections
sometimes they "look" connected but are loose. Did you put all the proper screws in their correct old locations? The wrong length screw can short the board.
If this answer is acceptable please return and mark it.
Good Luck,
N.
Score 1
Add a comment
Add your answer
safronia will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,853
