Click Image To Zoom
256 GB Solid State Drive
$199.95
Product code: IF107-124
Product Overview
A 256 GB Solid State Drive with the tools needed to swap it in.
  • Super fast, SanDisk's top of the line X210 256 GB SSD.
  • Hard Drive enclosure used for transferring your files also converts your old drive into a handy external USB drive.
  • Don't get caught with the wrong equipment this kit has everything it takes to get into most laptops.
  • Use the free SuperDuper! to transfer your files with the enclosure.
Kit Contents:
Compatibility
  • All MacBooks and MacBook Pros (excluding MacBook Air and MacBook Pro Retina)
  • All Intel Mac minis
Product Details
  • Interface: SATA 6.0 Gb/s
  • Dimensions: 2.5" (69.85mm) wide x .27" (7mm) tall
  • Capacity: 256 GB Unformatted
  • Read: Up to 505 Mb/s
  • Write: Up to 470 Mb/s
$214.95 Upgrade Kit
Condition:
New
Warranty:
5-year manufacturer warranty
Notes:
This option contains the drive and kit components.
$199.95 Drive only
Condition:
New
Warranty:
Notes:
Sandisk X210
Model #: SD6SB2M-256G-1022I
Add to Cart »
Replacement Guides
Mac Mini Mid 2010
Difficulty: Moderate
Mac mini Model A1176
Mac mini Model A1283
MacBook Core 2 Duo
Difficulty: Easy
MacBook Core Duo
Difficulty: Easy
MacBook Pro 13" Unibody Mid 2009
MacBook Pro 13" Unibody Mid 2010
MacBook Pro 15" Unibody Mid 2009
MacBook Pro 15" Unibody Mid 2010
MacBook Pro 17" Unibody
MacBook Unibody Model A1278
Difficulty: Easy
MacBook Unibody Model A1342
PlayStation 3
PlayStation 3 Slim
Compatibility
Mac Mini Late 2012
2.3 GHz (Quad i7, Late 2012)
2.5 GHz (Dual i5, Late 2012)
2.6 GHz (Quad i7, Late 2012)
Mac Mini Mid 2011
2 GHz (Quad i7, Mid 2011)
2.3 GHz (Dual i5, Mid 2011)
2.5 GHz (Dual i5, Mid 2011)
2.7 GHz (Dual i7, Mid 2011)
1.5 GHz (Core Solo, A1176)
1.66 GHz (Core Duo, Early 2006)
1.66 GHz (Core Duo, Late 2006)
1.83 GHz (Core 2 Duo, Mid 2007)
1.83 GHz (Core Duo, Late 2006)
2 GHz (Core 2 Duo, A1176)
2 GHz (Core 2 Duo, A1283)
2.26 GHz (A1283)
2.53 GHz (A1283)
2.66 GHz (A1283)
Mac mini Model A1347
2.4 GHz (Core 2 Duo, Mid 2010)
2.66 GHz (Core 2 Duo, Mid 2010)
MacBook Core 2 Duo
1.83 GHz (Core 2 Duo)
2 GHz (C2D, Late 2006)
2 GHz (C2D, Mid 2007)
2 GHz (Early 2009)
2 GHz (Santa Rosa)
2.1 GHz (Penryn)
2.13 GHz (Mid 2009)
2.16 GHz (Core 2 Duo)
2.2 GHz (Santa Rosa)
2.4 GHz (Penryn)
MacBook Core Duo
1.83 GHz (Core Duo)
2 GHz (Core Duo)
MacBook Pro 13" Unibody Early 2011
2.3 GHz (Early 2011)
2.7 GHz (Early 2011)
MacBook Pro 13" Unibody Late 2011
2.4 GHz (Late 2011)
2.8 GHz (Late 2011)
2.26 GHz (Mid 2009)
2.53 GHz (Mid 2009)
2.4 GHz (Mid 2010)
2.66 GHz (Mid 2010)
MacBook Pro 13" Unibody Mid 2012
2.5 GHz (Mid 2012)
2.9 GHz (Mid 2012)
MacBook Pro 15" Core 2 Duo Model A1211
2.33 GHz (Core 2 Duo)
MacBook Pro 15" Core 2 Duo Models A1226 and A1260
2.4 GHz (Penryn)
2.4 GHz (Santa Rosa)
2.5 GHz (Penryn)
2.6 GHz (Penryn)
2.6 GHz (Santa Rosa)
MacBook Pro 15" Core Duo Model A1150
1.83 GHz (Core Duo)
2 GHz (Core Duo)
2.16 GHz (Core Duo)
MacBook Pro 15" Unibody 2.53 GHz Mid 2009
2.53 GHz (Mid 2009)
MacBook Pro 15" Unibody Early 2011
2 GHz (Early 2011)
2.2 GHz (Early 2011)
MacBook Pro 15" Unibody Late 2008 and Early 2009
2.4 GHz (Late 2008)
2.53 GHz (Late 2008)
2.66 GHz (Early 2009)
2.8 GHz (Late 2008)
2.93 GHz (Early 2009)
MacBook Pro 15" Unibody Late 2011
2.2 GHz (Late 2011)
2.4 GHz (Late 2011)
2.5 GHz (Late 2011)
2.66 GHz (Mid 2009)
2.8 GHz (Mid 2009)
3.06 GHz (Mid 2009)
2.4 GHz (Mid 2010)
2.53 GHz (Mid 2010)
2.66 GHz (Mid 2010)
2.8 GHz (Mid 2010)
MacBook Pro 15" Unibody Mid 2012
2.3 GHz (Mid 2012)
2.6 GHz (Mid 2012)
2.7 GHz (Mid 2012)
MacBook Pro 17" Models A1151 A1212 A1229 and A1261
2.16 GHz (Core Duo)
2.5 GHz (Penryn)
2.6 GHz (Penryn)
2.53 GHz (Mid 2010)
2.66 GHz (Mid 2010)
2.8 GHz (Mid 2009)
2.8 GHz (Mid 2010)
3.06 GHz (Mid 2009)
MacBook Pro 17" Unibody Early 2011
MacBook Pro 17" Unibody Late 2011
2.4 GHz (Late 2011)
2.5 GHz (Late 2011)
2 GHz (A1278)
2.4 GHz (A1278)
2.26 GHz (A1342)
2.4 GHz (A1342)
Stories
My Problem
I was looking for more space and extra speed. Plus my old drive was close to 5 years old and had a problem with the drive mapping. So I had to restore from backup.
My Fix
I did my homework so it seemed that I was prepared. The kit had everything in it that I needed. I used superduper to clone. Everything went well and the drive works great.
My Advice
Do your homework before you start, don't get in a hurry and in just a couple of hours it's all done.
My Problem
Couldn't run apps, forget flash and videos and even word processing...
5 year old macbook black was rheumatoid and exasperatingly slow
My Fix
New flash ssd
Doubled RAM
It's a new machine! Extra fast. Very very happy. Will use it for another 3-4 years I hope
My Advice
Online guides
My Problem
The stock HDD that came with my MacBook Pro was running a bit slow and consistently added a lot of heat inside the laptop, so I decided to switch it out for a 256 GB SSD from iFixit!
My Fix
It went perfectly! I followed the guide on iFixit's website and didn't have any problems!
I was incredibly nervous about using SuperDuper, but it ended up being very simple and straightforward. Took about an hour to clone my HDD and transfer it to my new SSD using the external drive kit.
The drive replacement took about 30 minutes, mainly because I was nervous and kept having to wipe the sweat off my hands. Taking out the screws on the battery and HDD were the toughest part. Those suckers are small! But I used the tool kit that came with my new SSD and eventually got it done.
All in all, however, it went very smoothly and was nearly stress-free! I highly recommend using guides from iFixit.
My Advice
The advice I would give to anybody wanting to try upgrading their computer hardware would be to just do it. I was almost going to spend $2,600 on a new MacBook Pro, but ended up doing my research and didn't even spend $400 on a solid state drive and brand up DDR3 RAM (admittedly got the RAM from Amazon...sorry iFixit team :P). My laptop runs better than it ever has and doesn't even come close to heating up as much as it did before I installed the upgrades.
Put simply: don't throw away a perfectly good laptop just because you want some new eye candy or because you don't think you're qualified to tweak your current system. It's a great learning experience and there's nothing more fulfilling than successfully booting up an old computer with brand new parts inside.
My Problem
DVD Drive was not used for ages, so time came to replace it with SSD. Prior to dual HDD, System 250 GB HDD was already upgraded to 640GB, but still MacBook was slow. So I added 250 GB SSD and installed OS X to that disk. Now MacBook is much faster.
I have changed Display assembly on my friends MacBook Pro too. Original one was broken. Now he have got brand new looking MacBook Pro )
My Fix
Installation went smoothly, I used tools which came with Dual HDD Kit. DVD rom connection cable is also working great! I will use it very rarely maybe to burn some DVDs only.
Changing the Display was even easier than installing Dual HDD. I just followed the instructions.
My Advice
Thanks IFixIt for easy instructions and Fast delivery of the ordered Items. It took me only 6 days to get all perts here in Saudi Arabia.
My Problem
I thought maybe the Sata cable was the problem so I replaced it and no change so I finally got the 256 SSD... whoa super fast! Now I'm thinking of adding 8gb memory cards.
My Fix
Easy to follow with the accessory tool kits and anti static mat. Took about 1 1/2 hours start to finish after loading the install discs,apps disc and upgrades. I can still use the old drive to access everything without any problems.
My Advice
Don't delay just do it! you'll be impressed! Feels like a new laptop!
My 13yo son knocked it out so easy!
I couldn't believe how easy it was!
