Shop the Holiday Gift Guide
Introduction
Safety First! Before you begin, remember that safety is paramount. Always unplug your appliance before attempting any repairs or diagnostics. This precaution is crucial to prevent electric shock or damage to your appliance.
Understanding Your Refrigerator: This guide covers various problems, from water inlet problems to ice maker issues or unexpected leaks. We’ve broken down each problem into three key sections:
- Problem: Identifies the specific issue you're experiencing.
- Why It Happens: Provides a brief explanation of potential causes.
- How to Fix: Offers step-by-step solutions to resolve the issue.
Ready to Solve the Issue? With this guide in hand, you're well-equipped to handle refrigerator repairs with ease. Let’s dive in and get your refrigerator running smoothly again!
Causes
The refrigerator has identified a problem with the sensor located in the back of the freezer compartment. The error is commonly caused by a separation between the sensor and the housing, a connection issue, a disconnected part, or a short circuit. The error may also trigger if the sensor detects a temperature higher than 149ºF (+65ºC) or less than -58ºF(-50ºC).
The Freezer Room Sensor is located in the Freezer compartment in the back upper right.
The refrigerator has identified a problem with the sensor in the fridge compartment of the unit. The error is commonly caused by a separation between the sensor and the housing, a connection issue, a disconnected part, or a short circuit.
The Fridge Room Sensor is located inside the refrigerator compartment behind the "Twin Cool" housing.
The refrigerator has identified a problem with the sensor in the freezer compartment of the unit. The error is commonly caused by a separation between the sensor and the housing, a connection issue, a disconnected part, or a short circuit.
The Freezer Defrost Sensor is located in the Freezer Compartment behind the evaporator cover.
The refrigerator has identified a problem with the sensor in the refrigerator compartment of the unit. The error is commonly caused by a separation between the sensor and the housing, a connection issue, a disconnected part, or a short circuit.
The Fridge Defrost Sensor is located in the refrigerator compartment behind the "Twin Cool" cover, in the upper right of the evaporator coils.
You're seeing solutions for Samsung Refrigerator. Select your model to find parts for your device.
Related Problems
12 problems · View all
- Compressor Running but Not Cooling
- Fridge Not Cooling But Freezer Works
- Compressor Not Running
- Light Flickering
- Freezer Ice Building Up
- Making Knocking Noise
- Sounds and Possible Causes
- Freezer Not Freezing Ice Cream
- Ice Maker Won't Stop Making Ice
- Ice Maker Not Dispensing Ice
- Won't Dispense Water
- Makes Humming Noise
- Has Freezer Leaking Water Into Fridge
- Ice Maker Only Crushing Ice
- Ice Maker Making Hollow, Small, or Mushy Ice Cubes
- Ice Maker Making Cloudy Ice Cubes
Describe your problem in your own words
