Chromebook Won't Turn On
Often, it is easy to forget the troubleshooting basics during times of frustration. Before attempting any significant repairs for your device, check the following. TESTING
  • Ensure that the charging cable of your Chromebook is seated correctly in the charging port. If you have depleted the battery and are attempting to charge the device, ensure the charger is securely connected to the charging port and plugged into a functioning power source. A complete circuit must be established between the charger, the Chromebook, and the power source to enable proper charging.
  • Verify that your device's charging indicator light is functioning correctly. When connected to power, see if the charging indicator LED illuminates or changes color, indicating your Chromebook's charging status.
  • Attempt a hard reset of your Chromebook. Press and hold the power button for at least 10 seconds to discharge any built-up power and possibly resolve software glitches. Then, try powering on your Chromebook again.
If the issue persists, proceed to the more in-depth tips below.
Causes
Solution: Inspect and Replace the Battery
If your Chromebook does not power on or show signs of life, the issue may be related to the battery. Follow these steps to troubleshoot battery-related problems.
  1. Check Battery Level: Connect your Chromebook to the charger and wait at least 15 minutes. Then, see if the charging indicator light shows the device is charging. If not, the battery might be completely drained or faulty. Consider replacing the battery.
  2. Try a Different Charger: Use a different charger that's known to work with your Chromebook model. The original might be defective if the device starts charging with the new charger.
  3. Remove External Peripherals: Disconnect external devices such as USB drives, headphones, or monitors. Sometimes, a faulty peripheral can prevent the Chromebook from powering on.
2
Solution: Inspect the Charging Port for Damage and Replace or Repair
Depending on the specific model of the Acer Chromebook, you might be using a USB-C charging cable or a barrel-style charging cable.
  • Perform a thorough visual inspection of the charge port. Use a flashlight for USB C-port interiors. It's an easy entry point for liquid, and corrosion can live there undetected.
  • Wiggle the cable gently to see if you can get a better connection. If the port is loose, the internal pin may not make enough contact to charge the battery.
  • Check for signs of corrosion or burn. If anything looks questionable, open the machine and pull out the affiliated part for a better look.
    • Spills commonly damage USB-C ports. Even if the liquid doesn't penetrate the machine's interior, corrosion in the port can spell trouble.
    • Barrel connectors are likelier to suffer from bent pints or broken plastic parts. If your port feels loose, it's likely this is to blame.
  • If you find damage that can't be fixed or corrosion that can't be removed, find a replacement. In many cases, it is a modular component. If it's soldered onto the motherboard—like a USB-C port—you'll need some soldering chops to proceed (or replace the affected board).
3
Solution: Inspect and Replace the Screen
Sometimes, it's not the Chromebook but the malfunctioning display. Check with an external monitor to see if the Chromebook is working but not displaying anything. If the screen appears to cause the problem, you can check out the Chromebook Black Screen page or replace the screen. replace the screen.
5
Solution: Replace the Motherboard
Suppose your Chromebook displays a black screen even after following the troubleshooting steps mentioned earlier. In that case, there is a high likelihood of a problem with the motherboard or the surrounding components. Getting to some of these components will vary depending on the specific model of Chromebook you are using.
  1. Remove any accumulated dust or debris from inside the device for proper airflow.
  2. Ensure that your device's CPU is adequately cooled. If your device has an active cooling fan, make sure the fan is getting power. If you have recently reinstalled your heatsink, double-check that thermal paste has been appropriately applied.
  3. Reset your device's BIOS Settings by uninstalling and reinstalling the CMOS battery. This clears any potential conflicts or misconfigurations.
  4. Verify that the RAM module is installed correctly and functioning properly. If it is not properly seated, try reinserting or replacing it.
  5. Perform a thorough visual inspection of the motherboard for any signs of burns or damaged components. If you observe any visible damage, such as burns or parts that appear to be physically damaged, the motherboard likely needs to be replaced.
Describe your problem in your own words
View statistics:
Past 24 Hours:11
Past 7 Days:42
Past 30 Days:122
All Time:2,490
