Shop the Holiday Gift Guide
Won't Turn On
Last updated on
  • Check for signs of power: Press and hold the power button to try and turn the phone on. If you notice any kind of notification sounds, lights, vibration/haptic feedback, or other responses when pressing the buttons, then you might want to take a look at our Android Phone Black Screen Troubleshooting Page.
  • Try charging your phone for 30 minutes: Connect it to a known good charger and let it charge for at least 30 minutes, even if it doesn’t show any activity. The battery might be completely drained.
  • Try a forced restart: Some phones have a unique method. Press and hold the power and volume down buttons for 10-15 seconds. Alternatively, some devices require holding the power and volume up buttons.
Causes
Solution: Clean your phone's buttons and charging port
If your phone isn't being used, then it's typically living in your pocket or purse. Oftentimes, this can cause bits of dust or debris to build up along the buttons and even in the charging port. This can prevent your phone from turning on or charging normally.
  • Wipe down the exterior of your phone: Dirt and other grime can build up on your phone. Wipe down the exterior of your phone gently with a 70% isopropyl alcohol wipe or a soft, lint-free cloth lightly dampened with a 50/50 mix of water and isopropyl alcohol.
  • Clean your phone's charging port: Lint, dust, or corrosion in the port can block the electrical connection and slow down charging. Try cleaning your charging port.
2
Solution: Attempt to boot your phone into Safe Mode
Android Safe Mode and Android Recovery Mode are diagnostic tools that can allow you to boot into a malfunctioning Android device with only the essentials that are needed to uninstall user-installed apps and clear problematic cached data.
Important
Enabling these modes can vary depending on the type of phone you have. These are the most common modes for entering Safe Mode and Recovery Mode, but be sure to look up the method for entering these modes for your specific phone.
  • How to boot into Safe Mode: Long-press the Power Button for a few seconds until the phone turns off. Press and hold the Power button for 10 seconds, then press and hold the Volume Down button until your phone boots into Safe Mode.
  • How to boot into Recovery Mode: Long-press the Power Button for a few seconds until the phone turns off. Press and hold the Power Button and the Volume Down key. When the device flashes on, you should see a bunch of information about your device, and it starts at the top of the screen.
If the screen remains black in either mode, this points to a hardware display issue rather than software.
3
Solution: Replace the battery
Lithium Polymer batteries degrade over time, reducing their capacity to charge quickly. If you have an older Android phone, the issue might be caused by the battery.
  • Check battery usage in the battery menu within Settings. In your settings, look for a Battery option and look for Battery Health or Battery Status.
    • Alternatively, you can use third-party apps like AccuBattery or Ampere to monitor your phone’s charging rate and overall battery health.
  • If you find your phone's maximum capacity is below 80%, then you should look into replacing the battery. Be sure to follow the battery replacement guide for your specific phone.
4
Solution: Open up your phone and look for any damage
  • Inspect your Screen for Physical Damage: Drops, impacts, or exposure to moisture can damage display connectors or logic board components. Look for visible cracks, screen separation, or liquid damage indicators. If your phone was liquid damage consider looking at our Electronics Water Damage Wiki, and while it's made originally for iPhones, our iPhone Liquid Damage Guide.
  • Look for any loose connections: If your phone recently fell, there’s a chance the connection between your phone’s screen and motherboard might be loose. You’ll need a guide for your specific phone and open it to check for any loose connections. It might also be beneficial to reseat the connection for your phone's display.
  • Replace the Screen: If you find that reseating the display hasn't fixed the issue, then the display itself could be faulty. Try replacing the screen and test if there is any change in the issue.
  • Look for any Damage to the Motherboard: In some cases, a logic board issue may be preventing display output. Look for any burnt or damaged components. If there are components that are damaged, then the board itself might need to be replaced unless you have soldering skills.
Describe your problem in your own words
View statistics:
Past 24 Hours:44
Past 7 Days:307
Past 30 Days:1,295
All Time:11,668
