Shop the Holiday Gift Guide
The Basics
- Make sure the exterior of your phone is clean: Debris in your phone's charging port can casue unexpected restarts due to pins being bridged.
- Check for any app updates: Poorly optimized or buggy software can cause issues with how your phone functions, and can cause your phone to restart. Make sure to update your operating system to the latest avalable release, or quit any apps that might be likely offenders.
- Close any resource-intensive apps: Close any apps you’re not actively using, especially those that consume a lot of resources.
- Uninstall any recently installed apps: If the issue only started after recently installing an app, then try uninstalling the app and see if the issue continues. If you can't get to the app without your phone restarting, try booting your phone into Safe Mode.
- Clear cached data: Currupted cached data can cause issues with how your phone functions. Go into Settings then Apps and clear the cached data for your apps.
Causes
If your phone’s storage space is nearly full, meaning anything over 80% capacity, then this can lead to performance issues and frequent restarts due to the lack of space that would be essential for system functions.
- Uninstall unused apps and app data: If you have apps that you don't frequently use, or no longer use, then you'll want to uninstall it to free up storage space.
- Open the Google Play Store app, or your specific phones equivalent.
- At the top right, tap the Profile icon.
- Tap Manage apps & devices Manage.
- Select the name of the app you want to delete.
- Tap Uninstall.
- Find and delete/offload large files: To save space, you can delete downloaded files you don't need. If the files are needed, then you might want to consider offloading your files to a computer or external storage drive.
- Remove unnecessary media: Any media will take up space on your phone. This includes photos, movies, downloaded music. Consider offloading your files to a computer or external storage drive, and be sure to delete them from your phone's storage.
Restart in safe mode: Safe Mode can allow you to access your Android phone with only the essentials software.
- Long-press the Power Button until the phone turns off.
- Press and hold the Power Button for 10 seconds, then press and hold the Volume Down Button until Safe Mode boots.
If the phone doesn't restart while in safe mode then this likely indicates an issue with currupted data or software installed on your phone. If your phone does restart while in safe mode, then it is likely an issue with your phone's hardware.
- Inspect your Screen for Physical Damage: Drops, impacts, or exposure to moisture can damage display connectors or logic board components. Look for visible cracks, screen separation, or liquid damage indicators. If your phone was liquid damage consider looking at our Electronics Water Damage Wiki, and while it's made originally for iPhones, our iPhone Liquid Damage Guide.
- Look for any loose connections: If your phone recently fell, there’s a chance a connection inside your phone had been disconnected. You’ll need a guide for your specific phone and open it to check for any loose connections.
- Look for any Damage to the Motherboard: In some cases, a logic board issue may be preventing display output. Look for any burnt or damaged components. If there are components that are damaged, then the board itself might need to be replaced unless you have soldering skills.
You're seeing solutions for Android Phone. Select your model to find parts for your device.
Related Problems
Android Phone
8 problems · View all
Describe your problem in your own words
