Samsung Phone Troubleshooting: Fix Common Problems
The first step towards a working Samsung Phone is identifying the problem. Select one of our preferred guides below to diagnose and solve Samsung Phone common issues.
Samsung Galaxy Phone Battery Draining Fast
Is your Galaxy phone draining battery quickly? Does a charge not last a full day or anymore? Do you find yourself needing to charge multiple times a day? Have a look at these solutions to optimize your battery life!
Samsung Galaxy Not Charging
Is your Samsung phone not accepting a charge? Is your charger good, but you can't get your phone to respond? Check out these fixes to get back in order!
Lines on Screen
Is your Samsung Galaxy phone plagued with lines onscreen? Are green and purple lines covering the content you're trying to see? Take a look at this page to discover the cause.
Samsung Galaxy Phone Not Turning On
Is your Samsung Galaxy failing to power on? Are you getting no signs of life? Even if you've left it to charge all night? Well you're in the right place.
Samsung Galaxy Phone Black Screen
Is your Samsung phone on, but nothing is on the screen? Hearing system alerts, but all you can see is black? Check out these fixes!
Moisture Detected in Charging Port
Is your Samsung phone warning that you’ve got liquid in the charge port? Is it blocking you from charging your phone? Keep your port dry and try these fixes!
Samsung Galaxy Frozen Screen
Is your Samsung Galaxy phone unresponsive? Is it frozen o on the lock screen or mid task? There are some easy fixes to get unstuck!
Samsung Galaxy Keeps Restarting
Is your Galaxy phone boot looping? Is it restarting unexpectedly, (or predictably). There are plenty of solutions to get you up and running.
Samsung Galaxy Overheating
Is your Samsung Galaxy getting too warm? Getting a warning on screen that your phone is hot? Can't get the warning to go away? Have a look at these ideas.
Samsung Galaxy No Sound
Is your Galaxy phone staying silent? Can't hear music or videos even with the volume at max? Missing calls because they seem to be silent? Get going again with these fixes!
Samsung Galaxy Camera Blurry
Does your camera consistently take blurry photos? Is it making a vibrating noise or has issues maintaining focus? Buckle up and give these solutions a go
Didn't see your problem? The iFixit Community has answers.
Browse the most common questions asked by our members to see more solutions. Still no luck? You can always ask for help!
Why is my phone saying Charging stopped,temperature is too low
Samsung Galaxy A22
Phone not turning on after being dropped and cracking the screen
Samsung Galaxy A22
My Phone not switching on
Samsung Galaxy A22
Factory reset option doesn't come
Samsung Galaxy A22
Headphone port blocked, will not connect
Samsung Galaxy A22
Why is my phone slow charging in fast charge mode?
Samsung Galaxy A22
Why is my phone charging too much slowly it take more than 8 hour
Samsung Galaxy A22
My phone touch screen is not working due to water damage
Samsung Galaxy A22
