Shop the Holiday Gift Guide
Repair and disassembly information for Samsung's Galaxy A22 Android smartphone, released in July 2021.
Why is my phone saying Charging stopped,temperature is too low
Why is my phones temperature too low
Score 10
Add a comment
Most Helpful Answer
@nellymotau besides the possibility that our ambient temp is too low to charge the battery, this is a pretty common error. It can be software related so you want to reboot your phone and make sure that your software is up to date.
Most common issue is a failed thermo sensor. You have 3 on your logic board, one on the charging board and one on the battery. I would replace the battery first then reevaluate and next replace the charging board. That should resolve the issues with the low temp.
Update (04/06/24)
Since iFixit does not yet have a guide for neither the battery nor the charging board, use something like this video It'll take care of both. Both the charging board and the battery are readily available at many online stores. Just make sure you get the ones appropriate for your exact model.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Score 4
2 Comments:
@nellymotau Took a bit of looking, but I finally located a YouTube video showing the procedure for replacing the battery on your phone.
https://www.youtube.com/watch?v=cjCB3lnk...
by Share
Add a comment
Are you in a cold climate? If you are it's because batteries' activity naturally slow down in colder climates. I don't know what effect it has when charging them in this state, but I think it should be perfectly fine. Weird, I have never heard of this before, but I think that is the cause. Maybe you should put it near a heat source to charge it.
1 Comment:
It has nothing to do with temperature. Even on scalding hot afternoon it will still persist
by Share
Add a comment
Your phone's temperature is too low. Charging will continue when the temperature returns to normal.
Add a comment
Add your answer
Nelly Motau will be eternally grateful.
Past 24 Hours: 7
Past 7 Days: 57
Past 30 Days: 251
All Time: 16,890
