This teardown is not a repair guide. To repair your Microsoft Surface Pro 6, use our service manual.
  1. Microsoft Surface Pro 6 Teardown, Microsoft Surface Pro 6 Teardown: step 1, image 1 of 2 Microsoft Surface Pro 6 Teardown, Microsoft Surface Pro 6 Teardown: step 1, image 2 of 2
    • New Surface, new specs (sorta):
    • 12.3" PixelSense display with 2736 × 1824 resolution (267 ppi)
    • 8th-Gen (Kaby Lake R) quad-core Intel Core i5 processor with Intel UHD Graphics 620
    • 8 GB RAM (16 GB optional)
    • 128 GB solid-state storage (256 GB, 512 GB, and 1 TB configurations optional)
    • 8 MP rear-facing camera with 1080p video, and 5 MP / 1080p front-facing Windows Hello camera
    • USB 3.0, microSDXC, Mini DisplayPort, SurfaceConnect, and 3.5 mm audio ports
    • 802.11a/b/g/n/ac Wi-Fi, Bluetooth 4.1
  2. Microsoft Surface Pro 6 Teardown: step 2, image 1 of 3 Microsoft Surface Pro 6 Teardown: step 2, image 2 of 3 Microsoft Surface Pro 6 Teardown: step 2, image 3 of 3
    • Looks like we have an extra Surface Pro 6—err, wait, one of those is last year's Surface Pro.
    • Well, on the outside not much has changed from last year. Still the same case, hinge, and relatively healthy number of ports.
    • Noticeably absent for 2018, however, is the ever-popular USB-C port that found its way onto the Surface Go.
    • We have to look pretty close to tell these Surfaces apart. Even the model number under the kickstand is the same as last year: 1796.
    Pro 6 and Pro 5 are same model number?
    pk2281 - Reply
  3. Microsoft Surface Pro 6 Teardown: step 3, image 1 of 3 Microsoft Surface Pro 6 Teardown: step 3, image 2 of 3 Microsoft Surface Pro 6 Teardown: step 3, image 3 of 3
    Tool used on this step:
    iOpener
    $19.99
    Buy
    • The Surface Pro series has a few different configurations, and they all come standard with upgraded adhesive.
    • Fortunately, we've got a tried-and-true recipe for Surface screen separation success:
    • Step 1: apply iOpener liberally.
    • Step 2: grab an Opening Pick and a Suction Handle, and fight for dear life through Microsoft's gauntlet of adhesive.
    • Step 3 (optional): get impatient, break screen.
    • Luckily, we don't run into any surprises as we free the display—everything's pretty much the same as before, save for an extra display cable compared to the Surface Go.
    This picture makes it look too easy, it is not! you did damage to the wifi antenna and you need to take care at multiple stages of removal.
    wahr42 - Reply
  4. Microsoft Surface Pro 6 Teardown: step 4, image 1 of 2 Microsoft Surface Pro 6 Teardown: step 4, image 2 of 2
    • We interrupt this disassembly to bring you display chips!
    • Microsoft X904169, possibly N-Trig's Surface Pen controller and X904163 (likely touchscreen line driver)
    • Analogix ANX2604, possibly a DisplayPort converter.
    • Macronix MX25U1635F 16 Mb serial NOR flash memory
    • Silicon Works SW5077 power management
    • Likely Silicon Mitus SM4063B programmable gamma buffer
    • LG makes this display, which seems suspiciously similar to the one we found on the Surface Pro 5.
    • Could they be cross-compatible? Yes they could—we dropped last year's display into our Surface Pro 6, and it worked almost like someone planned it that way.
    is the digitiser controller the same as the one in the surface pro 5 ?
    Antonio - Reply
  5. Microsoft Surface Pro 6 Teardown: step 5, image 1 of 2 Microsoft Surface Pro 6 Teardown: step 5, image 2 of 2
    • With the display out of the way, we can get to the good stuff.
    • It seems Microsoft has been meddling with their passive cooler a bit—it looks like last year's, but with an extra little pipe down the left side—plus some funky heat-spreading pads.
    • It's impressive to see Microsoft continue to bump up processing power without much additional heat management. It will be interesting to see how well this new setup handles the heat under load.
    • Looking south, the similarities continue, with a quad-cell battery taking up most of the case.
    • On the plus side, all the screws so far are standard Torx. Let's get to twirling them out!
    I can see a damaged antenna top right, they are a pain to avoid, but I was able to re-stick it on as long as you don’t cut them. They conduct by close strong contact.
    wahr42 - Reply
  6. Microsoft Surface Pro 6 Teardown: step 6, image 1 of 3 Microsoft Surface Pro 6 Teardown: step 6, image 2 of 3 Microsoft Surface Pro 6 Teardown: step 6, image 3 of 3
    • Searching for the gold at the end of the heatsink, we peel back some ... things. The Surface Pro 4 had a copper heat spreader, but these look like graphite.
    • Looking under those heat spreaders didn't lead to any gold, but we're free to remove the heatsink now.
    • With the heatsink dispatched, we have access to the heat generators—all that silicon!
  7. Microsoft Surface Pro 6 Teardown: step 7, image 1 of 2 Microsoft Surface Pro 6 Teardown: step 7, image 2 of 2
    • New chips and stale chips (mostly the latter):
    • Intel Core i5-8250U processor
    • Samsung K4E6E304EB-EGCF 2GB LPDDR3 DRAM (4 chips for 8 GB total)
    • SK Hynix HFB1M8M0331A (BC501) 128 GB NVMe SSD
    • Winbond 25Q128JVPQ 128Mb serial flash memory
    • Marvell W8897 802.11ac, NFC, and Bluetooth SoC
    • Nuvoton NPCT650SBCWX Trusted Platform Module
    • Realtek RTS5343 microSD card reader controller
    Still DDR3 though? The MacBook Pro and most other laptops are running DDR4…
    djlobb01 - Reply
    Not DDR3 but LPDDR3. It is limited by intel processor which supports LPDDR3 and DDR4 only. intel processor does not support LPDDR4x.
    JJ Wu -
    Is the NVMe SSD replaceable?
    Hoa Le - Reply
    As it is soldered onto the motherboard, replacing it would be highly unlikely. However, it may be possible to install additional memory, as there seems to be a spare empty pad for lower memory configurations (see area left of yellow marking in Step 7).
    Arthur Shi -
    was there space to add RAM to the 8GB version?
    laurence.ng.cordell - Reply
    I have to replace the SSD. I’m able to solder and I want to try it, but I don’t find this SSD on the market (I'm writing from Italy).
    Can someone help me to find a compatible 128GB SSD in Europe? Thanks a lot!
    Riccardo84 - Reply
    is the socket for the ribbon cable connector on the display available. i have one that has been damaged from removal of the ribbon cable. i would like to know where i can order one.
    ray licon - Reply
    is the socket for the ribbon cable on the mother board available to purchase? where can i purchase one? it looks like a 26 pin socket.
    ray licon - Reply
  8. Microsoft Surface Pro 6 Teardown: step 8, image 1 of 2 Microsoft Surface Pro 6 Teardown: step 8, image 2 of 2
    • On the flip side:
    • Freescale/NXP M22J9VDC Kinetis K22F 512KB 120 MHz ARM Cortex-M4 based MCU
    • Texas Instruments BQ25700A battery buck-boost charge controller
    • Realtek ALC3269 audio codec
  9. Microsoft Surface Pro 6 Teardown: step 9, image 1 of 2 Microsoft Surface Pro 6 Teardown: step 9, image 2 of 2
    • IC Identification, pt. 2:
    • Monolithic Power Systems MP2949A tri-loop digital multi-phase controller w/ PMBus interface
    • Monolithic Power Systems NB681 6 A synchronous buck converter
    • Monolithic Power Systems NB679A and NB680GD 8 A synchronous buck converter
    • Monolithic Power Systems NB685A 12 A synchronous buck converter
    • Monolithic Power Systems MP86901-A and MP86902-B power phase
    • Texas Instruments CSD87334Q3D 20 A power block
    • Texas Instruments TLV62085 3 A step-down converter
  10. Microsoft Surface Pro 6 Teardown: step 10, image 1 of 2 Microsoft Surface Pro 6 Teardown: step 10, image 2 of 2
    • IC Identification, pt. 3:
    • Texas Instruments TPS62140 2 A step-down converter
    • Texas Instruments TPS62175 0.5 A step down converter
    • Monolithic Power Systems MP3376A 8-ch. WLED driver
    • Monolithic Power Systems MP2370DGT white LED driver
    • Texas Instruments TPS70933 150 mA LDO regulator
    • Texas Instruments TPS3700 18 V voltage detector
    • Texas Instruments TLV3011 comparator w/ voltage reference
  11. Microsoft Surface Pro 6 Teardown: step 11, image 1 of 2 Microsoft Surface Pro 6 Teardown: step 11, image 2 of 2
    • IC Identification, pt. 4:
    • Bosch Sensortec BMI160 3-axis accelerometer/gyroscope
    • Bosch Sensortec BMA254 accelerometer (likely)
    • ON Semiconductor CAT24C16 16 Kb serial EEPROM memory and Winbond W25X40CL 4 Mb serial NOR flash memory
    • Texas Instruments SN74AVC2T245 dual-supply bus transceiver
    • Texas Instruments TS3USB30E high-speed USB 2.0 1:2 mux/demux switch
    • Nexperia (formerly NXP Semiconductor) 74LVC125A 3-state quad buffer/line driver
    • Nexperia (formerly NXP Semiconductor) 74AUP1G32 2-input OR-gate
  12. Microsoft Surface Pro 6 Teardown: step 12, image 1 of 2 Microsoft Surface Pro 6 Teardown: step 12, image 2 of 2
    • We've once again come to that inevitable junction in any Surface teardown: take out the heavily-glued battery, or leave it be?
    • Considering there are no stretch release battery tabs, and we've had our fill of prying, we opt to let the beast slumber for now.
    • This battery weighs in at 45 Wh (7.57 V x 5940 mAh), exactly the same as last year.
    • That's expectedly larger than its more mobile sibling, and even a little larger than the most recent iPad.
    I saw someone on youtube using heat gun at the back of battery, is that safe?
    Maying Huelgas - Reply
    We strongly discourage heating a battery with a heat gun, as there is a substantial risk of a thermal event.
    Arthur Shi -
    Can I use pro 5 battery inside the pro 6?
    The LearningParent - Reply
  13. Microsoft Surface Pro 6 Teardown: step 13, image 1 of 3 Microsoft Surface Pro 6 Teardown: step 13, image 2 of 3 Microsoft Surface Pro 6 Teardown: step 13, image 3 of 3
    • Really scraping the bottom of the barrel case, hoping for something new, we pull out the speakers and cameras.
    • The cameras are still hidden under the bracket holding the antennas (which are incredibly easy to mangle upon opening).
    • The speakers are still corner mounted triangles for that surround sound feel.
    • I guess there's not much this tablet could do to raise its repairability score at this point.... But a fixer can dream...
  14. Microsoft Surface Pro 6 Teardown: step 14, image 1 of 1
    • Here's a shucked Surface for your viewing pleasure! In theory this is a tablet, but in our reality it was a pain in the butt!
    • The Surface Pro 6 brings more processing power (and heat) without changing its cooling solution much. Will the new thermal spreaders on the heat sink be enough to handle the power boost? Only time will tell.
    • After hearing rumors of a modular Studio, we were hoping this generation of Surface Pro would steer that direction. Alas, it's just as un-upgradable and un-repairable as ever, and it doesn't even get a USB-C port.
    为什么sureface pro6 工作的时候 把耳朵贴到后面会听到呲呲的声音?
    james dxb - Reply
  15. Final Thoughts
    • To the extent that screws are used, they are all standard Torx fasteners.
    • This tablet still has a headphone jack, which is modular and replaceable, if you can get to it.
    • All repairs require first removing the display assembly—which is stubbornly glued in place, expensive, and prone to shattering.
    • The battery is firmly glued in place, with its connector pinned under the motherboard—requiring near-total disassembly for service.
    • Once upon a time, Surface Pro storage was removable—but not in this version.
    • Complex construction makes all disassembly and reassembly tedious in comparison to other tablets.
    Repairability Score
    Repairability 1 out of 10
    (10 is easiest to repair)
Taylor Dixon
67,119 Reputation
94 Guides authored
28 Comments
Is it better a SKhynix HFB1M8M0331A (BC501) 128 GB NVMe SSD instead of a a SSD m.2 slot like in the surface 4? now there is no way we can change the ssd :/
Gabriel BEck - Reply
Its to save space I guess. Whats strange is my surface pro 6 is the same config i5 128 and it has samsung SSD. They must have switched vendors.
Ash -
Excellent tutorial, the director of IFIX I suggest on the page add a translator of languages ​​in Spanish as well as activate the multilanguage translation of the videos of YOUTUBE so you will socialize the knowledge of your pipelines in all languages! Not the whole planet speaks or reads in English!
johan fernandez - Reply
Hi Johan! This teardown has been translated into SIX non-English languages, including Spanish! Hope this helps!
Sam Goldheart -
What kind of a world do we live in where an iPad gets a higher repairability score than a Windows tablet?
Rocky Carr - Reply
Apparently, the Windows device manufacturers have taken a lot of profitability cues from Apple. At least in technology sector, the history seems to be somewhat cyclical.
Michael Han - Reply
The marketing is working too, reviews are great. I got pulled in too, been a long time mac user (had windows pcs, and chromebooks as well.) I swore mac was the way to go for the past few years, but now I see no reason to buy a mac, I’m all in on these windows Surface devices. I passed up an ipad pro, gaming pc, and pixel slate to buy a surface pro because for someone like me who needs a pc at home and on the go with decent specs, nothing beats a surface pro.
Ash -
Planned Obsolescence. If we could easily repair these things, then sales of their $600 - $3000 items go down. It’s a profit/greed/numbers game. Some of us are thankfully more stubborn then they are and refuse to give them that pleasure. I will learn the ways around this device when my Pro 3 and Book1/Performance base (this one is still under warranty) finally die.
scanslers - Reply
Is there a way to fix the charging port on this one. or any vendor willing to do it.
KP S - Reply
The model number for the Surface Pro 6 is actually 1824. The 1796 model number refers to the Surface Pro 5 or Surface 2017. Make sure if you are buying screen to fix you get it for the Surface Pro 6 or 1824. Cheers.
Abdullah - Reply
The Surface Pro 6 in our teardown was definitely 1796—you can tell for sure it’s a 6 because of the hardware changes and the updated processor from Intel. It’s entirely possible they’re using more than one model number. There’s some discussion about this here.
Jeff Suovanen -
1824 model belongs to Microsoft Surface Go.
nochkin -
muy buen tutorial, muchas gracias
Lucas Castro - Reply
I have to say, even though Surface Pro tabs are scoring like a 1 forever on iFixit, I’ve 2 model 1’s and they still run like clockwork. Microsoft might have glued all together, but the machines a extremely reliable. And since the OS is open, you can’t go much wrong. I would not want to use a 2013 iPad 4 today, yet a Surface Pro 1 is a fine machine in 2019. Even the battery is pretty usuable today at 80% (for both similar scores) capacity.
Blanka - Reply
Where do we get the replacement screens? I had a repair person suggest I just buy a new computer, and that that would be cheeper.
wlaketahoe@gmail.com
Chris Brown - Reply
I have a Surface Pro 6. The battery is down. Does it mean it is irreplaceable??
Vida Okpara - Reply
Hi Vida,
The battery is replaceable, but it is very difficult to do without damaging the display. The battery is also heavily glued in. If you could find a replacement battery, I would suggest taking your Surface Pro 6 to an experienced repair shop to get the battery replaced.
Arthur Shi -
Hello. I need to replace the hinges on my Surface Pro 6. Do you have step-by-step instructions for this?
Ty Penn - Reply
Il y’a quelques choses qui cloche avec la puissance ? Êtes vous sur que ce sont des dissipateur thermique pourquoi il y a t’il du capton entre la parti cuivrer et ce que vous pensez etre du graphite ? N’est cest pas plutôt un écran thermique ?
V1000 - Reply
Did it have m.2 ?
And how much M.2 INSIDE?
8774computer - Reply
As you can see in this step, it has soldered-on NVMe storage.
Arthur Shi -
Does anyone know if the surface pro 5 battery is compatible with the 6?
Matthew Young - Reply
excellent teardown guide, i’ll be using it soon I think - question I have is; my system fails to power on at all, I’ve tried various ‘reset’ guides, ‘wake from sleep guides’’, no splash screen, nothing except battery charge light. have replaced battery chargers w/new one, and to no avail, still no power on to screen. would suspect be battery? BQ25700A battery buck-boost charge controller? or another quirky chip on the system board or item preventing even a flash of lite on the system screen, keyboard?
Richard Turner - Reply
did you ever find a solution to this?
Max Dickerson -
I have a Surface Pro 6, and it identifies the SSD as a Samsung-made one. This is how it is identified in the Task Manager:
Disk 0 (C:)
            SAMSUNG KUS020203M-B000
            Capacity:         119 GB
            Formatted:      119 GB
            System disk:    Yes
            Page file:         Yes
            Type:   SSD
            Read speed      8.2 KB/s
            Write speed     4.1 KB/s
            Active time     1%
            Average response time           4.5 ms
Leumas Eleets - Reply
Can the hard drive be recovered in the 6?
Anne Marie Brandt - Reply
Past 24 Hours: 37
Past 7 Days: 240
Past 30 Days: 1,002
All Time: 178,653
