Mac Mini Logic Board Removal Tool
  • Mac Mini Logic Board Removal Tool / Stainless Steel
We'll send a message when the product is back in stock.
Product Details
Description
Description
The least originally named tool we offer.
  • Simple tool pries the logic board free to allow access to the hard drive in 2010-up Mac Minis.
  • Custom iFixit version is nearly indistinguishable from Apple's official logic board removal tool.
Repair Stories
User avatar
My Problem
Upgrade to SSD
My Fix
Found out the hard way you need to reformat the SSD before installing in the Mac mini. Otherwise it went fine.
My Advice
Note in the guide to reformat the SSD before installing into the Mac mini
User avatar
My Problem
replaced HDD with SSD
My Fix
did not need tool to remove logic board but screen did not fit back could not use one screw
My Advice
take risks but use good tools
User avatar
My Problem
One day my Mac Mini would not wake up. Leading up to this it was acting a bit unreliable.
My Fix
I started with first unplugging the power supply from the logic board and measuring the power supply output with a multi-meter to ensure that was not the issue. It puts out a simple 12V to the logic board so i . . .
User avatar
My Problem
Not a problem but an upgrade. A friend of a friend was in the market for a new computer and I convinced him to buy a Mac. A large selling point was the ability to purchase an older Mac and install a second drive and install Windows on it in the off chance he'd ever want to go back to it.
My Fix
"Repair" its . . .
User avatar
My Problem
My original 500GB hard drive was very SLOW .
My Fix
Super easy. Followed the instructions provided on ifixit.com, easy to follow and step by step. I was up and running within an hour. Now my Mac Mini is FAST!!
My Advice
1. Backup to Time Machine First - restore is fast and easy.
2. Follow the instructions for a co . . .
User avatar
My Problem
The hard drive was to slow - change it to a SSD
My Fix
Followed the repair guid for harddisk installation, and the guide was really helpful.
My Advice
Take your time and read the guid carefully. If you do, you will not go wrong
User avatar
My Problem
I was receiving a SMART report of imminent failure, so I replaced it with a Crucial MX300 SSD
My Fix
Two issues: the IR sensor was not observed. And the insertion into the drive slots was very tedious. The drive did not want to go into the two holes in the case. I also replaced the Mac mini cooling fan whi . . .
User avatar
My Problem
Slow mechanical hard drive - upgrade to SSD.
My Fix
Went smoothly.
My Advice
Could have used some closeups on the removal of the power plug clip - you just pull it out, but it wasn't clear if it was supposed to levered up or down. Also, could have used a closeup on pulling the power connector off the logic board; it d . . .
User avatar
My Problem
I was tired of long boot times and slow program launches on my late 2014 Mac Mini. Even with 16 GB of RAM, the thing was pokey.
My Fix
The 2014 Mac Mini wasn't the most difficult Mac to work on that I've ever encountered, that honor goes to the pre-Unibody Macbook Pro. Ugh. Replacing the hard drive in the M . . .
User avatar
My Problem
I thought I could live with a slow spinning drive - I couldn't...
My Fix
The replacement went without a hitch. I was dreading some kind of hiccup along the way, but the directions were so clear and detailed, I knew what to expect at each step. So in the end, I was able to successfully replacement my stock . . .
Show more
