MacBook Air 13" (Mid 2013 to 2017) I/O Board Cable
  • MacBook Air 13" (Mid 2013 to 2017) I/O Board Cable
$19.99
$19.99
We'll send a message when the product is back in stock.
Product Details
Description
Description
Replace a torn or damaged cable connecting the I/O board to the logic board in a Mid 2013 to 2017 13" MacBook Air.
Compatibility
MacBook Air 13" Early 2014
1.4 GHz
1.7 GHz
MacBook Air 13" Early 2015
1.6 GHz
2.2 GHz
MacBook Air 13" Early 2017
1.8 GHz
2.2 GHz
MacBook Air 13" Mid 2013
1.3 GHz
1.7 GHz
Show 1 more device
Repair Stories
User avatar
IT Department's Story Photo #1178216
IT Department's Story Photo #1178217
My Problem
One of the founders of the company I work at accidentally left his MacBook outside, and it was attacked by his sprinkler system.
My Fix
There was some corrosion on the mainboard that had to be cleaned off, and the I/O Board and I/O Ribbon Cable had to be replaced, due to them being fried. But after replacin . . .
User avatar
My Problem
The silence from the MacBook AIr was deafening and my client could no longer stand it!
My Fix
The repair went very quietly... and after the last screw was restored and thw power button pressed, that familiar startup sound came loud and clear!
My Advice
No enlightenment, however, I do recommend following the steps and . . .
User avatar
My Problem
A friends MacBook Air had been for a drink and no longer powered on.
My Fix
Simple, with the right tools, attention to detail, patience and the correct guidance. We were lucky the IO board was the only part damaged by liquid. We also replaced the flex cable which had a red dot underneath (assume this is a l . . .
User avatar
My Problem
Not turning on after coffee spilt over.
My Fix
I thought the problem was on the I/O because the coffee got spilled over the charging area.
My Advice
It is more probably that the logic board.
User avatar
My Problem
The output and input audio not working
My Fix
I fixed the problem replacing the I/O board and the I/O Board Cable
My Advice
You should have patience to replace anything in Apple devices, is very difficult to remove all small flats correctly.
Show more
