MacBook Air 13" (Late 2010 to Early 2015) Fan
  • MacBook Air 13" (Late 2010 to Early 2015) Fan
$39.99
$39.99
We'll send a message when the product is back in stock.
MANTA DRIVER KIT
112 bit driver kit $59.99
MANTA DRIVER KIT
Product Details
Features
Features
Sometimes, all you need is a fan.
Everyone has a first fan. If your fan has lost its loyalty, replace it with one that appreciates you for you. Includes fan and surrounding metal bracket.
Compatibility
MacBook Air 13" Early 2014
1.4 GHz
1.7 GHz
MacBook Air 13" Early 2015
1.6 GHz
2.2 GHz
MacBook Air 13" Late 2010
1.86 GHz
2.13 GHz
MacBook Air 13" Mid 2011
1.7 GHz
1.8 GHz
MacBook Air 13" Mid 2012
1.8 GHz
2.0 GHz
MacBook Air 13" Mid 2013
1.3 GHz
1.7 GHz
Show 3 more devices
Repair Stories
User avatar
dmalinovsky's Story Photo #673682
dmalinovsky's Story Photo #673684
dmalinovsky's Story Photo #673683
My Problem
My wife spilt tea over her MacBook Air 2012. Because of the water damage Apple Store guys said it'll take almost $1K to fix it, so you can guess my decision… But at least they made the diagnostics so I knew what to replace.
My Fix
Perfectly smooth, thanks for awesome tools and parts. The only tricky par . . .
User avatar
andreasjohansson's Story Photo #705878
My Problem
Fan was making a shrieking noise when on - didn't matter CPU load, etc.
My Fix
Repair was easy - the online guide is so easy to use, and with the right tools it only took us 4-5 minutes.
My Advice
Ha! Once we had replaced the fan, we looked at old one, spun the blades a few times, and out popped a hole-punch hole! And . . .
User avatar
chris's Story Photo #463413
My Problem
The battery on 2 of our Macbook Air's were pretty much dead. One of the Air's fans sounded like a helicopter.
My Fix
The repair was simple with the iFixit 54 bit driver kit and the replacement parts. The tutorial was spot on with each step.
My Advice
Don't wait to get a new battery. It makes all the difference in the . . .
User avatar
Jesse Russell's Story Photo #352214
My Problem
Fan started making concerning noises.
My Fix
Every step was clear as day. Took me about 20min and that was me going extremely slow and meticulous. I could do it again in around 7-8min I expect.
My Advice
Just do it the right way with the right parts that are known to work and you'll have no problems.
User avatar
My Problem
Had to replace my macbook display which involves removing the fan, somehow I broke the fan ribbon cable doing this so I had to order a new fan
My Fix
Went completely pain free, the iFixit guides are always helpful
My Advice
Be REALLY careful with the fan ribbon cable, I thought I was careful the first time but I still . . .
User avatar
My Problem
Daughter stumbled and crunched corner of her laptop, but luckily only the lower case and fan were damaged.
My Fix
Very easy repair. I skipped step #6. If she didn't have homework I would've had my daughter do the repair herself (with my supervision).
My Advice
Purchased new lower case on eBay. Probably didn't need . . .
User avatar
My Problem
The fan in my MacBook Air was growling. Grrrrrrrrr!
My Fix
Easy Peasy.... I didn't even lose the screws, and remembered exactly where each went thanks to the overnight shipping. Overnight? Ordered 3:00 pm eastern time, shipped from California and arrived 11:00 am eastern time in Florida. How can they do th . . .
User avatar
My Problem
The fan doesn't work any more
My Fix
Really easy to access the fan can be replaced quickly. The only little problem is to connect the new one. The spudger help but it's not easy to do it
My Advice
as said in comments step 3 & 6 in guide are not necessary
User avatar
My Problem
Noise from the old fan
My Fix
Everything went ok
My Advice
No additional advice.
User avatar
My Problem
A piece of plastic from a clothing tag fell into the fan and caused it to stop working. I replaced it using the parts from iFixit. Easy repair - works like new.
My Fix
Great - the instructions are spot on. Pictures and descriptions are easy to follow. Total repair time was less than 15 minutes.
My Advice
Follo . . .
Show more
