This translation may not reflect the most recent updates from the source guide. Help update the translation or view the source guide.
加热 iOpener并将其穿过反向钳。
折叠 iOpener,使其位于 iPhone 的底部边缘。
等待一分钟,让粘合剂有机会释放并出现开口间隙。
将撬片插入间隙中。
跳过接下来的三个步骤。
加热iPhone的下缘将有助于软化固定显示屏的粘合剂,使其更容易打开。
使用吹风机或准备一个iOpener,并将其放到手机的下缘约90秒,以软化显示屏下面的粘合剂。
Tool used on this step:Tri-point Y000 Screwdriver$5.99
从下侧连接器支架上拆下以下长度的四颗三点式 Y000 螺丝 :
三个1.2mm螺丝
一个2.4 mm螺丝
维修过程中,使用磁性垫来记住每颗螺丝所对应的位置,避免重新安装的过程中螺丝安装错位损伤您的手机。
将您的替换零件与原始零件进行比较——您可能需要在安装前转移剩余的组件或从新零件上移除背胶。
- 若要重组你的设备,重新涂抹显示屏粘胶剂 并按照相反的顺序执行以下指南。 ***
请将您的电子垃圾送到[e-waste |R2或e- steward认证的回收商|new_window=true]。
维修手机遇到问题怎么办?来iPhone7问题回答找找解决方案吧。
909 other people completed this guide.
Special thanks to these translators:
90%
These translators are helping us fix the world! Want to contribute?
Start translating ›
120 Comments
yes , unless it is sealed back with new waterproof tape, which almost no one has yet
Atronx -
No you can buy the replacement. See the above guide for a link on how to do that and iFixIt sells them. Recommend buying more than one because installation is tricky - must get it aligned perfectly though the spluger and pointy tweezers can help reposition minor slipups.
The back adhesive is available on ifixit. So you can make it water proof-ish again.
Recall, an original iPhone is far from waterproof after only a month usage.
Guenter -
