iPhone 11 Taptic Engine Replacement
  1. iPhone 11 Taptic Engine Replacement, Remove the pentalobe screws: step 1, image 1 of 2 iPhone 11 Taptic Engine Replacement, Remove the pentalobe screws: step 1, image 2 of 2
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.7 mm-long pentalobe P2 screws at the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
    Ask FixBot
  2. iPhone 11 Taptic Engine Replacement, Mark your opening picks: step 2, image 1 of 3 iPhone 11 Taptic Engine Replacement, Mark your opening picks: step 2, image 2 of 3 iPhone 11 Taptic Engine Replacement, Mark your opening picks: step 2, image 3 of 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Ask FixBot
  3. iPhone 11 Taptic Engine Replacement, Tape over any cracks: step 3, image 1 of 3 iPhone 11 Taptic Engine Replacement, Tape over any cracks: step 3, image 2 of 3 iPhone 11 Taptic Engine Replacement, Tape over any cracks: step 3, image 3 of 3
    • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
    • If all else fails, you can superglue the suction cup to the screen.
    Ask FixBot
  4. iPhone 11 Taptic Engine Replacement, Anti-Clamp instructions: step 4, image 1 of 3 iPhone 11 Taptic Engine Replacement, Anti-Clamp instructions: step 4, image 2 of 3 iPhone 11 Taptic Engine Replacement, Anti-Clamp instructions: step 4, image 3 of 3
    Tool used on this step:
    Clampy - Anti-Clamp
    $24.95
    Buy
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone—one on the top, and one on the bottom.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
    Ask FixBot
  5. iPhone 11 Taptic Engine Replacement: step 5, image 1 of 3 iPhone 11 Taptic Engine Replacement: step 5, image 2 of 3 iPhone 11 Taptic Engine Replacement: step 5, image 3 of 3
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    Ask FixBot
  6. iPhone 11 Taptic Engine Replacement: step 6, image 1 of 3 iPhone 11 Taptic Engine Replacement: step 6, image 2 of 3 iPhone 11 Taptic Engine Replacement: step 6, image 3 of 3
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the iPhone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick into the gap under the screen and the plastic bezel, not the screen itself.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
    Ask FixBot
  7. iPhone 11 Taptic Engine Replacement, Heat the lower edge of the phone: step 7, image 1 of 1
    • Heating the lower edge of the iPhone helps soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or heat gun or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute.
    Ask FixBot
  8. iPhone 11 Taptic Engine Replacement: step 8, image 1 of 2 iPhone 11 Taptic Engine Replacement: step 8, image 2 of 2
    • If you're using a single suction handle, apply it to the bottom edge of the phone, while avoiding the curved portion of the glass.
    Ask FixBot
  9. iPhone 11 Taptic Engine Replacement, Lift the display slightly: step 9, image 1 of 3 iPhone 11 Taptic Engine Replacement, Lift the display slightly: step 9, image 2 of 3 iPhone 11 Taptic Engine Replacement, Lift the display slightly: step 9, image 3 of 3
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • Insert an opening pick into the gap under the screen and the plastic bezelnot the screen itself.
    • The watertight adhesive holding the display in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
    Ask FixBot
  10. iPhone 11 Taptic Engine Replacement, Separate the screen adhesive: step 10, image 1 of 3 iPhone 11 Taptic Engine Replacement, Separate the screen adhesive: step 10, image 2 of 3 iPhone 11 Taptic Engine Replacement, Separate the screen adhesive: step 10, image 3 of 3
    • Slide the opening pick around the lower left corner and up the left edge of the iPhone, slicing through the adhesive holding the display in place.
    • Don't insert your pick more than 3 mm, as you may damage internal components.
    Ask FixBot
  11. iPhone 11 Taptic Engine Replacement, Screen information: step 11, image 1 of 1
    • There are delicate cables along the right edge of your iPhone. Don't insert your pick here, as you may damage the cables.
    Ask FixBot
  12. iPhone 11 Taptic Engine Replacement: step 12, image 1 of 3 iPhone 11 Taptic Engine Replacement: step 12, image 2 of 3 iPhone 11 Taptic Engine Replacement: step 12, image 3 of 3
    • Re-insert your pick at the bottom edge of the iPhone, and slide it up the right side to continue separating the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the display cables.
    Ask FixBot
  13. iPhone 11 Taptic Engine Replacement: step 13, image 1 of 3 iPhone 11 Taptic Engine Replacement: step 13, image 2 of 3 iPhone 11 Taptic Engine Replacement: step 13, image 3 of 3
    • The top edge of the display is secured with both glue and clips.
    • Gently pull the right edge of the display down slightly (in the direction of the Lightning port).
    • Insert your pick into the top-right corner of the phone.
    Ask FixBot
  14. iPhone 11 Taptic Engine Replacement: step 14, image 1 of 2 iPhone 11 Taptic Engine Replacement: step 14, image 2 of 2
    • Continue pulling the display down (toward the Lightning port) as needed in order to make a gap large enough for the pick.
    • Slide the pick to the top left corner and cut any remaining adhesive securing the display.
    • Don't insert your pick more than 3 mm, as you may damage the Face ID sensor array.
    Ask FixBot
  15. iPhone 11 Taptic Engine Replacement, Remove the suction cup: step 15, image 1 of 1
    • Pull the small nub on the suction cup to detach it from the front panel.
    Ask FixBot
  16. iPhone 11 Taptic Engine Replacement, Open the iPhone: step 16, image 1 of 3 iPhone 11 Taptic Engine Replacement, Open the iPhone: step 16, image 2 of 3 iPhone 11 Taptic Engine Replacement, Open the iPhone: step 16, image 3 of 3
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Prop the display up against something sturdy.
    • During reassembly, lay the display in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the display down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the display and make sure they aren't bent.
    Ask FixBot
  17. iPhone 11 Taptic Engine Replacement, Display Assembly: step 17, image 1 of 2 iPhone 11 Taptic Engine Replacement, Display Assembly: step 17, image 2 of 2
    • To access the screws in the following step, tilt the display by slightly lifting its lower edge.
    • Be careful not to strain or tear the display cables.
    Ask FixBot
  18. iPhone 11 Taptic Engine Replacement, Unscrew the battery connector cover: step 18, image 1 of 2 iPhone 11 Taptic Engine Replacement, Unscrew the battery connector cover: step 18, image 2 of 2
    Magnetic Project Mat
    $19.95
    Buy
    • Use a Y000 driver to remove the three 1.1 mm-long screws securing the battery connector bracket.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
    Ask FixBot
  19. iPhone 11 Taptic Engine Replacement, Remove the battery connector cover: step 19, image 1 of 1
    • Remove the bracket.
    Ask FixBot
  20. iPhone 11 Taptic Engine Replacement, Disconnect the battery: step 20, image 1 of 2 iPhone 11 Taptic Engine Replacement, Disconnect the battery: step 20, image 2 of 2
    • Use a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally contacting the socket.
    Ask FixBot
  21. iPhone 11 Taptic Engine Replacement, Unscrew the logic board cover screws: step 21, image 1 of 2 iPhone 11 Taptic Engine Replacement, Unscrew the logic board cover screws: step 21, image 2 of 2
    • Use a Y000 driver to remove the five 1.1 mm screws securing the logic board cover bracket.
    Ask FixBot
  22. iPhone 11 Taptic Engine Replacement, Remove the logic board cover bracket: step 22, image 1 of 1
    Ask FixBot
  23. iPhone 11 Taptic Engine Replacement, Disconnect the display: step 23, image 1 of 3 iPhone 11 Taptic Engine Replacement, Disconnect the display: step 23, image 2 of 3 iPhone 11 Taptic Engine Replacement, Disconnect the display: step 23, image 3 of 3
    • Use a spudger or a fingernail to disconnect the LCD panel cable connector.
    • Disconnect the digitizer connector next to it.
    Ask FixBot
  24. iPhone 11 Taptic Engine Replacement, Disconnect the front sensors: step 24, image 1 of 2 iPhone 11 Taptic Engine Replacement, Disconnect the front sensors: step 24, image 2 of 2
    • Use the point of a spudger or a fingernail to disconnect the front panel sensor assembly connector.
    Ask FixBot
  25. iPhone 11 Taptic Engine Replacement, Remove the display assembly: step 25, image 1 of 1
    Ask FixBot
  26. iPhone 11 Taptic Engine Replacement, Taptic Engine: step 26, image 1 of 2 iPhone 11 Taptic Engine Replacement, Taptic Engine: step 26, image 2 of 2
    • Use a Phillips driver to remove the three screws securing the Taptic Engine:
    • Two 1.8 mm screws
    • One 1.9 mm screw
    Ask FixBot
  27. iPhone 11 Taptic Engine Replacement: step 27, image 1 of 1
    • Remove the bracket covering the Taptic Engine flex cable connector.
    Ask FixBot
  28. iPhone 11 Taptic Engine Replacement: step 28, image 1 of 2 iPhone 11 Taptic Engine Replacement: step 28, image 2 of 2
    • Use a spudger to disconnect the Taptic Engine flex cable by prying it straight up from its socket.
    Ask FixBot
  29. iPhone 11 Taptic Engine Replacement: step 29, image 1 of 1
    • Remove the Taptic Engine.
    Ask FixBot
Repair didn’t go as planned? Check out our iPhone 11 Answers community for troubleshooting help.
14 other people completed this guide.
Jeff Suovanen
453,415 Reputation
259 Guides authored
iFixit Member of iFixit
Staff
123 Members
27,624 Guides authored
0 Guide Comments
Past 24 Hours: 13
Past 7 Days: 70
Past 30 Days: 360
All Time: 23,246
