iPad Pro 11" 3rd Gen Screen Replacement
  1. iPad Pro 11" 3rd Gen Screen Replacement, Prepare your iPad for disassembly: step 1, image 1 of 1
    • Allow your iPad's battery to fully drain before starting this repair. A charged battery may catch fire if damaged during the repair.
    • Unplug any cables and fully shut down your iPad.
    Ask FixBot
  2. iPad Pro 11" 3rd Gen Screen Replacement, Screen removal information: step 2, image 1 of 3 iPad Pro 11" 3rd Gen Screen Replacement, Screen removal information: step 2, image 2 of 3 iPad Pro 11" 3rd Gen Screen Replacement, Screen removal information: step 2, image 3 of 3
    • While your iPad looks uniform from the outside, there are delicate components under portions of the screen. To avoid damage, follow instructions exactly as written and note the following areas as you open your iPad:
    • Camera module, ambient light sensors, proximity senor, and front microphone
    • Display cables
    • Screen magnets
    • LCD edges
    Ask FixBot
  3. iPad Pro 11" 3rd Gen Screen Replacement, Heat the right edge: step 3, image 1 of 1
    • Apply a heated iOpener to the right edge of the screen for two minutes.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the screen and/or internal battery, so proceed with care.
    Ask FixBot
  4. iPad Pro 11" 3rd Gen Screen Replacement, Anti-Clamp instructions: step 4, image 1 of 3 iPad Pro 11" 3rd Gen Screen Replacement, Anti-Clamp instructions: step 4, image 2 of 3 iPad Pro 11" 3rd Gen Screen Replacement, Anti-Clamp instructions: step 4, image 3 of 3
    Tool used on this step:
    Clampy - Anti-Clamp
    $24.95
    Buy
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backward to unlock the Anti-Clamp's arms.
    • Place an object under your iPad so it rests level between the suction cups.
    • Position the suction cups near the middle of the right edge—one on the top, and one on the bottom.
    • Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
    • If you find that the surface of your iPad is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
    Ask FixBot
  5. iPad Pro 11" 3rd Gen Screen Replacement: step 5, image 1 of 3 iPad Pro 11" 3rd Gen Screen Replacement: step 5, image 2 of 3 iPad Pro 11" 3rd Gen Screen Replacement: step 5, image 3 of 3
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    Ask FixBot
  6. iPad Pro 11" 3rd Gen Screen Replacement: step 6, image 1 of 2 iPad Pro 11" 3rd Gen Screen Replacement: step 6, image 2 of 2
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • If your screen isn't getting hot enough, you can use a hair dryer to heat along the right edge of the iPad.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next step.
    Ask FixBot
  7. iPad Pro 11" 3rd Gen Screen Replacement, Insert an opening pick: step 7, image 1 of 3 iPad Pro 11" 3rd Gen Screen Replacement, Insert an opening pick: step 7, image 2 of 3 iPad Pro 11" 3rd Gen Screen Replacement, Insert an opening pick: step 7, image 3 of 3
    • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    • Apply a suction handle to the right edge of the screen, about 5 cm from the bottom edge.
    • Pull up on the suction handle with firm, constant pressure to create a gap just small enough to insert an opening pick.
    • Only create a gap small enough to insert an opening pick. Overbending the screen will damage it.
    • Insert the tip of an opening pick into the gap.
    • Don't insert the opening pick more than 5 mm or you may damage the LCD.
    Ask FixBot
  8. iPad Pro 11" 3rd Gen Screen Replacement, Separate the right edge adhesive: step 8, image 1 of 3 iPad Pro 11" 3rd Gen Screen Replacement, Separate the right edge adhesive: step 8, image 2 of 3 iPad Pro 11" 3rd Gen Screen Replacement, Separate the right edge adhesive: step 8, image 3 of 3
    • Insert a new opening pick in the gap you just created.
    • Slide the pick along the right edge to separate the adhesive.
    • When sliding near the volume buttons, don't insert the pick more than 2 mm or you'll damage the screen magnets.
    • Leave the pick in the top right corner to prevent the adhesive from re-sealing.
    Ask FixBot
  9. iPad Pro 11" 3rd Gen Screen Replacement, Heat the top edge: step 9, image 1 of 1
    • Apply a heated iOpener to the top edge of the screen for two minutes.
    Ask FixBot
  10. iPad Pro 11" 3rd Gen Screen Replacement, Top edge information: step 10, image 1 of 3 iPad Pro 11" 3rd Gen Screen Replacement, Top edge information: step 10, image 2 of 3 iPad Pro 11" 3rd Gen Screen Replacement, Top edge information: step 10, image 3 of 3
    • The top edge of the iPad contains the camera module, two ambient light sensors, the proximity sensor, and front microphone. These components are fragile and easily damaged if an opening pick is inserted too far. Only separate the adhesive in the marked locations to avoid damage.
    • The two ambient light sensors can be hard to see and can be located using a flashlight or by placing the iPad under a bright light.
    • Don't insert an opening pick more than 2 mm near the top left and right edges or you'll damage the ambient light sensors.
    • Don't insert an opening pick more than 1 mm near the middle of the top edge or you'll damage the camera module, proximity sensor, and front microphone.
    Ask FixBot
  11. iPad Pro 11" 3rd Gen Screen Replacement, Separate the top edge adhesive: step 11, image 1 of 2 iPad Pro 11" 3rd Gen Screen Replacement, Separate the top edge adhesive: step 11, image 2 of 2
    • Slide the pick along the top right edge, stopping when you reach the right ambient light sensor.
    • Don't insert the opening pick more than 5 mm.
    • Leave the pick in to prevent the adhesive from re-sealing.
    Ask FixBot
  12. iPad Pro 11" 3rd Gen Screen Replacement: step 12, image 1 of 3 iPad Pro 11" 3rd Gen Screen Replacement: step 12, image 2 of 3 iPad Pro 11" 3rd Gen Screen Replacement: step 12, image 3 of 3
    • Insert a new opening pick to the right of the ambient light sensor.
    • Slide the pick along the middle section of the top edge, stopping when you reach the left ambient light sensor.
    • Don't insert the pick more than 1 mm or you'll damage the proximity sensor and front microphone.
    Ask FixBot
  13. iPad Pro 11" 3rd Gen Screen Replacement: step 13, image 1 of 2 iPad Pro 11" 3rd Gen Screen Replacement: step 13, image 2 of 2
    • Insert a new opening pick to the left of the ambient light sensor.
    • Slide the pick along the top left edge, stopping when you reach the left ambient light sensor.
    • Once the top edge adhesive has been separated, you can remove the two picks near the ambient light sensors.
    Ask FixBot
  14. iPad Pro 11" 3rd Gen Screen Replacement, Heat the bottom edge: step 14, image 1 of 1
    • Apply a heated iOpener to the bottom edge of the screen for two minutes.
    Ask FixBot
  15. iPad Pro 11" 3rd Gen Screen Replacement, Separate the bottom edge adhesive: step 15, image 1 of 2 iPad Pro 11" 3rd Gen Screen Replacement, Separate the bottom edge adhesive: step 15, image 2 of 2
    • Insert a new opening pick in the bottom right corner below the existing pick.
    • Don't insert the opening pick more than 2 mm when sliding on the right edge.
    • Slide the pick around the bottom right corner to separate the adhesive.
    Ask FixBot
  16. iPad Pro 11" 3rd Gen Screen Replacement: step 16, image 1 of 2 iPad Pro 11" 3rd Gen Screen Replacement: step 16, image 2 of 2
    • Slide the opening pick along the bottom edge, stopping at the USB-C port.
    • Don't insert the opening pick more than 5 mm when separating the bottom edge adhesive.
    • Leave the pick in to prevent the bottom edge adhesive from re-sealing.
    Ask FixBot
  17. iPad Pro 11" 3rd Gen Screen Replacement: step 17, image 1 of 2 iPad Pro 11" 3rd Gen Screen Replacement: step 17, image 2 of 2
    • Insert a new opening pick to the left of the USB-C port.
    • Separate the remaining bottom edge adhesive.
    • Don't insert the opening pick more than 5 mm when slicing the bottom edge adhesive.
    • Leave the pick in the bottom left corner to prevent the bottom edge adhesive from re-sealing.
    Ask FixBot
  18. iPad Pro 11" 3rd Gen Screen Replacement, Heat the left edge: step 18, image 1 of 1
    • Apply a heated iOpener to the left edge of the screen for two minutes.
    Ask FixBot
  19. iPad Pro 11" 3rd Gen Screen Replacement, Left edge information: step 19, image 1 of 3 iPad Pro 11" 3rd Gen Screen Replacement, Left edge information: step 19, image 2 of 3 iPad Pro 11" 3rd Gen Screen Replacement, Left edge information: step 19, image 3 of 3
    • The left edge of the iPad contains several display cables. These cables are extremely fragile and easily damaged if an opening pick is inserted too far or at the wrong angle. Follow the instructions exactly as written to avoid damage.
    • The display cables are located within small indents of the frame and require an opening pick to be inserted at a 45° angle.
    • There are flat sections of the frame which require an opening pick to be inserted horizontally.
    Ask FixBot
  20. iPad Pro 11" 3rd Gen Screen Replacement, Separate the left edge adhesive: step 20, image 1 of 2 iPad Pro 11" 3rd Gen Screen Replacement, Separate the left edge adhesive: step 20, image 2 of 2
    • Insert an opening pick at a 45˚ angle just above the bottom left corner.
    • Don't insert the pick more than 5 mm or you'll damage the display cables.
    • Carefully slide the pick along the left edge, stopping when you reach the flat section of the frame.
    Ask FixBot
  21. iPad Pro 11" 3rd Gen Screen Replacement: step 21, image 1 of 2 iPad Pro 11" 3rd Gen Screen Replacement: step 21, image 2 of 2
    • Lower the opening pick so it is horizontal to the screen.
    • Don't insert the pick more than 5 mm.
    • Continue separating the left edge adhesive until you reach the next indented section of the frame.
    Ask FixBot
  22. iPad Pro 11" 3rd Gen Screen Replacement, Separate the remaining adhesive: step 22, image 1 of 1
    • Separate the remaining adhesive, making sure to follow the instructions exactly as written.
    • Slide the pick at a 45˚ downward angle and don't insert the pick more than 5 mm.
    • Slide the pick horizontally and don't insert the pick more than 5 mm.
    Ask FixBot
  23. iPad Pro 11" 3rd Gen Screen Replacement, Separate the screen from the frame: step 23, image 1 of 3 iPad Pro 11" 3rd Gen Screen Replacement, Separate the screen from the frame: step 23, image 2 of 3 iPad Pro 11" 3rd Gen Screen Replacement, Separate the screen from the frame: step 23, image 3 of 3
    • At this point, you've separated most of the screen adhesive. Lift the edges of the screen up slightly to check if there is any remaining adhesive.
    • Use an opening pick to remove any remaining adhesive keeping the screen stuck to the frame.
    • Grab the top right and bottom left corners of the screen.
    • Slowly slide the screen towards the bottom right corner to separate it from the frame.
    • Don't fully remove the screen as it is held in place by several ribbon cables underneath.
    • Shift the screen towards the bottom right corner of the frame until the ambient light sensor ribbon cable near the top edge is uncovered.
    Ask FixBot
  24. iPad Pro 11" 3rd Gen Screen Replacement, Unscrew the ambient light sensor cable bracket: step 24, image 1 of 2 iPad Pro 11" 3rd Gen Screen Replacement, Unscrew the ambient light sensor cable bracket: step 24, image 2 of 2
    FixMat
    $36.95
    Buy
    • Use a Phillips screwdriver to remove the two screws securing the ambient light sensor cable bracket to the logic board:
    • One 1.3 mm screw
    • One 2.0 mm screw
    • During reassembly, this is a good point to power on your iPad and test all functions before sealing it up. Be sure to power your iPad back down before you continue working.
    Ask FixBot
  25. iPad Pro 11" 3rd Gen Screen Replacement, Remove the ambient light sensor cable bracket: step 25, image 1 of 1
    Buy
    • Use a pair of tweezers or your fingers to remove the bracket.
    Ask FixBot
  26. iPad Pro 11" 3rd Gen Screen Replacement, Disconnect the ambient light sensor cable: step 26, image 1 of 2 iPad Pro 11" 3rd Gen Screen Replacement, Disconnect the ambient light sensor cable: step 26, image 2 of 2
    • Use the flat end of a spudger to disconnect the ambient light sensor cable by lifting straight up on the press connectors.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
    Ask FixBot
  27. iPad Pro 11" 3rd Gen Screen Replacement, Reposition the screen: step 27, image 1 of 3 iPad Pro 11" 3rd Gen Screen Replacement, Reposition the screen: step 27, image 2 of 3 iPad Pro 11" 3rd Gen Screen Replacement, Reposition the screen: step 27, image 3 of 3
    • Don't try to remove the screen yet, as it's still attached by delicate ribbon cables.
    • Grip the right edge of the screen and fold it open like a book.
    • Lay the screen down over the left edge of the iPad.
    Ask FixBot
  28. iPad Pro 11" 3rd Gen Screen Replacement, Unfasten the lower cable shield: step 28, image 1 of 2 iPad Pro 11" 3rd Gen Screen Replacement, Unfasten the lower cable shield: step 28, image 2 of 2
    • Use a Phillips screwdriver to remove the five screws securing the lower cable shield to the logic board:
    • Two 2.0 mm screws
    • Three 1.3 mm screws
    Ask FixBot
  29. iPad Pro 11" 3rd Gen Screen Replacement, Remove the lower cable shield: step 29, image 1 of 1
    Buy
    • Use tweezers or your fingers to grab and remove the lower cable shield.
    Ask FixBot
  30. iPad Pro 11" 3rd Gen Screen Replacement, Disconnect the display cables: step 30, image 1 of 3 iPad Pro 11" 3rd Gen Screen Replacement, Disconnect the display cables: step 30, image 2 of 3 iPad Pro 11" 3rd Gen Screen Replacement, Disconnect the display cables: step 30, image 3 of 3
    • Use the pointed end of a spudger to pry up and disconnect the top two display cables.
    Ask FixBot
  31. iPad Pro 11" 3rd Gen Screen Replacement, Disconnect the remaining display cables: step 31, image 1 of 3 iPad Pro 11" 3rd Gen Screen Replacement, Disconnect the remaining display cables: step 31, image 2 of 3 iPad Pro 11" 3rd Gen Screen Replacement, Disconnect the remaining display cables: step 31, image 3 of 3
    • Disconnect the two remaining display cables.
    Ask FixBot
  32. iPad Pro 11" 3rd Gen Screen Replacement, Remove the screen: step 32, image 1 of 1
    • Grip the right edge of the screen and lift it away.
    • During reassembly, before installing a screen, remove any remaining adhesive from the frame, and clean the glued areas with high-strength (>90%) isopropyl alcohol and a lint-free cloth. This helps prep the iPad for fresh adhesive and ensures that it will bond properly.
    • If you plan to reinstall your existing screen, remove any remaining adhesive from the back and clean the adhered areas with isopropyl alcohol.
    • Follow this guide to install pre-cut adhesive strips on your iPad before sealing it up.
    Ask FixBot
  33. iPad Pro 11" 3rd Gen Screen Replacement, LiDAR sensor assembly information: step 33, image 1 of 2 iPad Pro 11" 3rd Gen Screen Replacement, LiDAR sensor assembly information: step 33, image 2 of 2
    • The LiDAR sensor assembly is paired to the Face ID hardware. You'll need to transfer it to your replacement screen to keep Face ID functionality. The following steps show how to remove the sensor assembly and install it on your replacement screen.
    • The LiDAR sensor assembly is composed of four total sensors:
    • Two ambient light sensors
    • One proximity sensor
    • One microphone
    • You'll need to separate each sensor from the screen before removing the entire assembly.
    Ask FixBot
  34. iPad Pro 11" 3rd Gen Screen Replacement, Heat the top sensor assembly: step 34, image 1 of 1
    Ask FixBot
  35. iPad Pro 11" 3rd Gen Screen Replacement, Separate the ambient light sensors: step 35, image 1 of 2 iPad Pro 11" 3rd Gen Screen Replacement, Separate the ambient light sensors: step 35, image 2 of 2
    $3.99
    Buy
    • Insert one arm of your angled tweezers between the ambient light sensor and the screen.
    • You can also use a precision knife, but be careful not to damage the ribbon cable.
    • Pry up to separate the sensor from the screen.
    • This might take significant force.
    • Repeat this procedure for the other ambient light sensor.
    Ask FixBot
  36. iPad Pro 11" 3rd Gen Screen Replacement, Separate the proximity sensor: step 36, image 1 of 3 iPad Pro 11" 3rd Gen Screen Replacement, Separate the proximity sensor: step 36, image 2 of 3 iPad Pro 11" 3rd Gen Screen Replacement, Separate the proximity sensor: step 36, image 3 of 3
    • Insert one arm of your angled tweezers between the proximity sensor cable and the screen.
    • Slide the tweezers toward the screen while prying to separate the sensor from the screen.
    • This might take significant force and multiple iOpener heating cycles.
    Ask FixBot
  37. iPad Pro 11" 3rd Gen Screen Replacement, Peel away the tape: step 37, image 1 of 2 iPad Pro 11" 3rd Gen Screen Replacement, Peel away the tape: step 37, image 2 of 2
    • Peel off any tape covering the microphone.
    • Set the tape aside. You'll use it during reassembly.
    Ask FixBot
  38. iPad Pro 11" 3rd Gen Screen Replacement, Separate the microphone: step 38, image 1 of 3 iPad Pro 11" 3rd Gen Screen Replacement, Separate the microphone: step 38, image 2 of 3 iPad Pro 11" 3rd Gen Screen Replacement, Separate the microphone: step 38, image 3 of 3
    • Slide an opening tool under the microphone to separate its adhesive.
    • Pry up to separate the microphone from the screen.
    Ask FixBot
  39. iPad Pro 11" 3rd Gen Screen Replacement, Remove the LiDAR sensor assembly: step 39, image 1 of 3 iPad Pro 11" 3rd Gen Screen Replacement, Remove the LiDAR sensor assembly: step 39, image 2 of 3 iPad Pro 11" 3rd Gen Screen Replacement, Remove the LiDAR sensor assembly: step 39, image 3 of 3
    • Slide an opening pick under the LiDAR sensor assembly cable to separate it from the screen.
    Ask FixBot
  40. iPad Pro 11" 3rd Gen Screen Replacement: step 40, image 1 of 3 iPad Pro 11" 3rd Gen Screen Replacement: step 40, image 2 of 3 iPad Pro 11" 3rd Gen Screen Replacement: step 40, image 3 of 3
    • Continue sliding your opening pick under the LiDAR sensor assembly until it's completely separated from the screen.
    • Remove the LiDAR sensor assembly.
    Ask FixBot
  41. iPad Pro 11" 3rd Gen Screen Replacement: step 41, image 1 of 1
    Tesa 61395 Tape
    $8.95
    Buy
    • During reassembly, you'll have to perform the following:
    • Align the LiDAR sensor assembly on your replacement screen.
    • Use Tesa tape, or similar double-sided tape, to secure the cables to the screen.
    • Use E6000 adhesive, or similar adhesive, to secure the sensors to their cutouts on the screen.
    • Only apply adhesive to the edges of the sensors. Placing adhesive on the front will break them.
    Ask FixBot
  42. iPad Pro 11" 3rd Gen Screen Replacement, Display cable information: step 42, image 1 of 2 iPad Pro 11" 3rd Gen Screen Replacement, Display cable information: step 42, image 2 of 2
    • If your replacement screen didn't come with the two removable display cables, follow the next six steps to remove and transfer these cables.
    • The display cable connectors are located under a bracket near the bottom right corner of the screen.
    Ask FixBot
  43. iPad Pro 11" 3rd Gen Screen Replacement, Separate the non-removable display cable: step 43, image 1 of 3 iPad Pro 11" 3rd Gen Screen Replacement, Separate the non-removable display cable: step 43, image 2 of 3 iPad Pro 11" 3rd Gen Screen Replacement, Separate the non-removable display cable: step 43, image 3 of 3
    • Slide an opening pick under the non-removable display cable to loosen it from the bracket.
    Ask FixBot
  44. iPad Pro 11" 3rd Gen Screen Replacement, Unfasten the display cable bracket: step 44, image 1 of 2 iPad Pro 11" 3rd Gen Screen Replacement, Unfasten the display cable bracket: step 44, image 2 of 2
    • Use a Phillips screwdriver to remove the two 1.2 mm screws securing the display cable bracket.
    Ask FixBot
  45. iPad Pro 11" 3rd Gen Screen Replacement, Remove the display cable bracket: step 45, image 1 of 2 iPad Pro 11" 3rd Gen Screen Replacement, Remove the display cable bracket: step 45, image 2 of 2
    • Remove the display cable bracket.
    Ask FixBot
  46. iPad Pro 11" 3rd Gen Screen Replacement, Disconnect and remove the display cables: step 46, image 1 of 3 iPad Pro 11" 3rd Gen Screen Replacement, Disconnect and remove the display cables: step 46, image 2 of 3 iPad Pro 11" 3rd Gen Screen Replacement, Disconnect and remove the display cables: step 46, image 3 of 3
    • Use the flat end of a spudger to pry up and disconnect the narrow display cable.
    • Remove the narrow display cable. Set it aside for reassembly.
    Ask FixBot
  47. iPad Pro 11" 3rd Gen Screen Replacement: step 47, image 1 of 3 iPad Pro 11" 3rd Gen Screen Replacement: step 47, image 2 of 3 iPad Pro 11" 3rd Gen Screen Replacement: step 47, image 3 of 3
    • Disconnect and remove the wide display cable. Set it aside for reassembly.
    Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad Pro 11" 3rd Gen Answers community for help.
22 other people completed this guide.
Chayton Ritter
26,911 Reputation
105 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
18,408 Guides authored
5 Guide Comments
Sind original iPad Displays device lockt? Wenn ich zwischen zwei gleichen iPads die Displays austausche erwarten mich dann Probleme oder kann ich das ohne Schwierigkeiten machen?
braun bär - Reply Share
Is it possible to replace the LiDAR sensor assembly w/o losing the current Face ID configuration or is the original flex cable necessary to restore the function?
Isaiah Tate - Reply Share
The author did not address the rare earth magnets. Heap replacement screens do not come with either the ribbon cables (you covered this which is really important) and your iPad also has two small bar magnets comprised of two rare earth magnets each under the right bezels. They have specific polarization that will engage and hold down any flip cover case. If you remove them from your broken display with markings first, good, if one went flying as with my shattered screen I found the poles aligned quite nicely using my case cover to mark orientation. —CM
Carl son of Carl - Reply Share
The screw sizes/color coordinations are wrong, the 5 screws covering the screen ribbon and battery ribbon have 3 short screws and 2 long screws, the 2 long ones go up top and 3 short ones on bottom of cover plate.. and the upper lidar/ambient light ribbon cover the long screw goes up top and short screw on bottom of that cover plate.. the instructions color codes are exact opposite and this should be changed in instructions…. Annnnnd 500 for a %#*@ screen is flippin absurd wth is goin on ifixit I love u guys but this is starting to feel like a %#*@ apple store
Odyssey Diag - Reply Share
Just successfully completed this morning. I marked the correct orientation and transferred the cover magnets from the old display to the new. If you have a FDM 3D printer, the print bed is great for heating up the screen. I placed the iPad on a pre-heated 90C printer bed for a couple of minutes and the adhesive came off very easily.
Paul D - Reply Share
Past 24 Hours: 33
Past 7 Days: 474
Past 30 Days: 1,577
All Time: 55,356
