Google Pixel 6 Screen Replacement
  1. Google Pixel 6 Screen Replacement, Safety precautions: step 1, image 1 of 2 Google Pixel 6 Screen Replacement, Safety precautions: step 1, image 2 of 2
    • Allow your battery to drain below 25% before starting this repair. A charged battery may catch fire if damaged.
    • Fully power off your phone and unplug any cables.
    Ask FixBot
  2. Google Pixel 6 Screen Replacement, Anti-Clamp instructions: step 2, image 1 of 3 Google Pixel 6 Screen Replacement, Anti-Clamp instructions: step 2, image 2 of 3 Google Pixel 6 Screen Replacement, Anti-Clamp instructions: step 2, image 3 of 3
    Tool used on this step:
    Clampy - Anti-Clamp
    $24.95
    Buy
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • If your screen is cracked, cover it with a layer of clear packing tape to help the suction cup adhere.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your phone.
    • Position the suction cups near the bottom edge of the phone—one on the front, and one on the back.
    • Squeeze the cups together to apply suction.
    • If you find that the surface of your phone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
    Ask FixBot
  3. Google Pixel 6 Screen Replacement: step 3, image 1 of 3 Google Pixel 6 Screen Replacement: step 3, image 2 of 3 Google Pixel 6 Screen Replacement: step 3, image 3 of 3
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    Ask FixBot
  4. Google Pixel 6 Screen Replacement: step 4, image 1 of 3 Google Pixel 6 Screen Replacement: step 4, image 2 of 3 Google Pixel 6 Screen Replacement: step 4, image 3 of 3
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer or heat gun—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the phone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen frame when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next two steps.
    Ask FixBot
  5. Google Pixel 6 Screen Replacement, Loosen the display adhesive: step 5, image 1 of 1
    • Apply a heated iOpener to the screen to loosen the adhesive underneath. Apply the iOpener for at least three minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
    Ask FixBot
  6. Google Pixel 6 Screen Replacement, Insert an opening pick: step 6, image 1 of 3 Google Pixel 6 Screen Replacement, Insert an opening pick: step 6, image 2 of 3 Google Pixel 6 Screen Replacement, Insert an opening pick: step 6, image 3 of 3
    • Once the screen is warm to the touch, apply a suction handle to the bottom edge of the screen.
    • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction handle to adhere. Alternatively, very strong tape may be used instead of the suction handle. If all else fails, you can superglue the suction handle to the screen.
    • Lift the screen, including its safety frame, with the suction handle to create a small gap between the screen and the phone assembly.
    • Insert an opening pick into the gap between the screen frame and the phone assembly.
    • Make sure to insert your opening pick in the right position to avoid separating the screen from its safety frame instead of the phone assembly.
    • Slide the opening pick to the bottom right corner of the screen to slice its adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
    Ask FixBot
  7. Google Pixel 6 Screen Replacement, Slice the adhesive: step 7, image 1 of 2 Google Pixel 6 Screen Replacement, Slice the adhesive: step 7, image 2 of 2
    • Insert a second opening pick at the bottom edge and slide it to the bottom left corner of the screen to slice the adhesive.
    Ask FixBot
  8. Google Pixel 6 Screen Replacement: step 8, image 1 of 3 Google Pixel 6 Screen Replacement: step 8, image 2 of 3 Google Pixel 6 Screen Replacement: step 8, image 3 of 3
    • The screen of the Google Pixel 6 is not only held in place by adhesive but also small plastic clips. If your opening pick gets blocked during the screen removal procedure, it means you inserted your pick too deep underneath the screen. Only insert the tip of the opening pick (3-4 mm) when slicing the display adhesive.
    • Insert a third opening pick underneath the bottom left corner of the screen.
    • Slide the opening pick along the left edge of the screen to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
    Ask FixBot
  9. Google Pixel 6 Screen Replacement: step 9, image 1 of 3 Google Pixel 6 Screen Replacement: step 9, image 2 of 3 Google Pixel 6 Screen Replacement: step 9, image 3 of 3
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener or heat gun for 1-2 minutes to reheat it.
    • When you slice near the front facing camera, insert only the tip of the opening pick (2-3 mm) to avoid damaging or smearing the camera.
    • Insert a fourth opening pick at the top left corner of the screen.
    • Slide the opening pick along the top edge of the phone to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
    Ask FixBot
  10. Google Pixel 6 Screen Replacement: step 10, image 1 of 2 Google Pixel 6 Screen Replacement: step 10, image 2 of 2
    • Insert a fifth opening pick and slide it along the right edge of the phone to slice the remaining adhesive.
    • Do not try to remove the display all the way yet, the screen is still connected to the phone assembly.
    Ask FixBot
  11. Google Pixel 6 Screen Replacement, Open up the phone assembly: step 11, image 1 of 3 Google Pixel 6 Screen Replacement, Open up the phone assembly: step 11, image 2 of 3 Google Pixel 6 Screen Replacement, Open up the phone assembly: step 11, image 3 of 3
    • Avoid straining the display cable during the following procedure.
    • Carefully open the right side of the screen to the left side of the phone assembly like you would open a book.
    Ask FixBot
  12. Google Pixel 6 Screen Replacement, Remove the display cable bracket: step 12, image 1 of 3 Google Pixel 6 Screen Replacement, Remove the display cable bracket: step 12, image 2 of 3 Google Pixel 6 Screen Replacement, Remove the display cable bracket: step 12, image 3 of 3
    Buy
    • Use a pair of tweezers to carefully unhinge and remove the metal bracket sitting on top of the display cable connector.
    • Make sure to keep this component to reinstall it during reassembly.
    Ask FixBot
  13. Google Pixel 6 Screen Replacement, Disconnect the display cable: step 13, image 1 of 2 Google Pixel 6 Screen Replacement, Disconnect the display cable: step 13, image 2 of 2
    • Use a spudger to disconnect the display flex cable by prying the connector straight up from its socket.
    Ask FixBot
  14. Google Pixel 6 Screen Replacement, Remove the screen: step 14, image 1 of 2 Google Pixel 6 Screen Replacement, Remove the screen: step 14, image 2 of 2
    • The back of the Pixel's screen is very fragile. Even a small scratch or dent can damage the screen. To prevent damaging your screen or replacement screen:
    • When handling your screen, grip it by its edges.
    • When placing the screen on your work area, make sure nothing is touching the bottom of the screen. Consider placing it on a soft, lint-free cloth.
    • Remove the screen.
    • Check if your replacement screen comes with the front camera plastic bracket. If not, use a spudger to pry the bracket from the old screen and adhere it to the new one using some double-sided tape.
    Ask FixBot
  15. Google Pixel 6 Screen Replacement, Reassembly tips: step 15, image 1 of 1
    • During reassembly:
    • If you replaced the screen, check the front-facing camera hole on the screen and remove any remaining protective liners in it.
    • Remember to reinstall the display cable bracket.
    • This is a good point to test your phone before sealing it up. Temporarily connect your screen, power on your phone, and make sure it works as expected. Before continuing with reassembly, power off your phone and disconnect the screen.
    • Follow this guide if you're using custom-cut adhesives for your device.
    • Follow this guide if you're using a pre-cut adhesive card.
    • If you're installing a new screen, follow this guide to calibrate the fingerprint sensor.
    Ask FixBot
If possible, turn on your device and test your repair before installing new adhesive and resealing.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
191 other people completed this guide.
Dominik Schnabelrauch
261,711 Reputation
682 Guides authored
81 Guide Comments
Ordered the official Google Pixel 6 display part from iFixit and followed this guide, which worked well. However, it's probably worth adding that you may need to manually calibrate the display once it's installed if the phone is throwing up fingerprint reader errors (which is what happened to me). You can do that via this tool from Google: https://pixelrepair.withgoogle.com/udfps
Mark Walton - Reply Share
The best advice when performing this procedure is.
oswaldocb25 - Reply Share
The guide worked great, thanks! :D
Warning to others though: Careful what you buy! The genuine display was out of stock so I bought from a different source which didn't come with a fingerprint reader or display adhesive. My fault for not paying attention when buying, but fair warning to everyone else to double check. I hadn't even considered the reader being glued to the screen but not included on replacement parts. The adhesive is an easy purchase, but not sure how hard the fingerprint reader will be. I might be back to unlocking with a pin like some kind of caveman!
Jonathan Michaud - Reply Share
Nvm, found the guide for the fingerprint reader replacement. Hopefully I can just move this one over.
I'd second this warning as well - from what I eventually found online, when you try to calibrate the fingerprint reader with an aftermarket screen, you'll get a profile error that doesn't allow you to proceed. This is because the screen profile isn't loaded on Google's Servers, not the fingerprint reader. So essentially if you get an aftermarket screen, Google won't allow you to calibrate the fingerprint reader :(
Aadi Bhamidipati - Reply Share
Past 24 Hours: 68
Past 7 Days: 534
Past 30 Days: 2,361
All Time: 255,413
