Repair information and guides for the fifth generation of iPhone. Model: A1387
2193 Questions View all
very challanging restore situation 4s error 1 error 3194
Hi,
I just purchased and IPHONE 4s from Ebay 16GB
Seller said it was stuck to Itune connect loop
I took it off from recovery mode through an APP
downloaded ITUNES and tried to recover to latest firmware
but then got error 1
I then try to recover it on over older firmware and then got another error 3194 (please don't tell me to fix the host file in WIN 7 and I have already checked it and there is nothing in there.)
each time different error
Also I don't know how and where I can find some SHSH blob for this phone to downgrade it to earlier firmware.
Also I was wondering could this be due to faulty LOGIC Board ? even if I replace it can i still update/restore to latest firm where or do I need to find SHSH blob for it as well.
Please help I will highly appreciate it.
Thanks,
Zasid
Score 2
1 Comment
One important thing when I updated from latest Itune it did pick up and the apple logo progress bar showed up however it got stuck at 755 and gave error 1
by
Add a comment
Chosen Solution
This is a hardware fault--have s look at the board and see if you can find the damage, you may get lucky. Forget about shsh blobs, you gotta fix that board!
3 Comments:
I am suspecting the same that its the board fixing the board means buying a second hand working phone :)
by
Hi Zasid--you just wrote me an email asking me to look at this question. I think this lady--jessabethany--is giving you good advice ;)
Jessa from iPad Rehab
by
Oops sorry my bad :)
by
Add a comment
Most Helpful Answer
It is not possible to downgrade iPhone 4s, with or without SHSH blob. So if you try any version other than the latest one , you'll always get error 3194.
Score 1
Add a comment
Error 1 to my knowledge is not fixable ists a hardware fault
1 Comment:
I have read about it too that error 1 is not fixible but then why am I getting the other error when I update it to other lower level firmware.
So could be this be a logic board problem ?
by
Add a comment
Hi,
Have you tried changing the battery?
I once had a error 1 because of a faulty battery and changing it fixed my problem
1 Comment:
I tried to charge it first for a good 1 hour or so to be sure battery is full before performing the upgrade phone seems to turn on and everything however I get these error as mention. I think its the board. But I will keep your tip in mind.
by
Add a comment
error 3194 is not a hardware fault message. its a 'host' error.
TCP/IP settings of ur internet connection error
exit iTunes...
Locate your hosts file in Windows c:\windows\system32\drivers\etc\hosts
Use notepad to open the hosts file with Administrator privileges
Add the following line to the very bottom of the hosts file:
#74.208.10.249 gs.apple.com
if 74.208.10.249 gs.apple.com is already exist then in the host file you need to add # just before it #74.208.10.249 gs.apple.com
then restart pc & try again...
1 Comment:
Hey Takir ,
Is one of the most confusing error some people say its hardware fault and some says ite the host file based on my research.But thanks for posting and sharing :)
by
Add a comment
same here :-/ tried every thing
Add a comment
Add your answer
zasid will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 4
All Time: 4,467
