Repair information and guides for the fifth generation of iPhone. Model: A1387
2193 Questions View all
Question Closed
iPhone 4s upper antenna
Hi,
If I remove upper antenna from iphone 4s,is it possible to make or receive calls? (forget wifi)
Add a comment
Chosen Solution
This is just for wifi/Bluetooth. If you remove this antenna, cellular function will still work perfectly.
Score 1
1 Comment:
great. . thankx for answer.
by
Add a comment
Is your question perhaps "I removed this part and now my phone is on searching--is this related?"
If so, then the answer is no--unrelated.
2 Comments:
yeah you also correct. .thanx
by
I had a feeling that would be the story----your phone will be 'searching' after any repair that disconnects the battery until the phone connects to WiFi and sets the date/time correctly. You can manually enter the correct date/time and see if the phone finds service.
If not, then look really really closely at the edge of the board for pry damage from battery removal. This is a common cause of searching/no signal after unrelated repair.
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 247
