Model M8413 or A1007 / 600, 700, 800, or 900 MHz G3 processor
36 Questions View all
Question Closed
I want to know how to go to wireless internet?
I can get online with an ethernet cable but would like to go wireless. I dont have the previous users password. I want to make my own network on my linksys router. How do i do that?
1 Comment
Here is a link to reset your Linksys router. Once that's done set up your airport card--just follow machead3's directions to do that. Ralph
http://linksys.custhelp.com/cgi-bin/link...?...
by
Add a comment
Chosen Solution
Check that you have an Airport (wireless) card
Go to Applications->Utilities->System Profiler launch it and look under Network:->Airport
  • If you have a card its type will be listed.
  • Use System Preferences->Network to enable the Airport Card, and set its position in your means of communication.
    • You might want to disable modem if it's still in there
  • With airport on, and a wireless network in range '' it should show up under the Airport icon in the Menu Bar.''
For what it's worth there's no need for a password unless you are not the Administrator. With the proper System CD you can reset a pass word.
  • If you can add a new account you can give that user Administrator rights.
Good Luck,
N.
Add a comment
Add a comment
Which router do you have? Does it have wireless?
Are you saying that you can't connect to another wifi network or you are not able to access your own router?
Score -1
1 Comment:
This is not an answer and should be a comment, delete this and post it as a comment and your rep will be restored.
by
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,194
