Click Image To Zoom
Customers also bought
Small Suction Cup
$2.95
Home Tech Toolkit
$24.95
Installation Guides
MacBook Pro 13" Unibody Early 2011
Difficulty: Moderate
MacBook Pro 13" Unibody Mid 2009
MacBook Pro 15" Unibody 2.53 GHz Mid 2009
MacBook Pro 15" Unibody Early 2011
MacBook Pro 15" Unibody Late 2008 and Early 2009
MacBook Pro 15" Unibody Mid 2009
MacBook Pro 15" Unibody Mid 2010
MacBook Pro 17" Unibody
MacBook Unibody Model A1278
MacBook Unibody Model A1342
Compatibility
| MacBook Pro 13" Unibody Early 2011 |
| MacBook Pro 13" Unibody Mid 2009 |
| MacBook Pro 13" Unibody Mid 2010 |
| MacBook Pro 15" Unibody 2.53 GHz Mid 2009 |
| MacBook Pro 15" Unibody Early 2011 |
| MacBook Pro 15" Unibody Late 2008 and Early 2009 |
| MacBook Pro 15" Unibody Mid 2009 |
| MacBook Pro 15" Unibody Mid 2010 |
| MacBook Pro 17" Unibody |
| MacBook Pro 17" Unibody Early 2011 |
| MacBook Unibody Model A1278 |
| MacBook Unibody Model A1342 |
Stories
My Problem
I use my computer for work, so I figure, if there's any way to make it better, it's almost always going to be worth it. I already installed 16GB of RAM, so I figured the next step was an SSD. I wanted the fastest I could get, but to get one big enough AND super fast would be extremely expensive. So I got a 240GB, 500MB/s one, and instead of replacing my hard drive, I used this to have both.
My Fix
In the end it all worked out well, but there were a couple issues. First, I figured since both my hard drive and optical bays were SATA 3, I could just put the SSD in the optical bay, and it would be less work. It's been said before, but I'll say it again: it doesn't work. For whatever reason, your SSD won't be recognized in the optical bay of a MacBook Pro. The other problem I had, was that the T6 screwdriver I got didn't actually fit the screws, it was too big. But I'm fairly certain that was just a bad screwdriver, because I got a T7 and that fit. Now I have 130 screwdrivers (they only sell them in sets at Canadian Tire). Otherwise the operation was pretty straightforward
There is one issue I still have though: there is a bit of a buzzing sound when I play music loudly, at certain frequencies. I think this may be because to put the drive in the enclosure, I unscrewed the top of the enclosure, so I could push it in straight. After putting it back, it didn't fit together quite the same anymore; I think maybe it just wasn't made for that. I can't think of anything else that could be buzzing.
My Advice
1: Don't put a SATA 3 SSD in your optical bay; it won't work (hard drive will though).
2: Don't unscrew the top of this thing; it works fine to just put the drive in on the slight diagonal.
3: When putting those 3 torx screws back in, put one of the left ones in half way, then start the other one; otherwise you won't be able to start the other one.
My Problem
I destroyed my right fan. Then I noticed I do rarely use my CD. So why not to replace my CD with an SSD and put all the system and software on to the SSD and leave all personal data onto the original HD? The speed of my mac is now incredible. For example: CATIA CAD in Parallels with starts now within 20 seconds instead of 3 minutes! (MacBookPro)
My Fix
Without Problem! Only the screwdriver set i got additionally with an iPhone front cover is really a cheap solution and is worth nothing. But the iPhone front cover, the fan and the SSD installation set work well!
My Advice
Don't use the screwdriver from iFixit. You damage your screws. But repair guide and spare parts are excellent! Specially for the iPhone front cover I got few weeks ago.
My Problem
It wasn't really a problem, more of an upgrade. So I have a Mac Mini Server and a 13" Mac Book Pro. I find that I barely use the optical drive in my Mac Book Pro and decided to take it out and install a 500 GB HD from my Mac Mini Server in place of the optical drive by using the Optical Bay I got from ifixit. I noticed that the boot time for the Mac Book Pro got a little longer when I upgraded to Lion so I purchased a solid state drive and swapped it out with the boot drive. Now the Mac Book Pro boots up in like 3 seconds. The 320 GB boot drive from the Mac Book Pro is now the Boot drive for my Mini Server while using the second 500 GB drive as storage.
My Fix
The swapping process took awhile but with the help of ifixit, it went pretty smoothly. I used the Mac Mini Hard Drive Replacement guide and Macbook Pro Optical Drive Replacement guide to help me out. The 26 Piece Bit Driver Kit that I got from ifixit was very helpful.
My Advice
My advice is, take your time, there are a lot of small screws in both of these machines. If you do things too quickly you may end up losing some of them. And make sure you read over the repair guides once before starting the projects. And since both my laptop and desktop were down I couldn't use the guides online. Another recommendation is print the guides for reference.
My Problem
My 160GB HD was too small for my ever expanding Race Track Video collection. To top it off my MAC began to run slower, so adding a storage HD was a must.
My Fix
The repair went fine except some of the mounting holes had to be modified with a pair of needle nose pliers. The new 500GB HD boot up perfect and I moved over 110GB of music and video with no problems by configuring iMovie and iTunes to save to the new HD. Kudos iFix-it!!!!!!!!!!
My Advice
Do this if you do not use your optical drive!
My Problem
My computer is becoming older and older and I wanted to refresh it so i bought an ssd and a hard drive enclosure to keep my hdd
My Fix
The repair was really easy, following each step of the tutorial, it took me something like 15minutes to install the hard drive enclosure.
My Advice
This is easy! You should definitely do it!
My Problem
Just because your computer has a large hard drive with 7200 RPMs doesn't mean it's automatically going to sweep through everything in a flash. If you only have one hard drive installed on your machine, that means that one hard drive is doing all the work--it's performing the software functions as well as accessing files that you're working on. Depending on what kind of work you're doing and how many apps you're running simultaneously, this can be a lot of work for one set of hands to work on! By adding another hard drive to your machine and configuring it appropriately, you can add another set of hands to help share the workload.
I recently switched out my MacBook Pro's stock HDD for a 750GB 7200RPM drive and maxed my RAM to 8GB. Everything performed beautifully. But I still knew that my machine wasn't performing up to it's full potential. After doing some research, I decided that pairing an SSD with my existing HDD would unlock its full potential. The catch was that I would have to sacrifice my optical drive to make room. No problem. I never use it anyway!
My Fix
This repair is a bit more ambitious than just switching out a hard drive or swapping out RAM. Nevertheless, the guide made it simple to perform. Unfortunately, I got so caught up in getting the task done that I forgot to take pics! Anyway, after all was said and done, the machine performed just as I expected it to--record boot times and unparalleled performance in comparison to it's previous setup! Now I'd say that my MacBook Pro is flying the way it should be.
My Advice
If you want to unleash your Mac's true potential, a dual hard-drive setup is the way to go. I decided to pair a 60GB SSD (for speed) with a 750GB/7200RPM HDD (for storage). The SSD is dedicated solely to the OS and apps while the HDD is dedicated to things like my iTunes library, downloads, and photos. This allows the two drives to work simultaneously to their full potential, because one is handling the load of the software functions while the other one just accesses files. If you don't use your optical drive much, or at all, this is probably the best upgrade you can perform on a MacBook Pro.
Related Questions
2 Answers 0 Score |
I'd like to know the size of the optical bay. |
1 Answer 0 Score |
Chage superdrive or add a new HDD |
2 Answers 0 Score |
How to uprade MacBook Pro superdrive to ssd |
1 Answer 0 Score |
Does the logic board have 1 or 2 SATA ports? |
1 Answer 0 Score |
SSD Hard Drive Replacement Choices |
