Shop the Holiday Gift Guide
Introduction
Sometimes, getting to the heart of an issue, is being pedantic about language.
A glitch, for all intents and purposes, is simply an error. This could be used to describe numerous experiences. So rather than detailing all the various causes in full, it’s pretty likely the issue you are having is discussed on another page, worded differently.
Screen issues usually come in two flavors—touch and image. In older iPhones, you may even run into issues with backlight. But it's important to bear in mind which system within the display is affected.
Causes
The iPhone Ghost Touch page details how to handle unexpected or phantom touch inputs. Your phone may be acting as though you are swiping or selecting when you are not touching it at all.
The iPhone Touch Screen Not Working page addresses no touch input at all, or dead areas on the display. Whether the issue is intermittent or seems permanent, the causes are the same.
Problems related to the way a screen appears or the quality of the image onscreen are independent of touch issues and covers a wide spectrum of things. Try to categorize the issue you're having more specifically. Is it flickering? Are the colors abnormal? Is it only displaying a bunch of lines?
- The iPhone Lines on Screen page covers what to do if your phone has lines on the screen. This could be a single green line, purple line, or multiple vertical lines of varying color. The issue may be constant or intermittent.
- The iPhone Frozen Screen page gives guidance for how to deal when your iPhone is frozen, or stuck on the same image.
- If you're experiencing issues with flicker, or there's no image on the screen (especially if touch appears to work properly) the iPhone Black Screen page will lay out the possibilities.
You're seeing solutions for Apple iPhone. Select your model to find parts for your device.
Related Problems
Apple iPhone
27 problems · View all
- Ghost Touch
- Touch Screen Not Working
- Lines on Screen
- Frozen Screen
- Black Screen
- Battery Draining Fast
- Not Charging
- Keeps Restarting
- Randomly Shuts Off
- Overheating
- is Charging but Won't Turn On
- Won't Turn On
- Home Button Not Working
- Blurry Camera
- Volume Buttons Not Working
- Invalid or No SIM
- Camera Black Screen
- Liquid Detected in Lightning Connector
- Stuck on Apple Logo
- Won't Connect to WiFi
- No Sound
- Backlight Not Working
- Touch ID Not Working
- Bluetooth Not Working
- Slow Charge
- Apps Not Downloading on iPhone
Describe your problem in your own words
