SodaStream Source Won't Carbonate
If your SodaStream Source is producing flat soda or soda without enough bubbles, try the following solutions (roughly in order from easiest to hardest).
Causes
When using the SodaStream Source to make soda, using warm water generally results in fewer bubbles. Cold water is recommended for best results and more bubbles. Clean out the carbonation bottle and refill it with cold, unflavored water, and try to use the machine again.
2
For fizzier soda, SodaStream recommends using unflavored carbonated water. The soda will have more overall fizz because you are adding more carbonation, to begin with. You should not be using juice, flat soda, or any other previously flavored liquids. Clean out the carbonation bottle and refill it with clean, unflavored, carbonated water, then try to use the machine again.
3
If your SodaStream is producing soda with little carbonation, replace the carbon dioxide cylinder with a full one.
Describe your problem in your own words
View statistics:
Past 24 Hours:1
Past 7 Days:19
Past 30 Days:127
All Time:22,642
