Nokia 2780 Flip is Slow During Use
If your Nokia 2780 Flip is slow to respond or or lagging when using your phone, follow this troubleshooting guide for potential solutions.
Causes
When the phone attempts to reconnect to a weak network repeatedly, the phone will perform slowly.
  • Move to an area with a better network connection
  • Turn Airplane Mode on and off
  • Restart the phone
  • Remove & reinstall, or replace the SIM card
2
When the battery is weak or the voltage lowers under load, the phone might freeze, slow down, or fully shut down.
  • Ensure the phone is charged to at least 50% before long uptime
  • Avoid using the phone while charging to prevent overheating
  • Use the original charger and cable, or check with HMD support for compatible chargers if you need to replace.
3
Sometimes the phone may be slow after using several apps concurrently, an app update fails while in mid-install, the KaiOS app cache is corrupted, or there is insufficient RAM due to heavy phone use.
  • Close all open apps by holding the Back button for 3-5 seconds until the “Close All Apps’ pop ups appears.
  • Update any apps that are in mid-installation.
  • Restart the phone every few days by holding the power button, choosing “Power Off” and turning it back on after 1 minute.
4
A frozen screen can mean that the RAM is full, an app is entering a runaway loop, background sync spikes, the CPU is throttled up due to low battery voltage, or the system process has stalled.
  • Hold the power button for 10 seconds to restart the phone
    • If the phone vibrates or the screen begins to flash continuously, hold the power button until it shuts off.
  • Hold the Back button for 3-5 seconds to force the current app to close.
  • Remove the battery:
    • Take off the back cover
    • Wait 5 seconds
    • Insert the battery and power on the phone
5
The Nokia 2780 Flip has a total of 4 GB, with system files taking up most of this space. When the storage is low, the phone becomes slow.
  • Delete any apps that are not used by opening Menu > Apps > Options > Delete
  • Delete old MMS by opening Messages > Apps > Options > Delete Thread
  • Move photos or videos to an SD card using Menu > Gallery > Options > Move to SD Card
6
The KaiOS software being dated can cause the phone to slow down due to an outdated carrier configuration, security patches missing, app compatibility issues, or KaiStore app updates.
  • Press the volume up key and the power button simultaneously for about 15 seconds (or until phone vibrates) for a soft reset.
  • The phone will turn off and restart.
  • To update the software: Navigate to Settings > System > System update > Check for update to check if updates are available.
7
The Nokia 2780 can slow down when there is corrupted SIM toolkit data, SMS not received from the carrier, not rebooting after switching the SIM card, or an incorrect APN.
  • Open the APN menu under Settings > Network & Connectivity > Mobile Network > Access Point Names
  • Find the APN profile and compare it to your carrier's APN
  • Edit the APN to match your carrier
  • If you don’t know your carrier’s APN, find their support page or contact customer support.
8
If the phone gets hot, the processor will reduce its performance to protect the internal hardware. This can cause the phone to lag or have a delayed response.
  • If the phone feels warm to the touch, allow the phone to cool down before using it again
  • Do not leave the phone in direct sunlight
  • Close any background apps
  • If possible, remove the battery to allow it to cool faster
9
A corrupted or low-speed SD card can cause the File Manager, Camera, or Gallery to respond slowly.
  • Take out the SD card and use the phone without it to see if it runs smoothly
  • Save the files and reformat the SD card
  • Change the SD card with a Class 10 or higher SD card
  • Avoid any previously damaged SD cards
10
If the internal flash storage starts to fail, the phone may reboot, freeze, or work slowly while opening apps.
  • Restart the phone by holding the power button down for 10 seconds
  • Delete any unused apps or messages stored on the device
  • Back up any important files if the phone fully fails
    • Navigate to Settings > System > Backup, and switch backup on.
  • Move important files to your computer:
    • With your phone powered on, plug it into your PC using the USB cable. On your PC, go to My Computer or This PC and open your device to start transferring files.
11
If the system update fails or the firmware malfunctions, the phone may crash or freeze.
  • Restart the phone
  • Check for current system updates
    • Open the Menu/Apps list
    • Go to Settings
    • Scroll to Device
    • Choose Device Information
    • Select Software Update
    • Press Download/Check for Updates
    • If there is an available update, choose Install
  • Back up the data and perform a factory reset. *Please note that this wipes all of the phone's previous information
    • Open Menu
    • Go to Settings
    • Scroll to Device
    • Find Device Information
    • Select Reset Phone
    • Select Reset or Erase all data
    • Enter the phone passcode
    • Confirm the reset
  • How to factory reset my phone
12
If the SIM toolkit becomes corrupted, the phone may attempt to constantly load carrier settings, which will slow down the system.
  • Remove the SIM card for 30 seconds and reinstall the card
  • Restart the phone
  • Reset the network settings
  • Open the Menu
  • Go to Settings
  • Scroll to Network & Connectivity
  • Select Mobile Network
  • Choose Reset Settings or Network Settings Reset
  • Confirm the reset
  • Replace the SIM card
Describe your problem in your own words
View statistics:
Past 24 Hours:2
Past 7 Days:5
Past 30 Days:41
All Time:240
