Guides
Background
The Nokia 2780 flip was released in late 2022 by HMD Global as part of Nokia's modern line of simplified mobile phones. The Nokia 2780 flip is a 4 G LTE-enabled device designed for “digital detoxing and accessibility” for users who prefer basic communication features over complex or full-feature smart phones. The device runs on KaiOS 3.1, which allows access to basic apps such as messaging, web browsing, and Google services while maintaining a traditional flip-phone interface.
At launch the device retailed for $89.99, making it a low-cost alternative for smart phones. Currently, this device is only available for purchase in used/refurbished condition through retailers such as Amazon or BestBuy. Depending on the retailer and condition of the device, it can be purchased at the average cost of $79 - $99.
The Nokia 2780 Flip incorporates several aspects that are vulnerable to wear and failure over time. Common failures associated with flip phones include hinge degradation; this can lead to the loss of the clamshell's closing ability, and flex cable wear that can cause display issues, including screen failure. This device also relies on a removable lithium-ion battery, which may lose its capacity over time and might require replacement upon extended use.
Another source of potential issues can be from keypad wear, lag in responsiveness, and charging port deterioration. This can occur from repeated insertion cycles or the accumulation of debris. These common failures highlight the importance of repairability and maintenance to extend the life of the Nokia 2780 Flip.
Identification
The Nokia 2780 Flip can be identified by its dark gray plastic shell, with a rectangular shape. It has a dark gray removable rear cover with the battery placed beneath it. The hinge located in the center of the device allows the phone to flip open in one continuous movement. When opened, a screen is attached to the top of the hinge with a keyboard attached to the bottom half of the hinge. A 5 MP camera with LED flash is located on the back of the device. The Model number (TA-1420) can be found beneath the battery after removing the back cover.
Technical Specifications
Dimensions:
  • 202.10 x 58.00 x 19.50 mm
Weight:
131.20 g
Power:
  • Li-Ion 1450 mAh
Screen:
  • 2.7-inch TFT LCD Display with a resolution of 240 x 320 pixels
  • Pixel Density of 148 ppi
Camera:
  • Single 5 MP rear camera with LED flash
Storage:
  • 4 GB Internal Storage
  • 512 MB RAM
Software:
  • KaiOS 3.1
Connectivity:
  • GSM, HSPA, and LTE networks are supported
  • Includes USB, Bluetooth, GPS, and Wi-Fi connectivity
Additional Information
For any additional information needed, refer to these sources.
Nokia 2780 Flip Support on HMD
Nokia 2780 flip User guide
Nokia 2780 Flip Specs and Features on Phones Data
Nokia 2780 Flip on Amazon
Past 24 Hours: 7
Past 7 Days: 30
Past 30 Days: 98
All Time: 612
