Causes
When the dustbin has reached capacity or is reaching capacity, the vacuum cannot correctly pick up dirt or debris.
- Locate and remove the dustbin from the vacuum and empty it over the trash can by tapping multiple times until all debris is out.
- If you use water, ensure the bin is completely dry before putting it back into the vacuum.
# Regularly emptying the dustbin after each use helps maintain suction power.
Lefant recommends cleaning the HEPA filter at least once a week.
- Remove the dust bin and take out the filters.
- Use the brush on the docking station or your own to remove any access debris inside the filter.
- If not cleaned thoroughly, you might need to replace filters completely. Follow this guide to replace the filters.
Lefant M210 Dustbin Filters Replacement
- No estimateModerate
Buildup in the brushes will limit the vacuum suction
- Turn off the vacuum
- Follow this guide to remove the brushes
- Clear debris and clean brush attachments
- If the buildup is too significant, you may need to use backup brushes.
- Reattach the brushes
Lefant M210 Brush Replacement
- 4 - 8 minutesEasy
Describe your problem in your own words
View statistics:
Past 24 Hours:6
Past 7 Days:14
Past 30 Days:52
All Time:1,007
