Causes
Problem: The camera lens is physically blocked by the built-in privacy shutter.
Solution:
- Locate the small slider above the display.
- Move it to open the camera shutter.
- Test the camera in the Windows Camera app or video-conferencing software.
Guide Placeholder: [Privacy shutter check guide – coming soon]
Problem: Windows privacy settings may prevent apps from accessing your camera.
Solution:
- Open Settings → Privacy → Camera.
- Turn Camera access for this device ON.
- Enable Allow apps to access your camera.
- Scroll down and make sure the specific apps (Zoom, Teams, etc.) have camera access.
- Restart the app and test the camera.
Guide Placeholder: [Windows camera permissions guide – coming soon]
Problem: The camera may be disabled or unrecognized by Windows.
Solution:
- Press Windows + X → Device Manager.
- Expand Cameras or Imaging Devices.
- Right-click HP HD Camera → Enable device (if disabled).
- If already enabled, choose Update driver → Search automatically.
- Restart your computer and test the camera.
Guide Placeholder: [Device Manager camera enable/update guide – coming soon]
Camera Driver Is Outdated or Missing
Problem: Missing or outdated drivers can prevent camera operation.
Solution:
- Visit HP Support and search for HP EliteBook 830 G6.
- Download and install the latest camera driver for your Windows version.
- Restart the laptop and test the camera.
Guide Placeholder: [Camera driver update guide – coming soon]
Problem: Security settings in BIOS may disable the camera.
Solution:
- Restart the laptop and press Esc repeatedly at startup.
- Press F10 to open BIOS Setup.
- Go to Security → Device Security.
- Locate Integrated Camera and set it to Enabled.
- Save changes and exit BIOS.
- Test the camera in Windows.
Guide Placeholder: [BIOS camera enable guide – coming soon]
Problem: Hardware issues like a loose ribbon cable can stop the camera from working.
Solution:
- Power off the laptop and remove the bottom cover.
- Check the camera ribbon cable between the display and motherboard.
- Reseat the cable if loose.
- If the camera module is damaged, it may need replacement.
Replacement Part: HP HD Camera Module (Part # L13868-001)
Guide Placeholder: [Camera module replacement guide – coming soon]
Problem: Physical impact or liquid damage can permanently break the camera.
Solution:
- Replace the integrated camera using the HP Maintenance and Service Guide.
- If under warranty, contact HP Support for repair or replacement.
Guide Placeholder: [Camera replacement service guide – coming soon]
Describe your problem in your own words
