Dell Venue Pro Battery Not Charging
If your Dell Venue Pro does not show a charging icon and the battery level does not increase when connected to a charger, follow this page for possible solutions.
Causes
  • Inspect the cable and adapter for visible damage.
  • Test them on another compatible device.
  • If they fail, replace them with Dell-approved accessories.
2
  • Look for dust, lint, or corrosion inside the port.
  • Clean gently using compressed air or a soft brush.
  • If the problem persists, replace the charging port.
3
  • If your Venue Pro only works when plugged in, the battery may no longer hold a charge.
  • Replace the battery.
4
  • Disconnect the charger and hold the power button for 10–15 seconds to reset.
  • Reconnect and look for a charging symbol.
  • If the issue remains, perform a factory reset or firmware reinstall.
5
  • Connect the device to a computer using a USB cable.
  • If it is not detected, the charging circuit or mainboard may have failed.
    Professional repair is recommended.
Describe your problem in your own words
View statistics:
Past 24 Hours:0
Past 7 Days:3
Past 30 Days:30
All Time:142
