Shop the Holiday Gift Guide
Does Not Power On
Todjay A Orr and 1 contributor
Last updated on Causes
Verify that the device is receiving power and charging the battery.
- If the device is off, look for a battery icon showing the charge level.
- When active, the battery icon should show a charging symbol.
- A deeply discharged battery may take time before it can power the device.
- Connect the charger and do not try to turn it on immediately.
- Leave it charging for 45–60 minutes.
- After one hour, attempt to power it on normally.
- If still unresponsive, hold the power button for 10–15 seconds to reset power delivery.
- If the problem continues, replace the battery using the Dell Venue Pro Battery Replacement Guide.
5 - 10 minutesVery easy
If the button feels jammed or disconnected, the device won’t power on.
- Press the power button several times to check for a firm click.
- Clean debris around the button.
- If it remains stuck, replace the button using the Power/Volume Button Replacement Guide.
Dell Venue Pro Volume Button Replacement
30 - 45 minutesModerate
Related Problems
Dell Venue Pro
4 problems · View all
Describe your problem in your own words
View statistics:
Past 24 Hours:3
Past 7 Days:9
Past 30 Days:56
All Time:276
