Shop the Holiday Gift Guide
White Screen of Death
The Basics
- Restart your Chromebook: A simple restart can resolve temporary display issues. Press the Refresh and Power Buttons simultaneously.
- If you're using an external monitor, check for loose external connections. Ensure the cable connecting your Chromebook to the monitor is securely plugged in. If you display content on the external screen but not on your attached screen, continue with the following steps.
Causes
Solution: Double-check that your device's settings don't cause the issue.
- Adjust your Brightness settings. All Chromebooks have some built-in controls for adjusting contrast, often associated with brightness settings. Some Chromebooks have these controls on their keyboard and are indicated. To adjust Brightness, try looking for the following:
- Click on the clock in the taskbar.
- Find the brightness icon (usually a sun or similar symbol).
- Click on the icon to open the brightness and contrast settings.
- Adjust the contrast slider to find a setting that works for you.
- Accessibility Setting: ChromeOS offers accessibility settings that include options for adjusting contrast. To access these settings:
- Click on the Gear-shaped "settings" icon.
- Scroll down and click on Accessibility in the left sidebar.
- Look for settings related to how your display looks or how contrast is handled.
- Check Chrome Flags: Chrome offers experimental features through its flags settings. While these settings are not recommended for inexperienced users, they can sometimes resolve display issues. To access Chrome flags:
- Open the Chrome browser.
- In the address bar, type chrome://flags/ and press Enter.
- Carefully review and experiment with available flags. Be cautious and change settings one at a time.
Solution: Try to recover your operating system
Occasionally, issues can occur with your operating system that affect how your hardware functions. If a simple restart isn't able to resolve your issue, you might need to recover your OS.
Recovering your operating system will factory reset your device and wipe any data on its internal storage, so be sure to move any data on the device to an external USB storage device or Google Drive.
- Recover your Operating System. If updating your device does not restore sound to your Chromebook, you can try to use a Recovery USB. You can create a recovery USB using the instructions here.
Solution: If your display is damaged, you must replace the LCD pannel.
If your Chromebook works with an external display but not with the attached display, it suggests damage to the screen. To check if the display might be faulty, follow these steps.
- Power off your Chromebook. Be sure to remove any peripherals or power sources.
- Carefully inspect the internal display for physical damage. Checking from different angles can help spot hairline cracks as they catch in the light. Look for any small cracks or liquid damage.
If the screen is damaged, the best solution is to replace it. Use the appropriate guide for your specific Chromebook. If you cannot find any damage to your display, then chances are the display cable might be experiencing complications. Read on.
Solution: If the display cable is damaged, you must replace it.
If this cable connecting your display to the rest of the computer is disconnected or damaged, the display may not work as expected.
- Ensure that the internal display is securely connected to the motherboard via the display cable. This will involve some dismantling—check out a relevant Chromebook guide to see how to get inside your Chromebook. Ensure the display cable is securely plugged into the LCD panel and motherboard. If the cable appears loose, reconnect it carefully. After reconnection, test the display to see if the content appears correctly on the LCD panel.
- Perform a visual inspection of the display cable. If no visible damage is apparent, thoroughly examine the display cable connections. Check both the end of the display and the point where the display cable connects to the motherboard. Look for any signs of damage, such as burns or indications of liquid damage. If any damage is found, try to source a new display cable and replace it.
If you don't find any issues during the display and display cable inspection, proceed to the final section for further troubleshooting.
Find compatible replacement parts for your Chromebook. All parts and fix kits are backed by the iFixit Quality Guarantee.
Solution: If components on your device's motherboard are damaged, then you will need to replace the board.
If earlier troubleshooting steps were unable to resolve the issue, then there is a high likelihood of a problem with the motherboard or the surrounding components.
- Ensure that your device's CPU is adequately cooled. Some Acer Chromebook models, such as the C712 Series, have encountered problems with cooling fan failure caused by the daughterboard's ribbon cable becoming disconnected from the motherboard. If you have recently reinstalled your heatsink, double-check that it is correctly attached to your CPU and that the CPU has the appropriate amount of thermal paste applied. Proper cooling is essential to prevent overheating and ensure optimal performance.
- Remove any accumulated dust or debris from your device's internal components. Maintaining proper airflow within your device is crucial. Dust or debris can hinder the cooling process, potentially causing issues with the operating system. Regularly cleaning your device's internals helps prevent excessive heat generation and ensures optimal performance.
- Reset your device's BIOS Settings. To reset your motherboard's BIOS settings, you can try uninstalling and then reinstalling the CMOS battery. By doing so, any stored settings or configurations that may have become corrupted will be cleared, and the system will start with default settings. This helps eliminate potential conflicts or misconfigurations that could be causing the issue you're experiencing.
- Verify that the RAM module is installed correctly and functioning properly. If it is not properly seated, it can cause display issues. Try re-inserting it, ensuring it is securely in place. Alternatively, you can consider replacing it with the same type to eliminate any potential RAM-related problems.
- Perform a thorough visual inspection of the circuit boards for any signs of burns or damaged components. Suppose you observe any visible damage, such as burns or parts that appear to be physically damaged. In that case, the board likely needs to be replaced, especially if it's the board carrying the display cable connector. You can find motherboard and daughterboard components for select Chromebook models in our store.
You're seeing solutions for Chromebook. Select your model to find parts for your device.
Related Problems
Describe your problem in your own words
