Shop the Holiday Gift Guide
E24 Code
Introduction
Error code E24 means your Bosch or Siemens dishwasher can't drain normally. A clogged filter, blocked impeller, loose pump cover, kinked or blocked waste-water hose, or obstructed siphon connection can trigger the code. Start with the accessible drain components before removing the dishwasher or its panels.
Perform regular dishwasher maintenance to help prevent drain restrictions.
Causes
Before resetting the dishwasher, record the E24 code in case you need to refer to it later.
On many Bosch dishwashers, press and hold Reset 4 Sec. or Start for approximately four seconds. The dishwasher should pump out the residual water and cancel the cycle. Button names and reset procedures vary by model, so check the owner's manual if these controls aren't present.
- If the dishwasher doesn't drain, continue to the drain-path checks below.
- If it drains but E24 returns during another cycle, continue troubleshooting. A successful reset does not rule out an intermittent blockage, kinked hose, loose pump cover, or another drain-path problem.
See Bosch dishwasher reset instructions for the manufacturer's procedure.
Disconnect power before reaching into the sump. Turn off the water supply before disconnecting hoses or pulling out a built-in dishwasher. Wear work gloves because broken glass can hide near the impeller.
Follow How to Fix the Bosch Dishwasher E24 Error Code to:
- Clean the filter and remove standing water safely.
- Check the impeller and pump cover for debris or poor seating.
- Inspect the waste-water hose for kinks or blockages.
- Check and clean the siphon connection.
- Inspect deeper drain passages if the accessible checks don't restore flow.
For general drainage diagnosis, see Dishwasher Not Draining.
Applicable Models
Some affected models are listed below. Use Command-F or Ctrl-F to search for a model number. This list is not exhaustive, and your model may not be listed.
GM926710, SHE43P25UC/64, SHE45M05UC/50, SHE45M06UC/50, SHE4AP06UC/06, SHE55M12UC/64, SHE55M15UC/64, SHE55M16UC/64, SHE58C05UC/48, SHI4302, SHI4306, SHI6802, SHI6805, SHI6806, SHU9915UC/11, SHX43C05UC/46, SHX45M05UC/50
Additional Resources
- Contact Bosch Customer Support at 1-800-944-2904
- Reset a Bosch Dishwasher
You're seeing solutions for Bosch Dishwasher. Select your model to find parts for your device.
Describe your problem in your own words
