MacBook Pro 15" Unibody (Mid 2009-Late 2011) Hard Drive Cable
  • MacBook Pro 15" Unibody (Mid 2009-Late 2011) Hard Drive Cable / New / With Bracket
  • MacBook Pro 15" Unibody (Mid 2009-Late 2011) Hard Drive Cable / New / Without Bracket
  • MacBook Pro 15" Unibody (Mid 2009-Late 2011) Hard Drive Cable / Used / With Bracket
  • MacBook Pro 15" Unibody (Mid 2009-Late 2011) Hard Drive Cable / Used / Without Bracket
  • 360°
360
$44.99
$44.99
We'll send a message when the product is back in stock.
Product Details
Description
Description
Replace that damaged Hard Drive Cable!
Connects hard drive to logic board. Includes IR sensor/sleep indicator.
Compatibility
MacBook Pro 15" Unibody 2.53 GHz Mid 2009
MacBook Pro 15" Unibody Early 2011
2 GHz
2.2 GHz
2.3 GHz
MacBook Pro 15" Unibody Late 2011
2.2 GHz
2.4 GHz
2.5 GHz
MacBook Pro 15" Unibody Mid 2009
2.66 GHz
2.8 GHz
3.06 GHz
MacBook Pro 15" Unibody Mid 2010
2.4 GHz
2.53 GHz
2.66 GHz
2.8 GHz
Show 2 more devices
Repair Stories
Joe Koffee's Story Photo #384258
Joe Koffee's Story Photo #384259
Joe Koffee's Story Photo #385195
My Problem
Short Description: I was an idiot.
Long Description: For a few months I thought it would be a good idea to run the boot drive for my Mid 2010 MBP from an external SSD. Better sense got a hold of me and I decided to migrate the drive back to the old internal HD. When I formatted the old internal HD . . .
My Problem
I tried replacing my hard drive with an SSD and damaged the hard drive cable. I needed to replace the hard drive cable to use an internal drive.
My Fix
The repair was fine following the guide. I had some trouble with stripped screws but that was about it.
My Advice
Take your time and be careful when connecting the ca . . .
My Problem
Bad hard drive or cable - had to replace both
My Fix
Very smooth, thanks to the iFixIt guide.
My Advice
This is a repair that is easy enough to do if you are not afraid to open up your computer. I highly recommend it.
My Problem
My 2009 MBP (2.53 GHz) stopped booting seemingly out of no where -- I took it to an Apple store and they "confirmed" that the HD was busted (totally believable as it's the factory original). I bought a new SSD and that wouldn't boot either. After some testing it turned out that the factory HD was . . .
My Problem
I was hoping to reconnect my hard drive. I had the "flashing file folder with question mark"
My Fix
I enjoyed my first technical repair, however the cable was not enough. My next adventure is to install a new hard drive!
My Advice
I was grateful to your "step by step" visual guide.
My Problem
After excitedly replacing my hard drive, I noticed my laptop was not identifying said hard drive! I was terrified the drive was broken or that I accidentally shocked it to death (even though I was clad in ESD safe stuff). Trying not to have a mental breakdown, I examined everything near the hard dri . . .
My Problem
Laptop was super slow and battery was shot.
My Fix
Purchased new solid state drive, new memory modules, and new battery, along with a too kit from IFIXIT Thanks to guides, everything went smoothly, except I tore hard drive cable while detaching old drive. So I had to purchase new cable and then wait for . . .
My Problem
I installed an SSD on my MBP Early 2011 model 15" using the excellent instructions on iFixit. It ran for a half hour then the MBP froze. The SSD was no longer recognized.
I reinstalled the old HDD and connected the SSD via USB and the SSD was there with no issues.
After research I found that . . .
My Problem
The problem? My computer wouldn't turn on at all.
My Fix
The IT guy at my college library advised a different cord to fix the problem, which of course didn't work so off to the Geek Squad I went. They diagnosed it with the same problem, different cord, problem solved!
My Advice
It's good to get a second opinion and sh . . .
My Problem
Original HD sata cable failed and decided to put a new faster drive in while adding a second HD in the optical bay.
My Fix
Just like the guide described...except I had purchased a HD with a 6gb/sec transfer rate and it gave me problems. Upon further research it appears that my late 2011 macbook pro has reli . . .
Show more
