MacBook Pro 15" Unibody (Early 2011-Mid 2012) Replacement Battery
  • MacBook Pro 15" Unibody (Early 2011-Mid 2012) Replacement Battery / New / Fix Kit
  • MacBook Pro 15" Unibody (Early 2011-Mid 2012) Replacement Battery / New / Part Only
  • 360°
360
$89.99
$89.99
We'll send a message when the product is back in stock.
Product Details
Description
Description
This MacBook Pro 15" Unibody (Early 2011 through Mid 2012) Replacement Battery is what you need to bring your laptop back back to life. Our aftermarket replacement batteries lead the industry in quality and reliability—each is tested and guaranteed to have a capacity greater than 6730 mAh—so you know you're getting the best money can buy.
Kit Contents
Kit Contents
Note
Lithium ion battery shipping regulations limit the shipping methods for orders containing batteries. Domestic orders may only be shipped via Standard shipping. iFixit is not able to ship batteries internationally or outside the contiguous US at this time. iFixit Customer Support will contact you if your order needs to be modified after it is placed.
Compatibility
Repair Stories
William Neuson's Story Photo #1397029
My Problem
My MacBook battery began to fail and expanded to the point of temporarily deforming the aluminum near the trackpad.
My Fix
Using the iFixit Pro Tech Toolkit, I followed the instructions in the step-by-step guide. The battery charged in a few hours and proceeded to work fine.
My Advice
In the event that the battery swe . . .
Andrea Fanelli's Story Photo #1009271
My Problem
My girlfriend's old MacBook Pro 15 2011 was dead, and she hadn't turned it on in the last 3 years. I put my hands on it and tried to figure out what was wrong. That computer is more powerful than my current MacBook Pro Retina 13 2015, so I decided it was worth investigating.
My Fix
I first tried to figu . . .
My Problem
Original battery was swelling.
My Fix
Very, very simple and straightforward. Almost as easy as changing a battery in a remote control.
My Advice
The three holes that are used to mount the battery to the chassis are ever so slightly out of alignment. Fasten these screws loosely initially, then tighten them once all are . . .
My Problem
The original 2010 Pro battery finally gave up the ghost. While the Mac help desk diagnosed a bad hard drive, replacing with a new one did not help.
After spending $100 on an online site (known to all) for an off-brand battery, which never charged properly, turns out the charger was malfunctioning. P . . .
My Problem
The battery in my five and a half year old Mac Book Pro swelled up and distorted the case.
My Fix
My first step was to remove the old battery to relieve the pressure on the case. I then ordered a cheap replacement from Amazon. It arrived and I installed it. The computer booted up and then kept rebooting . . .
My Problem
At first the issue was with booting up. The MBP would not get past the progress bar screen no matter how long we had waited. Using Command+Option+R+P didn't help. What finally helped was booting it into safe mode. Every boot up after that would work. Yay!
Once it was logged in, performance was abys . . .
My Problem
My 2011 MacBook Pro battery finally died. It had expanded so much, it was pushing the trackpad out of place and I couldn't do much on the machine. Went to Apple, they found the part on ifixit, it went out of stock quickly, I asked to be notified when they had more in, they notified me in the next co . . .
My Problem
Battery worn out, and OS said to "service soon".
My Fix
Ordered replacement from iFixit and installed it with my own tools. A couple screwdrivers, a spudger, and a few minutes time, and I have a new battery! I did have an odd instance of the computer suddenly sleeping (very shortly after typing and clicki . . .
My Problem
I came back from vacation to find this battery had inflated and nearly busted its way out of the bottom case.
My Fix
Only difficulty was that I had to reshape the bottom cover since it had been bent by the expanding battery.
My Advice
The Note 7 is not the only battery that can have problems. You should never leave a . . .
My Problem
Second battery needed replace in two years
My Fix
Very easy, I used the exact driver tips.
My Advice
You can use small slotted driver instead of ones recommended but you risk stripping the screws.
Show more
