2 TB 3.5" Hard Drive
$79.95
$79.95
We'll send a message when the product is back in stock.
Product Details
Features
Features
Important: To ensure compatibility with the 2009 and 2010 21.5" or 27" iMac, the replacement hard drive must be of the same brand as the original. The model number of the hard drive does not matter as long as the brand matches. 2011 and up iMacs cannot be supported by us.
Serial ATA interface. Works only in iMac G5s and Intel iMacs (excluding 2011 and up 21.5" and 27" models). This drive has a form factor of 3.5".
Compatibility
iMac G5 17" Model A1058
1.8 GHz (EMC No. 2055)
2 GHz
iMac G5 17" Model A1144
1.9 GHz
iMac G5 20" Model A1076
1.8 GHz
2 GHz
iMac G5 20" Model A1145
2.1 GHz
iMac Intel 17"
1.83 GHz (EMC No. 2104)
1.83 GHz (EMC No. 2110)
1.83 GHz (EMC No. 2124)
2 GHz
2.16 GHz
iMac Intel 20" EMC 2105 and 2118
2 GHz (EMC No. 2105)
2.16 GHz
2.33 GHz
iMac Intel 20" EMC 2133 and 2210
2 GHz (EMC No. 2133)
2.4 GHz (EMC No. 2133)
2.4 GHz (EMC No. 2210)
2.66 GHz (EMC No. 2210)
iMac Intel 20" EMC 2266
2.66 GHz (EMC No. 2266)
iMac Intel 21.5" EMC 2308
3.06 GHz (Core 2 Duo)
3.33 GHz (Core 2 Duo)
iMac Intel 21.5" EMC 2389
3.06 GHz (Core i3)
3.2 GHz (Core i3)
3.6 GHz (Core i5)
iMac Intel 24" EMC 2111
2.16 GHz
2.33 GHz
iMac Intel 24" EMC 2134 and 2211
2.4 GHz
2.8 GHz (EMC No. 2134)
2.8 GHz (EMC No. 2211)
3.06 GHz (EMC No. 2211)
iMac Intel 24" EMC 2267
2.66 GHz
2.93 GHz
3.06 GHz (EMC No. 2267)
iMac Intel 27"
2.66 GHz (Quad Core i5)
2.8 GHz (Quad Core i5)
2.8 GHz (Quad Core i7)
2.93 GHz (Quad Core i7)
3.2 GHz (Core i3)
3.6 GHz (Core i5)
Power Mac G5
1.6 GHz
1.8 GHz (EMC No. 1969)
1.8 GHz (Late 2004)
1.8 GHz Dual (EMC No. 1969)
1.8 GHz Dual (EMC No. 1969C)
2.0 GHz Dual (EMC No. 1969)
2.0 GHz Dual (EMC No. 1969C)
2.0 GHz Dual (EMC No. 2023)
2.0 GHz Dual (EMC No. 2061)
2.3 GHz Dual (EMC No. 2023)
2.3 GHz Dual (EMC No. 2061)
2.5 GHz Dual (EMC No. 1969C)
2.5 GHz Quad
2.7 GHz Dual
Show 12 more devices
Repair Stories
User avatar
User avatar
My Problem
The 1TB hard drive crashed and I reformatted and restored it but then it crashed again about a day or two later.
My Fix
The hard drive replacement was a breeze. It took about 1hour and after formatting the new drive and loading OS X Yosemite all I had to do was restore my files from my backup USB drive. T . . .
User avatar
My Problem
Easy to do and very inexpensive way to get computer working
My Fix
Very well for a novice at this type of repair.
Great instructions. Could have used info on material to use in replacing the heat sensor to the HD. I used a silicon paste, but wasn't sure this was the right answer. Seems to work fine.
My Advice
For . . .
User avatar
My Problem
My iMac's original 250 GB hard drive failed. Since it was a 2008 model, full repair at a service center would cost more than the computer was worth. Aside from the HD, it was in pristine condition & had an Intel processor that could handle the latest version of OSX (Yosemite), so I felt it still had . . .
User avatar
My Problem
My machine was beginning to run slower and with Safari the petty beach ball was appearing a little too often before the web page would load. Then the screen pop panic appeared, all white with no possibility of booting to the desk top screen.
My Fix
With some online research I stumbled upon the IFIXIT site a . . .
User avatar
User avatar
My Problem
Repair was pretty easy except for the fact that after everything was complete it turns out I also needed a " owc temperature sensor switch " replacing the oem hd require this cable which connects to the hard drive and temperature sensor ...if not connect the fan thinks the hard drive is failing and . . .
User avatar
My Problem
Lost hard drive on computer. All tests diagnosed the hard drive as dead. Taking it to an Apple Dealer was out if the question. More to repair than the computer is worth.
My Fix
Repair was easy thanks to your easy to follow instructions as well as tools that can be purchased from your website. I have already . . .
User avatar
User avatar
Show more
